Question about Mr. Heater Mr Heater Portable Buddy Propane Heater
Propane convection heater won't maintain full flame
Model is Mr Heater mh80cv.
Pilot lights fine. Turning the ball valve for the main burner produces only a small yellow flame as if the propane tank were empty. That isn't the case, as I've tried two different full tanks.
  • Anonymous Mar 15, 2014
    pilot flame is coming on and heating the themo coupler
    The main flame will not engage.
    President:
  • 1,902 Answers
Seems like the valve is not opening up fully or the adjustment is out of adjustment. Try adjusting the flame.
Posted on Feb 15, 2009
Pilot light blows out while heater gets hot. Mr Heater 30000 but gentles propane wall heater.
I would clean the pilot assembly first before replacing parts. Alllot of times the pilot will stay lit with just the pilot on but will go out with the main burner on. The reason is that with the main burner on there is a draft that pulls the pilot flame away from the thermocouple.
Dec 31, 2016 | Heating & Cooling
My pilot stays on on my propane furnace but will not light up
The Little Giant units use a Unitrol gas valve very similar to a water heater in the home. #1,urn the Unitrol gas valve to the "PILOT" position to ignite the pilot. Depress the plunger and hold it down then push the spark igniter button until you can see the pilot flame ignite.
You have a lit pilot so this is not a problem for you.
The pilot light stays on continuously by design.
Once the pilot flame is established, you then turn the on/off/pilot valve to the "ON" position and set the thermostat to the desired temperature range., it should then fire its main burner until the desired temperature is reached. Once the temperature is reached, the main burner will shut off and the heater will go into a standby mode with the pilot flame still burning.
If you have turned the pilot valve to on and set the temperature high, it should come on, if not a new gas valve is required, they can be very difficult to replace due to rust.and most cases require a new unit,
Mar 19, 2015 | Unitrol Propane Heater Valve - Little...
Pilot won't stay on
Burners don't have anything to do with the problem of pilot not lighting. Is the problem that flame will not 'stay' lit? Or you can't even get a flame to ignite? If former: possible bad pilot generator or bad gas valve. If latter, possible bad gas valve or no fuel to ignite.
Dec 23, 2012 | Hayward H Series Pool & Spa Heater 400k...
My mr heater won't stay running
No pilot in this unit.
Check the thermocouple and its connections.
The thermocouple is the device that has the copper cable connecting it to the vave unit. It leads up into where the burner can "heat it up". This indicates to the controll valve that the gas is actually burning and keeps the valve open.
Jan 06, 2010 | Mr. Heater Model MH12TS - Single Tank-top...
Propane patio heater ignition problem
I would change the thermocouple and here is why:
The thermocouple is the pilot's, well, co-pilot! It is the electronic device that senses if the pilot flame is hot enough to sustain burning the gas fuel from the burner. If the thermocouple thinks it's safe, then it keeps open the main gas valve located in the pilot assembly. If the thermocouple does not sense enough heat from the pilot flame (such as when the pilot is out), then the thermocouple shuts off the gas valve to the burners.
How the Thermocouple Works
So what is this thing and how does it work? Well the thermocouple (technically called a thermocouple junction) is a device that contains two metal wires welded at the ends and placed inside a protective metal case. The thermocouple sensor is found at the business end of the pilot flame and is designed to be placed in the hottest part of the flame. The other end is connected to the pilot valve body. As the thermocouple heats up, it produces a small amount of electricity and when it gets hot enough from the pilot, send a signal to open the gas valve by using a solenoid operated by a 24 volt transformer. The thermocouple calls the shots, and by converting heat to an electrical signal, it allows the gas valve to open or close. Once the gas valve is open, gas is then constantly supplied to the pilot and as required for the gas burners (as called for by the thermostat). If the pilot goes out, then the thermocouple gets cold and produces no electric signal to open the gas valve's solenoid and the gas valve shuts off the gas supply to the pilot and burners
May 27, 2009 | Endless Summer Blue Rhino 235000...
Heating & Cooling Logo
621 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
