Question about Nintendo DS Lite Console
Fell in water
My DS fell in water 3 mounts ago what do i do
  • Anonymous Feb 16, 2009
    my ds fell in water
  • Kevin Shafer
    Kevin Shafer May 11, 2010
    Buy a new one
  • 3 Answers
Well - Your DS is very likely dead at this point. DO NOT "Just Turn It On to Check" This will almost certainly kill it.
If you have some basic electrical & mechanical skill, you could take it apart and have a look. Here is the general procedure for electronics that get wet:
AS SOON AS POSSIBLE (like immediately) after it gets wet, turn off the device and remove the battery. If it has an internal battery, when you get it open, disconnect the battery immediately.
You will be looking for:
Corrosion
Short-Circuit Burns
Remaining Water/Moisture
If you have identified any corrosion or burns, best thing would be to chuck it.
If there is no visible damage, then pat dry any wet/moist parts. Let the unit sit open in a warm, dry spot for 24h to fully dry.
Reassemble without turning on.
Charge battery, or put in fresh batteries.
Turn on & hope for the best.
In your case, I would do the above, then with a multimeter - check the battery voltage. Then charge the battery for a few hours and check the battery to see if the voltage has increased. If so, you are getting a charge and the unit should power up if it has no damage.
Hope this helps, but really, it's probably dead. You can also find a local firm who fixes water damaged electronics & cellphones to see if they can help you out.
Cheers
Posted on Feb 15, 2009
Nintendo DS LITE fell on water couple years ago
The unit has been damaged beyond repair, one long shot, remove power and the back cover, get a tooth brush and rubbing alcohol, clean main board and remove all white spots caused by the residual of water left behind allow several minutes for the alcohol to evaporate and try to power up.
Mar 14, 2013 | Video Game Consoles & Games
Nintendo ds lite fell in water
Let it dry for a week it will be fine as long as u don't turn it on. The screen mite have water damige but other than that it will be fine. If it starts having problems reading games get a alcohol wipe and rap it around the game the insert game then eject. Do that ten or fifteen times or till it plays. All that is is carotion.
Jan 07, 2012 | Nintendo DS Lite Console
L button not working
I had the same problem but there are ways to fix it..... sorta. But 1st what might of happened.
1.Water went in through the mic or hit the L button.
2.Your DS fell and the L button broke.
Now to fix it sorta you have to options and I never tried both.
1.Contact the DS creators and see if they can or will fix it.
2.Get a new DS.
Dec 28, 2010 | Nintendo DS Console
A couple of months ago I dropped my Nintendo d.s in water. Recently when i tried to charge it the light turns on but when i try to turn on the system it won't work. How can I fix it?
Open the battery panel, remove the stylus, as well as any other removable covers you can. Blow dry the device for about 30 minutes focusing on any external holes which may vent hot air internally. Finally fill a bowl with dry white rice and submerge the DS in the bowl overnight. If you haven't burned it out by trying to use it or corroded it in the time since it fell. This will draw all the water out.
Jun 17, 2010 | Nintendo DS Lite Console
Wet G1 Tmobile htc fell in water a while ago
Don't turn it on until it's dry again.
Maybe it could work again.
If not, you'll need to take to a cell phone fix place.
Jun 14, 2010 | HTC G1
I've dropped my DS Lite in water. How can I fix
if it was a long time ago, then get a new battery if it was recently like minutes ago then put it in a bowl of rice and have it covered in rice and take out battery
Nov 07, 2009 | Nintendo DS Lite
My DS has fell into the tolit.
DO NOT try to turn it back on or charge it. Instead do the following:
- Shake out as much water as you can and dry it off as best you can.
- Get a tupperware or other sealing container at least three times the size of your DS and fill it about half-full with rice.
- Put the DS in the rice. Might be an idea to wrap it loosely in paper towel to avoid getting rice dust in it.
- Leave it for a few days to dry out. Every 12hr or so, remove the DS and shake the rice around a bit.
Works for cell phones and other gear too.
Nov 05, 2009 | Nintendo DS Lite Console
My ds fell in water
Try, if you can, opening it and hairdrying it on a low heat. Leave it in your airing cuboard for about an hour or so and then put the parts back together and try it again.
Jan 28, 2009 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
130 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
