Question about Trendware TRENDnet TEW-432BRP 54Mbps Wireless G Firewall Rou Router (TN-432BRP)
Ive asked the question. Where is the answer found?
Re Trendnet router "wired" aand PS3 - is 54 mbps enough to run Call of duty 4?
I went on PS3 website and found a forum where someone had the same problem. I then re-installed the trendnet router - with their support. I had the port forward numbers from the forum and we installed them and then, re-configured the Ps3. That solved the problem.
Posted on Feb 16, 2009
Why my router trendnet tew-731BR doesn't working?
You have to look on the tag at the base or back and find the IP address and admin / password sign in to set it up. Set of numbers like or then when on the routers server you can enter your ISP details to get the router setup.
Dec 05, 2014 | Trendnet TEW-731BR 300 Mbps Wireless-N...
I need a pin number to get on the internet through my trendnet router
where is it asking you for a pin number!! if possible show a screenshot of the problem, i will surely help you out
May 13, 2011 | Trendnet TEW652BRP 300 Mbps WiFi N router...
How can i connect a trendnet (tew-652brp) 300mbps wireless router on aevdo wireless modem
depending on what you are doing with the two devices, there are a bunch of different answers. usually connecting two like devices requires a crossover cable. This is different from the traditional straight-through cables that you can buy at walmart. but for simplicity sake, use a crossover cable
May 09, 2011 | Trendnet TEW652BRP 300 Mbps WiFi N router...
I have my router and everything hooked up but my xbox 360 upstairs (1 floor) is not recieving connection and it clearly states on the box that the connection goes up to two floors
You may need to change the configuration of the router to use B/G/N compatibility mode using the 2.4GHz spectrum instead of the N-Only mode using the 5GHz spectrum.
On page 30 of the user manual available at the TrendNet web site, the Wireless >> Basic web page settings has a choice of "802.11 Mode". For your situation, you will want to use the "Mixed 802.11n, 802.11g, and 802.11b" setting.
Dec 28, 2010 | Trendnet TEW652BRP 300 Mbps WiFi N router...
Trendnet tew-652brp username: admin password: admin Computer will not accept this, please help
Just reset it! At the back of the router is a small hole.With a toothpick or some like press gently for 30 seconds and wait for the router to start up again.Log in to and start a new configuration.
Ifyou need more help come back.
Post/ thumbs / testimonial are welcome!
Dec 27, 2010 | Trendnet TEW652BRP 300 Mbps WiFi N router...
Hi, I purchased Trendnet TEW-651br today and set up the connection. Everything seemed to be working fine until I noticed I'm getting way too slow download speed. The reason I chose this rooter was 150...
Well The best way go get a new one... They are chep now cant by a DLINK Ultra Fast data transfer for $69.99 they are good but if your want 8 to 10 HUB well it will be $160.. not bad
Sep 30, 2010 | Trendnet Wireless Home Router TEW651BR
Use 2 wire to run laptop
Yes you can use the laptop with this router because this is a wireless router.
Details of the router are:-
Manufacturer: 2wire Product MPN MPN 1000-400108-001 Key Features Router Functionalities dtrquestion.gif Wireless Access Point • DSL Modem • Firewall • DHCP Server Connectivity Wireless Interfaces Built-In 4-port Built-In Switch LAN Interfaces 10/100 Base-T Additional Interfaces 1 x USB Standards and Protocols LAN Standards IEEE 802.3 CSMA/CD or Ethernet • IEEE 802.3u 100 Mbps (Fast Ethernet) Protocols dtrquestion.gif AAL5 • ARP • ATM • DHCP • ICMP • IP • PPPoA • PPPoE • TCP • UDP Remote Management Protocol dtrquestion.gif SNMP • HTTP Firewall / VPN Firewall Features Stateful Packet Inspection (SPI) • NAT VPN Protocols IPSec Pass-Thru • PPTP Pass-Thru • L2TP Pass-Thru Authentication CHAP Wireless WLAN Standards IEEE 802.11b 802.11b Data Rates 11 Mbps, 5.5 Mbps, 2 Mbps, 1 Mbps Modulation dtrquestion.gif CCK • DBPSK • DQPSK • DSSS Security dtrquestion.gif WEP Antenna Type dtrquestion.gif Internal / Integrated Antenna x 3 Modem DSL Standards ADSL Lite (G.Lite ITU G.992.2) Other Features LED Indicators Power • DSL • Link Additional Features Auto Crossover (MDI/MDI-X) Dimensions Width 2 in. Depth 10 in. Height 8 in. Weight 1.4 lb. Miscellaneous Release Date December, 2003
May 03, 2010 | 2wire (1000-400108-001) Router
Hi, I have a Trendnet TEW-432BRP wireless router and even if the speed link is 20 mbps (I tested it without the router in the midle) I get only 8 mbps having the router installed. Please help me solving...
You may need to do a firmware upgrade on your router to make the connection faster behind it....You can get the latest firmware from the manufacturers web site....
Dec 28, 2009 | Trendware TEW-432BRP Wireless Router...
Problem with Pre n Router
54mbps is what the Belkin routers wireless signal transmits at! This cannot be altered and is working correctly regardless of other wireless card speeds.
Jul 10, 2008 | Belkin Wireless Pre-N (F5D8230-4) Router...
Open Questions:
See all Trendware TRENDnet TEW-432BRP 54Mbps Wireless G Questions
Trendware TRENDnet TEW-432BRP 54Mbps Wireless G Firewall Rou Router (TN-432BRP) Logo
Top Trendware Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
