Question about Philips GOGEAR SA6045 MP3 Player
My mp3 player won't do anything!!
It will not:
turn on reset charge react AT ALL
I need help!!! Is it completely dead? My computer doesn't recognize it when I plug it in. Please help!!
  • 2 more comments
  • graykitty101 Feb 15, 2009
    I don't think that is the case, because before it completely collapsed on me, it had a full battery.
  • Anonymous Feb 17, 2009
    mp3 WONT DO ANYTHING
  • hobie87 Feb 25, 2009
    same exact problem as she is having
  • Anonymous Feb 26, 2009
    My mp3 player won't do anything!!"
  • 4,889 Answers
Hello there,
It is unlikely that the player is dead but the Usb cable or USB/charging port or the battery is dead. If the player is under warranty you can demand for a replacement. Otherwise check if a replacement usb cable would fix the issue. Otherwise its going to cost you around $30 for repairs.
Sai.
Posted on Feb 15, 2009
  • eagle338
    eagle338 Feb 15, 2009
    In that case the contacts inside the player may be broken. They battery can die on you even when fully charged if it has crossed the recharge cycle limit. Either ways your player requires service.
It was running and then shut off. It wont turn on and the reset button doesn't do anything either. the computer doesn't recognize that it is attached. It appears to be completely dead. I charged it...
You should try to repair the player using Philips Device Manager. The procedure that you should do is described detailed step by step at the manufacturer's web site:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=BE&slg=ENG&sct=PORTABLE_VIDEO_PLAYERS_SU&cat=MP3_AND_MEDIA_PLAYERS_CA&grp=SOUND_AND_VISION_GR&session=20100703194931_66.249.65.15&ctn=SA3125/02&list=aa12_list_partial.html&mid=Link_DiagnosticInformationTool&hlt=Link_DiagnosticInformationTool
At first select the category "communication with the PC" and follow the instructions you get there.
Finally you will get to the state "repair function" and you will be able to hope successful action.
gylacz
Jul 20, 2011 | Philips SA3125\02 MP3 Player
Sandisk Express will not turn on.
Ensure that the player has been charged.
Try to power reset the device by simultaneously pressing and holding the center and volume up button, while connecting it to the PC.
If power reset fails, charge the device for at least two and a half hours. The computer should not be in sleep or hibernation state while charging.
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
Jan 14, 2010 | SanDisk Sansa MP3 Player
Creative zen mp3 player won't turn on. already tried resetting
Mine did exactly the same and i thought it was dead, but when u are reseting it keep it plugged into the computer while reseting it and it should turn on. It worked for mines anyway.
Jul 15, 2009 | Creative Labs Creative Technology Zen MP3...
My creative zen won't turn on it's vision m 30 gb and when you plug it in all it dose is flash It doesn't pop up or even say anything in my computer PLEASE HELP
I am unable to reset my ZEN Vision M player. It will not even connect with my computer and the battery is completely dead. Is there a solution?
Jul 03, 2009 | Creative Labs ZEN Vision:M Digital Media...
My coby mp3 player is completly dead and will not turn on when charged up or reseted
how do you try to tourn it on try charging it to a point to where it wont even do anything and then try it
Jun 01, 2009 | Coby MP-C7085 MP3 Player
Connects to the computer but wont turn on
i have the same problem to!! what a heap of ****!
Oct 11, 2008 | Samsung YP-K3 MP3 Player
Networking Trouble?
Make sure you are using the USB cable that originally came with the Walkman. Make sure the hold switch is not turned on.
Reset the player.
Try charging using another USB port on your computer - if that fails, try charging on another computer completely (but make sure it has the same OS or you will experience formatting- related issues).
My general info sheet: 1.       “My Mp3 player won’t turn on” or “My Mp3 player won’t hold a charge.” (POWER SUPPLY ISSUE)
The tricky part about these issues is that there are several possible causes – it could be software or it could be hardware.  Before you try anything else, make sure the mp3 player’s “hold” or “lock” switch is not engaged.  See your user’s manual for location of switch/ instructions (available from manufacturer’s website).  If the hold is engaged, the mp3 player will not charge, and it will not turn on.  Then, make sure the player is plugged into a compatible computer with a USB 2.0 port.  Many laptops and older desktops lack sufficient power resources to properly power/charge/utilize an mp3 player.  Next, try resetting your mp3 player.  If that still fails, try your device’s “recovery” button.  There is a specific button that triggers the recovery mode – volume + for most players, REC button for others, play for others, and skip forward for still others.  The general formula goes something like this, although you may have to substitute another button for “volume +”: disconnect the player from the computer, turn it off even if you have to reset the player to turn it off (if it is dead, this won’t be a problem), hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player (even if it is completely dead) - it will pop up a window that says Found New Hardware Wizard.
Make sure that your mp3 player is not designed for a country other than your own – this information can be obtained from the manufacturer in most cases.  European and some Asian current systems are different than in the U.S., Canada, and Mexico.  If you plug a United States mp3 player into a European wall outlet, you will fry the player.  If you plug a German mp3 player into a US outlet, it will have insufficient power to power the player.  There are transformers available that can correct for this issue.
If you have lost the original charger for your mp3 player, try to obtain the original charger.  If the original is no longer available, check your product specs to get EXACTLY the correct voltage.  It may seem harmless to use a 5V charger on a 4.5V mp3 player, but in many cases you will damage the mp3 player by doing this.
Also, never unplug an mp3 player while it is transferring music/files/performing a firmware upgrade (and also, never perform these activities when your player is not at least 75% charged).  This is a sure way to kill most mp3 players.  As a safety rule, always check and use the “safely remove hardware” option if it is available on your computer – lower right hand corner (green arrow pointing to chip) in most Windows taskbars.  If it is not available, wait one full minute after your last file transfer to unplug the mp3 player – even if your mp3 player says “OK to disconnect.”
If your mp3 player uses AA, AAA, or any type of user-removable battery, you must take extra steps to prevent equipment damage when replacing batteries (most product manufacturers do not know this tip).  Before removing the batteries, power the player off and let it sit for one minute or longer.  Run your hand along the side of your computer tower to dissipate static electricity (or use any other method available to dissipate static electricity).  Use only and exactly the replacement battery recommended by the manufacturer.  Carefully remove the old battery.  Hold and gently squeeze the new battery for a few seconds to dissipate static.  Hold the mp3 player case in one hand, and carefully insert the new battery.  One single static spark, and your mp3 player could be history.  Also, check your product documentation beforehand to see if removing the battery will result in your song’s being erased/data being lost.  Many, if not most, mp3 players do not have replaceable batteries – the manufacturers do not have them, and popping open your mp3 player more often than not causes damage to additional components.
If the solutions above do not work, and you have gone through troubleshooting with the manufacturer, you may have hardware damage and the player will need to be replaced.
-Tha Mp3 Doctor
Sep 14, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
Digital media player
Make sure the hold switch if off. Reset the player. Try a different USB port on same computer. Try a different computer with the same OS (to prevent formatting-related errors)  Here's some general info about the problem:  “My Mp3 player won’t turn on” or “My Mp3 player won’t hold a charge.” (POWER SUPPLY ISSUE) The tricky part about these issues is that there are several possible causes – it could be software or it could be hardware.  Before you try anything else, make sure the mp3 player’s “hold” or “lock” switch is not engaged.  See your user’s manual for location of switch/ instructions (available from manufacturer’s website).  If the hold is engaged, the mp3 player will not charge, and it will not turn on.  Then, make sure the player is plugged into a compatible computer with a USB 2.0 port.  Manylaptops and older desktops lack sufficient power resources to properly power/charge/utilize an mp3 player.  Next, try resetting your mp3 player.  If that still fails, try your device’s “recovery” button. There is a specific button that triggers the recovery mode – volume + for most players, REC button for others, play for others, and skip forward for still others.  The general formula goes something like this, although you may have to substitute another button for “volume +”: disconnect the player from the computer, turn it off even if you have to reset the player to turn it off (if it is dead, this won’t be a problem), hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player (even if it is completely dead) - it will pop up a window that says Found New Hardware Wizard. Make sure that your mp3 player is not designed for a country other than your own – this information can be obtained from the manufacturer in most cases.  European and some Asian current systems are different than in the U.S., Canada, and Mexico.  If you plug a United States mp3 player into a European wall outlet, you will fry the player.  If you plug a German mp3 player into a US outlet, it will have insufficient power to power the player.  There are transformers available that can correct for this issue. If you have lost the original charger for your mp3 player, try to obtain the original charger.  If the original is no longer available, check your product specs to get EXACTLY the correct voltage.  It may seem harmless to use a 5V charger on a 4.5V mp3 player, but in many cases you will damage the mp3 player by doing this. Also, never unplug an mp3 player while it is transferring music/files/performing a firmware upgrade (and also, never perform these activities when your player is not at least 75% charged).  This is a sure way to kill most mp3 players.  As a safety rule, always check and use the “safely remove hardware” option if it is available on your computer – lower right hand corner (green arrow pointing to chip) in most Windows taskbars.  If it is not available, wait one full minute after your last file transfer to unplug the mp3 player – even if your mp3 player says “OK to disconnect.” If your mp3 player uses AA, AAA, or any type of user-removable battery, you must take extra steps to prevent equipment damage when replacing batteries (most product manufacturers do not know this tip).  Before removing the batteries, power the player off and let it sit for one minute or longer.  Run your hand along the side of your computer tower to dissipate static electricity (or use any other method available to dissipate static electricity).  Use only and exactly the replacement battery recommended by the manufacturer.  Carefully remove the old battery.  Hold and gently squeeze the new battery for a few seconds to dissipate static.  Hold the mp3 player case in one hand, and carefully insert the new battery.  One single static spark, and your mp3 player could be history.  Also, check your product documentation beforehand to see if removing the battery will result in your song’s being erased/data being lost.  Many, if not most, mp3 players do not have replaceable batteries – the manufacturers do not have them, and popping open your mp3 player more often than not causes damage to additional components. If the solutions above do not work, and you have gone through troubleshooting with the manufacturer, you may have hardware damage and the player will need to be replaced. -Tha Mp3 Doctor
Aug 12, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
My creative zen is completely dead it doesn't power on at all also it doesn't charge there is no power what so ever please help me
I have had the problem of the completely dead player after having it for less that an day. No response to any buttons, no response when plugged into USB to charge, and Windows sees it as an "unknown device" when plugged into the PC. It tried the reset hole, and still nothing.
Then I tried connecting it to the PC to charge and then using the reset hole. Success - the player sprang back to life, fully charged. Hope this helps someone.
Jul 17, 2008 | Creative Labs Zen Stone Plus MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
167 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
