Question about Magic Chef CYG4000AWW Gas Dryer
Gas dryer runs sometimes, not others.
To start it sometimes makes noise then sturggles to "catch" and start. Other times it makes connective noise but then stops noise and won't work.
  • Magic Chef Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dhjhdf
Posted on Sep 29, 2010
Electrolux dryer getting 'stuck' at times
the belt is frayed and catching at times. mine was split in half. right down the middle.gets caught on tention pulley as it goes around,,,sometimes
May 10, 2014 | Dryers
The engine cuts off like its out of gas. It is intermittent and can happen when I am doing 70 on highway, the power starts to drop I can depress the gas pedal and after repeated pumping will sometimes...
Have you scanned for any fault codes? Most parts stores have them available to loan out short-term (5 to 10 minutes in their parking lot).
Without any OBD scan, it's very difficult to even point you in a direction.
It could be electrical or fuel-related. When was the last time you had the fuel filter replaced? Check the plugs/coils for fouling and proper connection. Check the battery connections to make sure nothing is loose.
Sep 03, 2013 | 2008 Scion Xb
Dryer was making high pitched squealing noise and now won't run
Please supply the model number so we can help further.
May 20, 2012 | Hotpoint Dryers
My Maytag Atlantis gas dryer is making a sqeeling noise and sometimes will not turn the drum, unless i hand turn it and my run, i open it up but nothing looks out of order, the motor smells as if it is...
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 24, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
I have a LGR5636EQ3 Maytag dryer that will not heat up and the timer is not keeping correct time. Dryer will run but longer than preset time and no heat. No click noise when started. I had dryer set at 60...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 13, 2010 | Kenmore 73952 Gas Dryer
My 1987 GE Dryer, Model # DDE5300GALWH,will not run all the time.
sounds like you need a new timer you can actually take the timer apart to check for a burnt connection
Jan 07, 2010 | GE Dryers
I have a Frigidaire dryer model FDE437GHS0 It has been working fine til this morning. If I turn the timer switch to time dry and push the start button it sounds like the timer is turning(or the gears are)...
IT SOUNDS LIKE THE TIMER IS BAD. IF THE TIMER MAKES NOISE IN ANY POSITION AND GRINDS THE LITTLE TIMER MOTOR OR THE TEETH ON THE MAIN GEAR IS SLIPPING
Aug 11, 2009 | Dryers
Sometimes starts, sometimes doesn't
sounds like the timer is bad
Jun 17, 2009 | Dryers
WHIRLPOOL GAS DRYER MODEL LGR7646E
sounds like your motor is bad or the start relay on motor.. dont think you can replace just the start relay on that motor
Nov 06, 2007 | Whirlpool LGR3624JQ Gas Dryer
Magic Chef CYG4000AWW Gas Dryer Logo
121 people viewed this question
Top Magic Chef Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Charles T Nevin
Charles T Nevin
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
