Question about Compaq Evo N610C Notebook
Pop-up I'm searching or open page by internet and pop up the following page: http://85.17.166.130/go//rfe.php?cmp=vm_mg_fails_ron_bc&uid=74682d60fa9d11ddaf15163503cfffff&guid=9760771854bb4974832b3b9f7b811af6&lid=http&url=https%3A%2F%2Fwww.regcure.com%2Fsafecart%2Forder%2Fwithplpc%2Fregistration%2Findex.php%3Faid%3D3%26lid%3DEN%26vid%3D31245%26cpid%3D84%26lid%3DEN%26uid%3Ds6ogu&affid=163503&b42=0.0080 How disable the page
  • Kevin Shafer
    Kevin Shafer May 11, 2010
    go to www.crossloop.com/antiochpc and contact me there. Then I can get rid of it for you. Thanks.
Buy a spysweeper and anti virus software. If that doesn't work, reformat your PC, it has a serious problem.
Posted on Feb 16, 2009
I get this message ?.unable to load requested page ..failed to load YouTube .ssl handshake failed."can you help me sort it out please
It sounds like your Internet Security setting need adjusting go to your Control panel and locate System folder and Search for Internet options in your System Folder Locate Internet Options Then go to Advanced Settings then go to the bottom of the file and select Restore Default property's then Select Reset now Restart your Computer and Away you should go If you are running a Windows OS you should be right. Let me know how you go, Goodluck. Ron
Dec 07, 2017 | YouTube Computers & Internet
How to get rid of adverts
Disable Active X on your browser. Install virus and malware protection software.
Aug 11, 2014 | Computers & Internet
1983 mike hailwood replica wont start no spark
Hi, Ron and the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm needs reset
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
02 900SS No Spark Help Ducati ms The Ultimate Ducati Forum
http://www.ducatimonster.org/forums/tech/196908-i-am-also-having-no-spark-issue-please-help.html
https://www.tradebit.com/filesharing.php/search/0/1983+ducati+900
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Jan 26, 2014 | Ducati Motorcycles
Please Help 2004 dodge neon have spark engine cranks new camshaft sensor and coil does not pop w/ starting fluid code 340on reader
Trouble Code: P0340
No Camshaft Position Sensor Circuit Failure
Possible Causes:
CMP Sensor connector is damaged, open or it is shorted CMP Sensor signal circuit is open or shorted to ground or to battery voltage or 5v supply circuit CMP Sensor 5v supply circuit is open or shorted to ground or to battery voltage CMP Sensor ground circuit is open CMP Sensor is damaged or has failed CKP Sensor is damaged or has failed PCM has failed
Jun 08, 2012 | 2004 Dodge Neon
MB drivers for Asus M2N-VM DH for Windows7
Go to their support site:
http://support.asus.com/download/download.aspx?modelname=M2N-VM%20DH&SLanguage=en-us
Select Windows Vista instead. Vista and Windows 7 have the same kernel so the drivers are compatible. Just make sure you choose correctly between 32/64bit. Please vote if this helped you. Thanks.
Mar 07, 2011 | Computers & Internet
Replaceing motherboard
1. Go to the following link: http://support.asus.com/download/download.aspx
2. In the "General Download" section, select "Motherboard" from the first drop-down menu.
3. Select "Socket 478" from the second drop-down menu.
4. Select "P4S533-E" from the third drop-down menu.
5. Click "Search".
6. In the pop-up window, select "Others", then click "Search".
7. On the next page, click the "+" sign oppoaite to "Manual (3)".
8. Scroll to the bottom of the page to the section labeled "Version E1034". Click on "Global (DLM)" opposite to "Download from".
9. Enter the numbers/characters in the displayed image into the text box, then click "Submit".
Oct 25, 2009 | ASUS P4S533-E Motherboard
Java problem with pogo games
First uninstall both Java and Microsoft VM. To uninstall Java follow the instructions from the following link: http://www.java.com/en/download/help/uninstall_java.xml
To uninstall Microsft VM follow the instructions from the following link: http://www.java.com/en/download/help/uninstall_msvm.xml
Download and install Java from the following link: http://javadl.sun.com/webapps/download/AutoDL?BundleId=29219
After installing Java reset internet explorer. On internet explorer click tools -> internet options. Click advanced in internet options screen and click on Reset.
Revert for any clarifications
Apr 07, 2009 | Microsoft Windows XP Professional for PC
I cant find it! HELP PLS. HELLLLLLLLLLLLP>..
If you have a broadband Internet connection you can download all your motherboard drivers:
1) Go to this page: http://support.asus.com/download/download.aspx?SLanguage=en-us
2) in the Download box in the upper left hand corner enter "S533" in the field titled "Input Model to Search".
3) Click on the Search Info box just below.
4) once teh search is done you will be presented with several choices to select from, find and click on the one labled "P4S533-VM"
Once you have the drivers just copy them to a USB drive and avoid the whole CD burning mess.
Dec 14, 2007 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Compaq Evo N610C Notebook Logo
29 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
