Question about ProMax 197NC Bmx V Type Brake Set, Rear, 95mm Arms
Brake adjustment promax aluminum linear pull
New Fuji Odessa1 Assembled bike but rear brakes always on. Please advise brake adjustment method. Also front brakes left side(seated on bike) has cable going to it. right side brake works. left not. loosen nut and tighten cable I assume.''Thanks'' Bill DeCastro
  • Anonymous Apr 09, 2009
    I've got the same problem it's been "buggin" me for weeks
  • 469 Answers
Assuming the wheel is centered in the frame and all is working well, the pressure springs need to be adjusted. using the pressure screws (small screw sticking out of thr side of the brake) you can adjust the return pressure of each side. Loosen the screw on the side that is moving a quarter turn, tighten the screw on the side that does not move. squeeze the brake lever, check operation, continue until the brakes work equally.
Posted on Apr 13, 2009
My brakes work when sitting still, but will not stop bicycle in motion/under power
There are multiple possible reasons:
1. Brake caliper is not adjusted so pads are within 1/8" or so of rim (rim should be straight enough to allow that).
2. Brake pads are old and hardened.
3. Too much friction in brake cable and housing
4. Brake cable housing is too long, allowing too much flex.
5. If brake levers have been replaced wrong levers were installed.
p.a. It is helpful to know whether a problem is new, has developed gradually over time, or has always been there, and if any maintenance or event occurred just before the problem began.
Jan 30, 2018 | ProMax 197NC Bmx V Type Brake Set, Rear,...
Brake is sticking. how do you fix. is rear brake
The web is rich in resources for 'how to' do just about anything on a bicycle.
"adjust rear brake on bicycle"
One resource...
http://www.parktool.com/blog/repair-help/linear-pull-brake-service-v-brake-type
Aug 23, 2011 | Mongoose Spear 26 Inch Men's Bike
When I take my daughters front wheel off her Diamondback bike I need to reajust the front break. How can this be avoided?
By always placing the wheel firmly into the fork's dropouts and then then tightening the quick release. Adjust the brake centering and it should always stay the same UNLESS the brake centering itself is moving every time you disconnect the brake to remove the wheel. Then it gets complicated.
Look here:
http://parktool.com/repair/byregion.asp?catid=14
Aug 02, 2010 | ProMax 197NC Bmx V Type Brake Set, Rear,...
Men Mountain Bike (26"): How to adjust tention on the rear brakes...
Your bike likely has linear pull brakes so you will need to a. loosen the pinch bolt that holds the brake cable to the noodle (down at the wheel). You then pinch the brake in towards the rim with your hand until it's almost touching and then retighten the cable. You can then do some fine adjustment on how close the brake pads are the rim with the adjusting nuts up at the levers.
May 18, 2010 | Huffy Men Mountain Bike (26")
Back tire replacement
Before doing anything else, loosen the rear wheel and make sure the axle is fully seated in the dropouts, then tighten it. The brake should not be able to contact the tire, only the rim.
Not sure from what is here what kind of bike and brand of brakes or derailleurs you have.
You could always Google it. There are lots of how-to's with illustrations out there. For example, "shimano rear brake adjustment" finds a whole bunch of advise.
Front guard???
Feb 20, 2010 | Fuji Road Bike Saddle/embroidery/chromoly...
Brake assembly help!!!!!!!!!
1. the other end of the brake cable with the stopper,insert to the handle brakes.there is a guided slot for it.
2.go to the brake assembly.loosen the nut and find the small hole at the shaft of the flat head bolt.insert the cable.
3. adjust the brake.pull the cable until it is in the best tension,slowly rotate the brake nut to keep the cable in place.
4. try to grip the brakes and try pushing the bike while testing the tires if it skid.try to ride it to so that your weight will be calculated with the brakes.
5. adjust the brakes by repeating the above instruction until desired brake adjustment is achieved.
May 31, 2009 | Huffy So Sweet Girls 20-Inch Bike
Rear Disc brake is rubbingke
I had the same problem with my Hope mono-mini.
I took it into a shop and the guy showed my ruffly what to do.
On the side that the disk is rubbing you need to put a spacer on the bolt between the brake mount and the bike's mount.
If done correctly (or understood what i meant) it will pull the pad away from the disk a little bit and it will stop rubbing.
Hope it helps
Ed
Feb 01, 2009 | RTO Hope Tech X2 Mtb Mountain Bike Disc...
ProMax 197NC Bmx V Type Brake Set, Rear, 95mm Arms Logo
2,522 people viewed this question
Top ProMax Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a ProMax Cycling Expert? Answer questions, earn points and help others
