Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Lamp has been replaced but TV wont power up?
I have purchased a new bulb, replaced it and installed. when I attempt to power on the TV the power indicater flashes yellow for about 2 minutes. then it flashes red and the lamp indicater flashes red a few time then nothing.
Any advice?
  • Greg Giddens Sep 30, 2013
    The door not being installed correctly caused the problem I was having thx alot...I would not have known about the little switch that flips up when the door is on if it hadnt have been for this suggestion again thx very much seved me alot of $$$
    Novelist:
  • 184 Answers
If the lamp is a known good one, the next most likely suspects are the lamp ballast/power supply board or a mis-aligned lamp door. There's an interlock switch which opens when the lamp door is removed. Try removing and re-installing the lamp and the door.
Posted on Feb 15, 2009
Wer is the light bulb so I can change it?
Replacement of the lamp should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The lamp is sat in a housing and its position is adjacent to the vent holes that it shines through.
If you feel confident, disconnect it from the mains power, remove anything in the cavity.
Remove the microwave cover. Purchasing a new replacement lamp will be useful as it will give you an idea of what it looks like. Locate the dead lamp remove the lamp and fit the new one. Replace the covers. Plug it back in and try the lamp by opening the door.
Hope this helps.
Mar 27, 2011 | Microwave Ovens
I have a samsung tv, HLT61765X/XAA. the picture has gone really dark. Could it be the bulb?
yeah this sounds like a bulb burning out they are made to last 6000-8000 life hours I found the lamp you need just in case
http://www.discount-merchant.com/Samsung-BP96-01795A-Lamp-Enclosure-p/samsung-bp96-01795a_lamp_enc.htm?1=1&CartID=0
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!
Oct 26, 2010 | Samsung HLT6176S Television
I have a hitachi 55vs69 projection television. Lately, it has been shutting down every 15 minutes or so. The screen turns dark but you can still hear video until about a couple minutes later the led light...
First step is to unplug the 120 vac power for a few minutes to clear any corrupted data that may be present in the controller circuits.
If a "power" reset doesn't help and the lamp or bulb is installed correctly, you most likely have a failed replacement bulb. The symptoms are all standard indications of a failed bulb.
Reduced lamp life can be caused by:
  1. Lightning and other 120 vac power bumps.
  2. Collisions with vacuum cleaners or other incidental impacts while the TV bulb is operating.
  3. Starting the TV without a complete cool down. Bulb will consume a small amount of mercury with each start. Excessive consumption occurs when bulb is "Hot" and turned on.
  4. Wrong bulb installed as replacement.(Philips original replaced with Osram or El Cheapo)
  5. Poor quality or damaged bulb installed as replacement.
  6. Bulb damaged during replacement
  7. Bulb installed incorrectly at replacement.
Almost all Hitachi 55vs69 "No Picture" failures are related to the bulb.
Many of our service events are with customers that purchased El Cheapo bulbs from "shopping cart" websites or picked up a bulb from a small "local" TV shop. Many small shops stock of 3 or 4 bulbs and try to substitute or cross reference to fit more than 200 models of TVs from 7 different manufacturers. If a premature bulb failure occurs, they have the opportunity to sell you some expensive service.
Go here to see all of the different Hitachi TV bulbs that are available in Canada.
Find Your Lamp
Use the correct bulb for your model and if you are uncomfortable with the replacement procedure, get local service.
Jun 08, 2010 | Hitachi 55VS69 55" Projection HDTV
Still getting "Projection lamp is nearing end of life"
KDF46E2000 - Change Lamp Warning - Reset
Bulb is most likely OK. Original bulb in Sony TV is Philips, label on bulb usually says Philips. Sony don't make bulbs. Sony Cost is usually 1.5 times other sources. Many shopping cart operations sell condemned, reject or poor quality electronic service items because cost of return and fooling with them is excessive. This is obvious and widespread with convergence ICs and other parts.
Lamp timer needs reset. This is usually an automatic function. TV detects Increased lamp current from previous failed bulb or weak bulb condition and resets automatically. TV must be unplugged for lamp replacement for this to work. Occasionally it must be reset manually, as below:
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a
second of each other:
DISPLAY Channel 5 Volume + POWER .1. Access Service Adjustment Mode and select the Service Menu that
contains the Category with the Adjustment Item you want to change.
2. To change the Category, press 2 or 5 on the Remote Commander.
Note: Pressing 2 or 5 only changes the categories within the
Service Menu displayed. To change a Category on one of the other
Service Menus, press the JUMP button until the correct Service
Menu is displayed.
3. To change the Adjustment Item, press 1 or 4 on the Remote
Commander.
4. To change the Data Value, press 3 or 6 on the Remote
Commander.
Note: To go back to the last saved Data Value, press 0 then ENT
on the Remote Commander to read the memory.
5. To save the changes, press MUTING then ENT to write into
memory.
6. To exit service mode, turn the power off by pressing POWER .
Wait 2 minutes before restarting the set to allow the fans to
completely shut down or the Service Menu will appear on the screen.
easyab
ConvergenceRepair.com
__________________
Feb 27, 2010 | Sony KDF46E2000 46" Projection HDTV
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Sharp TV Flashing Codes
did you purchase just a new bulb? or did you buy the bulb with the cage included?
Oct 21, 2008 | Sharp 56DR650 Television
Lamp failure indicator
I had the same issue when replacing my lamp for the first time. I replace just the bulb with the Phillips replacement bulb. After installing the power down issue started and it would take up to 7 attempts before the TV would stay on with a picture.
Since I never had this problem until i replaced the bulb i decided to send the new bulb back and replace it with a difference one. In my opinion replacement parts are never made to the same standard as original OEM parts. This TV is definitely very temperamental in regard to the bulbs.
When the second replacement bulb arrived I decided to not only replace the bulb I also cleaned the connector plug in the cartridge with a QTip and alcohol. I did the same for the plug receptor in the TV.
When I replaced the bulb i insured the the top of bulb lettering was facing the handle of the cartridge so when you put the cartridge back in the TV the top of the bulb would be facing you.
I also cleaned the entire inside of the TV where the cartridge is inserted including the screws.
Once I did all this the TV turned on the first time and has been working fine for three days now.
I do believe the replacement bulb position is very important as to how it heats up and determines when it needs to cool.
I hope this helps others with the same success i had because I really do not want to replace this TV and start replacing all the parts others have done with little to no success for this issue.
Jul 11, 2008 | Mitsubishi WD62527 62 in. LCD HDTV
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
172 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
