Question about Toshiba 42H81 42" Rear Projection Television
Power light blinking
I have a Toshiba 42H81 that has the power indicator light blinking and the TV will not turn oni also have the same problem.. want to know if it can be fixed by myself or is a tv repair person the best way to go
  • 1 more comment
  • jimsbigpp Feb 15, 2009
    i have the blinking red power light. the tv turns on and runs for about a minute then shuts down to the blinking light. i have already tried unplugging it for a day.
    the power supply board sounds right. can i replace this myself? if so where do i order it from?
    the red blinks are constant
  • 52 Answers
Best bet would be to call a repairman.
One of the boards could be fried, power supply, bad bulb, etc.
Repairman, definately.
-Captain Jake
Posted on Feb 15, 2009
    Brigadier General:
  • 8,619 Answers
Hi!
Please tell me how many times the light is blinking? Try to turn it off for 10 min.s and then turn it on.
  • 217 Answers
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Always, blinking light indicate protective mode and indicates fault sensed by the built-in diagnostics. The sequence and count of the blinks would indicate probable area of fault or where to start.
Two ways to address the problem:
  • DIY (do-it-yourself) repair. This would require familiarity with electronic components & circuitry, use of a DVM/VOM and a soldering iron. It would be to your advantage to have access to a Service Manual or at the very least a schematic diagram with voltage measurements;
  • seek the services of a qualified professional for a repair quotation.
While it would be possible to effect your own repairs, there would be the above mentioned pre-requisites; otherwise, it would be guess work and unfortunately may lead to false diagnosis/parts replacement. A quote on the other hand would cost depending on the going rate within your location. The advantage is that you would have an idea of the possible cost of parts and service fee. This would be significant since this information factored in with downtime, efforts to have the TV repair would present you an evaluation of your options or even consider replacing the unit entirely.
If you are comfortable with the DIY, pls post back. Good luck and thank you for using FixYa.
  • 479 Answers
Hi and welcome to Fixya,
If the indicator light is blinking but no display on the TV means there is not a power issue,Issue seems with some internal fuse or connector so it will be right to go for the repair but try first to refix all the things including settop box.
Then try with the menu if the menu is coming,the display assembly is fine but the issue is with other conectors.
Thanks
    Sergeant:
  • 326 Answers
As the power indicator light blinking this indicates the problem in the tv.the exact fault can be located by the number of blinks you get.but any how if you r familiar with soldering iron and using multi meters you can can do this other wise its better to can a service person either then taking a risk.but if you r familiar with using meter and soldering just count the number of bliks you get at the front pannel of the tv and i provide you further reparing instructions.
    President:
  • 2,110 Answers
In this unit it's likely the convergence amps are the cause. Those and possibly the 2.2ohm resistors (especially R7726) in the yoke return path -also check fuse..
    Master:
  • 848 Answers
Hi
it tends to be problem in power supply board.....
  • gopinath pasupathy Feb 15, 2009
    if power supply board sounds right check for the fuses andbad capacitors in and around main board.......you can do this repair yourself with the help of service manual .....parts and power supply can be obtained from partstore.com
    you can get parts for your tv from the link
    http://www.shopjimmy.com/TVs/Toshiba/Tos...
  • Toshiba Master
  • 19,396 Answers
Depends, try first unplugging tv power cord for five minutes.
  • Ginko
    Ginko Feb 15, 2009
    Try first unplugging tv power cord for five minutes, this is called hard reset and will reset settings and get rid of minor hardware problems.
    If that does not work, try leaving unplugged for longer, let say few hours, if TV still does not restart it is faulty.
    The led blinking is a special diagnostic mode called protection, if the TV still stays on protection after unplugging power for few hours, and draining power from TV completely, then the TV is faulty.
    In that case you will need a technician to fix the problem.
    Commons problems on this set concerns power board and convergence board, and repair for those is about $200.
Red light blinks and black screen.
The blinking red light is a standby indicator. Make sure your remote is set to "tv" and not "cable" or "auxiliary".
Jul 25, 2009 | Toshiba 42H81 42" Rear Projection...
TV turns off and power light blinks unpluged andd still does it.
Likely to be the STK convergence chips causing a protection circuit to switch the TV off. Have you got any onscreen convergence problems (i.e, colour fringes)?
May 27, 2009 | Toshiba 42H81 42" Rear Projection...
My Toshiba Rear projection TV Has A blinking power light
The power supply is in protect mode. There is most likely a short on one of the boards, or the high voltage generator, or a scan amplifier, or the power supply itself has a failure. Without troubleshooting the set it is impossible to know.
Jerry G.
Feb 19, 2009 | Toshiba 42H81 42" Rear Projection...
Oct 14, 2008 | Toshiba 42H81 42" Rear Projection...
Replace the convergence amps and check the return resistors in path to the yoke from that circuit.
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Toshiba 42h81
STK392-110 's = replace with Toshiba or Sanyo quality only..
What was the location & value of the resistor ?
An IC, if shorted internally,can prevent the tv from powering up..
Re-check soldered in 5 amp micro fuses F850,851,852,etc
Fix it ! ..............................T.
Aug 28, 2008 | Toshiba 42H81 42" Rear Projection...
Toshiba 42h81
have you try to switch it on using the contol on the tv..?
Jul 20, 2008 | Televison & Video
Blinking red power indicator light
Pushing it back in place went it went out tells me that the problem is probably a poor solder connection. That arcing probably took out one of the fuses, but a fuse is NEVER the cause merely a symptom. I would begin by examining the black wire that feeds the +16v to the convergence IC's on the main board. The convergence circuit is the most thermal circuit in that unit. Next check for any jumpers and other component joints that appear to be ring cracked. Even the convergence amps themselves. Then check for open fuses after you've made a good inspection. Check for fuses: F850 & F851 5amp, F470 2amp, and F890 3.15amp and one of these are likely open. But if you replace them without correcting the problem that cause them to open it will simply happen again.. Good Luck Bill
Jun 10, 2007 | Toshiba 42H81 42" Rear Projection...
This appears to be a duplicate post - - and I'm not sure which one you'll check for an answer so here goes: Pushing it back in place went it went out tells me that the problem is probably a poor solder connection. That arcing probably took out one of the fuses, but a fuse is NEVER the cause merely a symptom. I would begin by examining the black wire that feeds the +16v to the convergence IC's on the main board. The convergence circuit is the most thermal circuit in that unit. Next check for any jumpers and other component joints that appear to be ring cracked. Even the convergence amps themselves. Then check for open fuses after you've made a good inspection. Check for fuses: F850 & F851 5amp, F470 2amp, and F890 3.15amp and one of these are likely open. But if you replace them without correcting the problem that cause them to open it will simply happen again.. Good Luck Bill
TV auto shut off-power indicator light blinking-won't turn back on
You could have gotten an electrical surge that put your set into a shutdown condition and unplugging the set and letting the Microprocessor reset will fix this problem if it dosent blow out the main power regulator as you still or might I say have a regulator IC problem. IF THIS PROBLEM HAPPENS AGAIN MORE THEN A FEW TIMES WITHIN A SMALL TIME FRAME I WOULD HAVE THE SET LOOKED AT BEFORE THE REGULAOR BLOWS SOMETHING OUT!!!!
Jan 11, 2006 | Toshiba 43H70 43" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
61 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
