Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Philips 55PW9363 need convergence grid dimensions
I want to tune in the green geometry of my 55PW9363. I know that a grid template is required. I'd like to make one, but don't know how to determine the measurements of the grid. Can anyone supply the measurements?
Thanks.
  • mailboxgrd_f Feb 15, 2009
    Good suggestion, very practical.
    I guess I am still interested in making the grid template, as much for the education as for the results.
    I had to replace the convergence amps and a couple of resistors because the red amp failed. After replacing the parts, I noticed that the green geometry is not "perfect," though it is not terrible. I'd like to tune the green in, then match the red and blue to it.
    Novelist:
  • 184 Answers
You may not need a template as long as the geometry has not been totally lost or corrupted. How is the image in red and blue? If any of the three convergence/CRTs has good geometry, you can align the others to it. You can simply cover over any CRT whose image you wish to block out while you are aligning the others.
Posted on Feb 15, 2009
What are the default geometry values for 480P and 1080i FULL modes?
If you have the model listed have fun----Geometry values are depicted in the Convergence section---the grid of GREEN lines determines geometry and red and blue are then adjusted to the Green.
Primitive: Set had at one time two overlays available--clear plastic you attached to screen to line the that Green grid up against---one for 480 and one for 1080.
Once the geometry is set (best possible) you must align convergence and save it in both the modes one at a time.
By current standards a Fred Flintstone system--but in its day a real pain as alignment can take many hours with the correct remote via the tech menu for convergence.
Apr 27, 2012 | Philips 60PW9363 60" Rear Projection...
I've repaired the convergence circuits on my Philips 60PP9202, but I need the convergence grid template to converge it properly. Where do I find one of these templates?
you can make your own out of plastic the info is in the service info for your model. If you email me a request for it I will email them to you. slinteriors@yahoo.com
Aug 23, 2011 | Philips 60PP9202 60" Rear Projection...
My Phillips 55PW9363 tv has a double image problem, how can i fix it?
Ur convergence is dead.Know to solders? Require changing 2 convergence ICS,and all the resistors.Tries Website Tv repair World.com,Tvrepairkits.com.for the convergence kit.Shop will cost U $300 for parts,and labors.
Jan 25, 2010 | Philips 55PW9363 55" Rear Projection...
No color adjustment
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Pioneer sd-643hd5 rear projection 64" tv has green geometry grid problems
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 25, 2008 | Pioneer SD-643HD5 64" Rear Projection...
Convergence
Touch-up Convergence adjustments Enter the Digital Convergence Mode (DCM) by entering 0-6-2-5-9-7-(Status or Index) on the Remote control. The following menu will appear: Select an active channel or Aux Input. A signal must be applied to the set when performing convergence. If any Customer Adjustments need to be made, the Menu button can be used to toggle between the Customer Menu and DCM. The MPOSD ADJUST is used to center the Customer Convergence grid. A highlighted cross will appear along with the Convergence alignment grid. The highlighted cross should be centered onto the center of the Convergence grid. To perform a Touch Up Convergence, highlight SELECTION and press the right cursor button on the remote. The following menu will appear: Selections STORE, RESTORE FACTORY, and RESTORE DEFAULT are not shown after selecting SELECTION. Press the cursor down button on the Remote for these selections to appear. RESTORE FACTORY loads Convergence defaults from the Factory Loaded section of the Convergence Memory IC. RESTORE DEFAULT loads Convergence defaults from the sets software. To perform a Touch-up Convergence: 1. Enter the Convergence Mode and select RED TO GREEN or BLUE TO GREEN. Do not select GREEN (Green Geometry) without placing a Template over the screen. To perform Green Geometry, refer to the Complete in-depth Convergence. 2. Use the Cursor buttons on the Remote to Navigate from one adjustment point to another. Press the Status or Index button on the Remote to select ADJUST. Use the cursor buttons on the Remote to adjust the Red to Green or Blue to Green. Press the Status or Index button again to navigate to the next adjustment location. 3. After Convergence alignments are complete, press the Menu button on the Remote to return to the SELECTION menu. 4. Highlight the STORE selection and press the right cursor key on the Remote to save changes. 5. Use the GREEN TO RED or GREEN TO BLUE selections to perform convergence when the Green CRT has been replaced.
Aug 18, 2007 | Philips 60P8342 60" Rear Projection...
Philips 55pw9363 factory default settings
Yes,there is almost always a way! you will need the CD ROM literature for your model--it will list the normal range of settings. My reserved question is what caused the overscan and why did you decide to go in the servicer menu to "fix" the problem???? You may have some convergence issue,also.
Oct 17, 2006 | Philips 55PW9363 55" Rear Projection...
Philips 55PW9363 Service Menu - Geometry settings help, picture shifting at times???
If you are doing the labor you should wait and replace the new part and while you are at it check for loose conections in the horizontal drive circuit since all symptoms might be related,but they are doing all the work they should address all the problems you have,settings in the service menu dont just change on their own and are adjusted only when a major comp[onent has been change like the convergence.
Oct 03, 2006 | Philips 55PW9363 55" Rear Projection...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
208 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
