No sync signal hitachi 43hds69 hdmi cable from sony blu ray to any hdmi input on tv. correct input selected. NO SYNC SIGNAL then tv goes to power saving mode.
  • Billy Bauer May 11, 2010
    Make sure you've selected all the correct settings in the blue-ray disc player. If you have the output set to component or so that the output signal is analog rather than digital. Are you able to view the menu from the disc player or play movies if you select another input type? Does a 480I input function?
    michtech
SOURCE: Connecting Magnavox NB500MG9 Blu-ray player
could be the hdmi is shot. try unpluuging the unit from the wall for a few hours and try again
Posted on May 10, 2009
premtech
  • 934 Answers
SOURCE: Hitachi TV 42hdt51
Might be the digital board, which on this unit you're in luck, easy to diagnose. The digital board has a group of led lights on it D302, D303, D304, D305, D306 if when you attempt to power up and of these begin flashing or changing colors it's likely digital board needs to be replaced...
If any of this sounds to foreign get a pro on this, you can mess this unit up in the blink of an eye...
Bill
Posted on Nov 20, 2007
SOURCE: problems using HDMI
I've had a problem with the HDMI connector, had it replaced twice while my VPL-HS60 was under warranty. This connector seems very fragile, the first time I was not getting any signal from HDMI, so the repair shop ordered a new connector and replaced it, a couple of days after the it was not working again and found that they had to solder it back on the board. If you're not getting a signal from HDMI anymore that could be your problem.
Posted on May 21, 2008
jerryg50
  • 1667 Answers
SOURCE: No connection/ no signal
Either the new BlueRay player is defective, the HDMI port on the player is defective, or the port on your set is defective.
Try connecting it with component RGB/AV cables, or S-Video/AV cables and see if everything works. If so, then you know that it is either the port on the BlueRay, or the port on the TV set.
To test the HDMI port on your TV, you will need another HDMI device to try.
Jerry G.
Posted on Sep 01, 2008
Drew_1
  • 10 Answers
SOURCE: Screen flicker when selecting Blu-Ray player w/ HDMI-1 selected.
Something to remember is that most HDMI setups on TV's have what is called a DVI/HDMI port, I would suggest not using anything on that port that isnot converted from DVI to HDMI. I bet if you look, that HDMI 1 on yours....
Posted on Feb 10, 2009
How do I hook-up Netflix through a Sony Blu-Ray player and a LG television
If your Sony Blu-Ray player and LG TV are recent models, each should have an HDMI cable connection. HDMI is an method to connect your digital video and audio devices with just a single combined cable. In the case of your LG TV, using an HDMI cable will allow you to send the HD video signal to your TV's screen, and allow you to hear the sound through the TV's speakers.
Your LG TV may have multiple HDMI connectors, to allow other devices to send signals to your TV, such as a cable box or satellite box or digital video recorder (DVR). Your Sony Blu-Ray player will usually have just a single HDMI connector.
Purchase an HDMI cable from your local electronics store. There are different versions of the HDMI specification, and you should get a cable that you can verify is certified for the HDMI version 1.4 specification.
Plug one end of the HDMI cable into the Blu-Ray player, and the other end into one of the HDMI connectors on the TV, noting which one you selected.
When you turn on your Sony Blu-Ray and your LG TV, you should use the remote for the LG TV to select the input source. Your LG remote should allow you to select the HDMI input connector you used, at which point you should see the display of a DVD playing on the Blu-Ray player. If you cannot hear the sound, use the LG remote to increase the TV volume.
Mar 02, 2015 | Netflix
Vizio vbr220 says no signal
Ok. I know this is rudimentary but did you make sure that your tv input is on hdmi? Also you may need to go to the menu on the player and see if there is a output selection. Check to see how many input hdmi your tv has and check each one to see if that helps. Also check with different hdmi cables because sometimes it is that.
Jun 26, 2014 | Vizio VBR220 Blu-Ray Player
Samsung hitachi sync out of range
take the blue ray disk out, turn your blue ray on and connect to a tv monitor, go to menu, and for hdmi option select 720p then reconnect your hdmi cable to the projector, it should come on, go back to menu, and match the input of the projector to the right type hdmi output from your blu-ray.
there is nothing wrong with your projector.
tony
Feb 20, 2013 | Hitachi Office Equipment & Supplies
I just got the Toshib 46rv530u and can't figure out how to get it to change video to 1080p
hi,
1080p full hd video can obtain only through hdmi. for that u need a full hd blue ray player or full hd sat receiver . the tv automatically changed to full hd according to the input connecting to it .go to hdmi setting and check whether hdmi connectivity is ON. also check the hdmi setup of ur input device.
ok
Dec 16, 2010 | Toshiba REGZA 46RV530U LCD TV
I have a Playstation 3/blu ray player and I don't know how to get hi def video on a samsung hln467w
Your TV only has a DVI input, not an HDMI which PS3 has as an output. You can buy a HDMI to DVI adapter and connect the HDMI out of the PS3 to the DVI input of the TV. To get the true HighDef video you need a HDMI input on the TV to enjoy the full capacity of the Blu ray capabilities of the PS3. DVI came out before the HDMI standard and your picture will look good but not like HDMI. I have the same problem with my samsung 65 inch. I Bought the wrong technology. I hope this helps and good luck!
Nov 07, 2009 | Samsung HLN467W 46" Rear Projection HDTV
PS3 not working on 42'' JVC via HDMI cable port
I have the PS3 and this TV and it works....Try this.
1. Turn ON TV
2. Connect HDMI from TV to PS3
3. Select the correct HDMI input on the TV for the PS3(important)
4.Turn OFF PS3 if it is ON.
5. hold [I/O] Power button on PS3
6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
7. Configure the HDMI output for the PS3
Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
Mar 24, 2009 | Sony Playstation 3 40GB System Console
Jerry G.
Aug 13, 2008 | Sony BDP-S300 Blu-Ray Disc Player
No hdmi signal
hold down your playstation button for a few moments and it will automatically sync to the tv at optimal settings. And thatz wut it doobi
Nov 20, 2007 | Hitachi 42HDS69 42 in. Plasma Television
Televison & Video Logo
949 people viewed this question
Top Televison & Video Experts
Electro Med Services...
