Hi: I just bought a DVD burner last week, and I'm trying to produce backups with dvdshrink for my Pioneer DV-545. I've got hold of a sampler pack of DVD-Rs from blankdiscshop.co.uk, and also some Pcworld PackardBell 1x DVD-RWs. Basically, I'm having a lot of difficulty. Pretty much *anything* works on my other player (a ??50 Logix from Safeway or somewhere), but the Pioneer seems to be very finnicky. Is there anyone out there with a DV-545 who can recommend a brand of DVD-Rs which might work better? (Also, would DVD+Rs work? I haven't tried that yet.)
Thanks for the info Roy. I've solved the problem now, and it *wasn't* the disks. I don't know how well known this stuff is, or how widely applicable this would be, but just in case, here it is. PC setup: Win2K, BTC DVD Dual drive DVD+/- R/RW(DRW 1004IM), Nero 6.3.0.3 DVDshrink 3.1.4. The players are a Pioneer DV-545 and a Logix 3300D.
DVD-R or -RW: all the disks I tried played on the Logix, with various mild blocky aberations. All were unwatchable on the Pioneer (skipping, freezing etc, or failed to recognise).
DVD+RW: perfect on both machines.
I then installed the Adaptec ASPI layer (#), and it fixed everything. All formats of disk, and every brand I've tried, now play perfectly on both players. I'm guessing that the lack of ASPI was allowing some kind of encrapulation of the DVDs during the write, and the error correction in the cheap Logix player was better than the Pioneer. It's also worth pointing out that *any* disk written in data mode (straight or packet mode - pre ASPI) was fine, and all of the movies (pre ASPI) played fine with PowerDVD. When I deinstalled ASPI as an experiment, the symptoms returned.
AIUI, Win98 and ME come with ASPI built in. I'm not sure about XP. Maybe I should have installed the burner in my Linux box.
Ken.
Was this helpful?
Yes
No
Solution #2
posted on Aug 01, 2007
Rachel007 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
I had a terrible time with Princo, and now exclusively use Verbatim DVD-R x2 and recently x4 (written at 2x in Pioneer 104 drive using Nero 6.3.0.2 from files authored using Ulead Video Studio). I get almost 100% success in Pioneer 545 and 656 players, plus assorted anonymous computer DVD readers. At GBP 1.20 in bulk it doesn't seem worth the risk of trying any more cheapos. I buy the ink-jet printable style even though I only write on them because the coating over the data is tougher.
Roy -- Roy Battell. To use this address remove the digits included to remove Spam ... Mail: 666.co.uk
I have a PD560 portable dvd player that I recieved from Direct TV lost manual, seems like I had to...
(More)
I have a PD560 portable dvd player that I recieved from Direct TV lost manual, seems like I had to connect to TV to program before it would work ? It powers up but won't play, never been used, how can I get it started? does it need to be programmed?
My DV-555k used to work well, but now it always shows "NO DISC" sign after loading a...
(More)
My DV-555k used to work well, but now it always shows "NO DISC" sign after loading a DVD/VCD, so it won't play the disc. It also damages DVDs & VCDs so they can be played again. There would be circular lines/ scratches on the surface of the disc after it's been played
