Question about Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer
Water coming out of the draw during cycle
Water has been coming out of the draw, it seems to be when it is about to spin. I have been drying things that seem to have a lot of fur or fluff so could it be that something needs to be cleaned or unblocked somewhere?
  • karsy Feb 17, 2009
    water comes out of draw when emptying and on a spin. tried the drain button to see if the same thing happens but there seems to be no problem on this function, not sure if something is blocked.
Water comes out of draw when the water is emptying and on a spin. have tried it on the drain button to see if it did the same and there seems to be no problem on this function, only seems to be a problem when spinning, not sure if something is blocked.
Posted on Feb 17, 2009
    Problem Solver:
  • 14 Answers
CHECK YOUR PUMP MY BE BLOCKED
Posted on Feb 15, 2009
Washer is leaking during rinse/spin cycle
What is the model number of your unit?
Nov 23, 2012 | Washing Machines
LG WM3988HWA water filling drum and overflowing during dry cycle
Solution for finding the right part, the (5 way) Valve assembly:Part Number: AP4998623 made by LG
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5520795
I got the company link from LG. If the link does not work, go the the main website and enter in the model number. appliancepartspro(.)com
p.s. I found a service manual for my unit when I removed (by unscrewing) the inside plastic piece of the pump filter. It was located to the right, in a plastic bag.
p.s.s. I checked my water pressure, it was 90psi. I think this is why my flow limiter 'shot out' the valve and into the tubing.
p.s.s.s. The dryer heater assembly, the duct out, fan, and tubing was filled with so much lint, I was surprised anything could get through.
Nov 20, 2011 | LG WM3988HWA Front Load Washer / Dryer
I have a Kenmore frontloading washer, model no. 417.42042100. At the end of the wash cycle, the clothes are still very wet; that is, still SOAKED with water, even though all the water has been drained...
HI. your unit is equipped with a spin control board. this board, if damaged, will not initiate an adequate spin. This will not allow for proper drainage and drying of the clothes. The spin motor regulates the rotation speed during the spin cycle. It seems to be the culprit at this time. Have the spin board replaced asap.
This part will usually cost around $150.00 at the most.
Aug 27, 2009 | Kenmore Washing Machines
Spins fine, but clothes still soaking wet
Clogged water pump. Not draing fast enough. If this is helpful, please post as such.
Feb 21, 2009 | Maytag Performa PAV2200
Hotpoint Aquarius 1200 Washer Dryer not drying.
Hi, I think the problem you have is with the cold water inlet valve? When your machine dries it uses a small amount of water at high pressure through a restricter fitted in the water inlet valve. These break down letting in to much water which cannot evaporate quick enough for it to pump out causing the washing to become wetter than after the wash/spin cycle. The only way of solving this is to replace th tree way water inlet valve. But make sure that the pump is working ok first and that there is nothing in the sump hose trap which is located underneath the washing machine out the bottom of the tub.
Good luck.................
Dec 28, 2008 | Hotpoint Washing Machines
Estate Dryer takes too long to dry load
Since you say the vent is clear, Make sure that the lint filter is cleared before each load. Make sure the door shuts close and is reasonably sealed. If the dryer draws air past the door, it is not fully drawing heat from the element or burner. Also make sure the washer is doing it's job in the spin cycle. It takes much longer to dry fabrics that are still soppy wet. You might try resetting the washer in the spin cycle to further evacuate the water from the clothes before placing in the dryer. See if that makes a difference. Maybe the washer spin is just being lazy. If it's a top loader it may have a loose belt causing the problem.
Dec 16, 2008 | Estate Dryers
Kenmore 90 Series, clothes wet after spin
First thing you need to check is the speed of the spin cycle. As long as you are not overloading the machine, it should spin the clothes pretty dry. the basket drive may need to be replaced. If it is spinning very fast, then check the drain hose, make sure the water is coming out nice and fast. If not you may have a water pump problem even lint clogged inside it.
Nov 29, 2007 | Kenmore 22422 Top Load Washer
Loud screaming sound during spin cycle
The screaming noise is probably from a dry bearing in the motor, it will probably come and go and shouldnt cause to much problem, they are supposed to be self lubricating but sometime they run dry.
Oct 18, 2007 | GE Spacemaker WSLP1100D Top Load Washer
Washer dryer is no longer drying
two things to check take rear half of cabinet off and check the dryer duct (lhs from front) is not blocked. this is very common check water is being taken in during dry - the water is used to condense steam from the drying clothes. easiest way to check this is to see that some water is being drained during the drying cycle. i assume that drain is operating ok
Jun 03, 2007 | Zanussi ZWD1270 Front Load Washer / Dryer
GE WWSE5200BWW Topload Problem
sounds like the motor needs replaced pretty common on this unit..
May 28, 2007 | GE WWSE5200B Top Load Washer
Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer Logo
122 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
puggy666
Level 1 Expert
freddyfox
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
