Question about Whirlpool Calypso GVW9959K Top Load Washer
My calypso stoped and FL flashes and will not cancel,
It flashes FL and will not cancel or go. even after I unplug it and try to push any cycle to wash. It was in the middle of a load.
  • ammndam Feb 17, 2009
    I have the same problem with my washer as well and I have tried everything.
  • 15,935 Answers
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
Error code FL flashes and my calypso washer keeps beeping. Won't start just shows the code.
FL error - Flood condition
"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display.
You coudl se this manual: Service_Manual_PDF
Hope this helps.
May 20, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Washer won't drain..like filter is clogged
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%@#$
Mar 27, 2010 | Kenmore Elite 21082
Machine stoped after wash cycle tub did not drain and reads F L kenmore elite calypso model #22064 100 type 170 cannot get it to start at all it keeps beeping and reads FL
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%#@$
Feb 09, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Fl code on kenmore calypso cannot clear
this is the fl code on a whirlpool calypso which is probably the same since kenmore is just a name,, whirlpool built the machine if u didnt know kenmore doesnt build anything they just put their name on things... (FL is a flood conditon.) FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
FL code washer not draining
“FL” (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the overfill switch is reset or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. Shut off the water
faucets to the inlet hoses if water continues to flow.
Here is the complete manual.
Jan 08, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso error code reads FL...
Press STOP/CANCEL to clear the display. http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Should you continue to have appliance issues or need parts or service advice, please don’t hesitate to contact us. We are at your service from 7 AM until 9 PM CST Mon – Sat!
Thanks, Ella :>)
Nov 08, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My kenmore elite calypso washing lights on the front panel will not light up.i push the choice i want then it reads FL and all it does is hum and beep.even when off it will beep and read FL.i will turn it...
Flood Condition:
Oct 15, 2009 | Kenmore Washing Machines
GOING NUTS WITH WASHER
FL Flood condition"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. You will need to unplug this unit for 5 minutes. if you continue to hear beeps and the (FL) appears once more after the shut down, you will need to replace the water level switch.
Press STOP/CANCEL to clear the display and unplug the unit for 5 minutes.
Apr 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Cycle Problem
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#%!^
Mar 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso wash motion washing machine FL code stuck
Calypso washers have been known to be problematic. In fact, there is a class action suit out there which could be beneficial to you: http://www.calypsosettlement.com/ According to Whirlpool FL stands for Flood Condition. Here is their explanation of it: ----- FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display. ----- Hope this helps.
Aug 07, 2006 | Whirlpool Calypso GVM9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
168 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
