Question about KitchenAid 24 in. KUDG25SH Built-in Dishwasher
Kitchedaid dishwaser child lock light is on
How do I turn off child lock light?
From my experience press the last function key and hold that should turn it off, if that doesn't work press the temp and hold or the energy save, the key is to hold it and try and see the last function key that was pressed.
Posted on Mar 17, 2009
The blue light and a red light under the glasses and plates signal is flashing and my dishwaser won't start.
does the door lock ?? if not try leaning against it when pressing the start button
Jan 21, 2015 | De Dietrich Dishwashers
Unlock child lock
On the Audi Q7, depending on country and options the child lock is either:
1. On the drivers armrest, near the window switches, there are 2 buttons with a little orange light and a picture of a little baby on them. Deselect both buttons to turn off the child locks.
-OR-
2. Open the passenger doors, there is a small keyhole on the inside of the door above the latch, use your key and turn it 90 degrees to turn off the child lock.
Hope that helps
Sep 24, 2013 | 2008 Audi Q7
Machine displyas CL. Why
It means the Child Lock feature which locks the controls is turned on. Look for the two console buttons, usually adjacent, with the lock and child symbols between them like the one shown below. Press and hold those buttons simultaneously until the CL light turns off to unlock the controls.
Mar 02, 2011 | LG WD-1045FH Front Load Washer
I have a problem with the remote control that is not working, I have taken it local technicians but nothing . My TV is in child lock so I need a remote for the tall big telefunken TV
Hi what you can do is to buy a universal remote control for this TV to remove the child lock. You can get that online or on any electronic shops in your area. Once done here is the instructions on how to remove the child lock using remote.
Look at the "Power" indicator light on the front of the television to check if it is blinking. When blinking, the child lock is enabled. You can also check by pressing the "Power" button on the television.
Point the remote control at the television and press one of the buttons on the number keypad. The "Power" indicator light will stop blinking, indicating the child lock is turned off.
Lock the television again by pressing and holding the "Power" button on the remote control until the indicator light starts blinking. It takes approximately three seconds before the light turns on. Thanks
Feb 01, 2011 | Televison & Video
Child proof lock light is on, cannot run the dishwasher
To turn off the Child Lock
Press and hold ENERGY SAVER DRY for 4 seconds. The
light turns off.
Apr 18, 2010 | KitchenAid 24 in. KUDM25SH Built-in...
I have model #KUDS24SEBL-l. The child lock light
Press and hold the "Energy Saver Dry" button for 5 seconds to turn the Child Lock on/off. I hope this helps you.
Oct 15, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Sony DAV DZ230 Child Lock
hello You can deactivate the buttons on the unit
(except for "/1) for preventing misoperation,
such as child mischief (child lock function).
When the child lock function is activated, the
buttons on the unit are locked and “ ” lights
up in the front panel display. (You can operate
the system by using the remote.)
Note
•When you operate the buttons on the unit while the
child lock function is on, “CHILD LOCK” appears in
1 Press SYSTEM MENU.
2 Press
X/x repeatedly until “CHILD
LOCK” appears in the front panel
display, then press or
c.
3 Press
X/x to select a setting.
The default setting is underlined.
• “OFF”: Child lock function off.
• “ON”: Child lock function on.
4 Press .
The setting is made.
5 Press SYSTEM MENU.
The system menu turns off.
Tip
• You can activate the child lock function by pressing
x for more than 5 seconds (“ ” lights up in the
front panel display).
To cancel, press x for more than 5 seconds so that
“ ” disappears from the front panel display.
Deactivating the Buttons
on the Unit good luck
shaun
Sep 12, 2009 | Audio Players & Recorders
Kenmore Dishwasher 665 15777990
It sounds like the child lock is on. Is the light on when the door is closed and nothing is pressed? If so hold the lock button until the light turns off. If you do not have a lock button, try the heated dry button or consult the manual to find out which button toggles the child lock.
Good luck.
Feb 21, 2009 | Kenmore Dishwashers
KitchenAid 24 in. KUDG25SH Built-in Dishwasher Logo
202 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
