Question about Canon PIXMA MP830 All-In-One InkJet Printer
Paper jams When i go to print the printer starts and when it get to the rollers it jams the paper into bunch up paper and then of cource it jams
  • petunia729 Feb 15, 2009
    Thanks for the infor I will try that.
  • 77 Answers
You need to order a set of pickup rollers for your printer and replace them. This is usually a fairly easy job and usually pretty cheap for parts.
Posted on Feb 15, 2009
When printing color the paper jams. This does not happen when printing black. How do I stop it from jamming when printing color.
Is that true for both print and copy job ?
Where does the jam happen ?
I am thinking if it is at the paper pickup roller area just as the job starts to print and not midway while printing, check the paper quality; dirty pickup roller; clean cork pad and try job from another tray
Sep 21, 2016 | Konica Minolta magicolor 1680MF -...
My canon MP287 cant print.black when photocopy. The paper also started to jam so it cant print. what will I do?
When there is a paper jamb make sure the whole piece of paper is removed because any tiny pieces of paper that are left behind will cause further paper jambs.
If the paper does not feed through the printer correctly then the rubber rollers are dirty/sticky. Clean the rollers with methylated spirits to stop the paper from sticking to the rollers.
Mar 02, 2013 | Office Equipment & Supplies
Paper jams in heater
Hello
An overheated fuser is one of the most common causes of a paper jam. When large loads of print jobs are pushed through a printer, the fuser slowly starts to warm up. As the fuser warms up, the heat causes the corners of the printer paper to bend. The hotter the fuser gets, the more the paper bends. Eventually the paper bends so much that it causes the paper to get stuck in the fuser, causing a jam.
If you cannot find any other reason for a continuous printer jam, the problem may be the roller. A cracked roller can easily grab a piece of paper and get it caught. A glazed-over or dirty roller can also cause the paper to get caught on the roller and jam the printer. If the roller is cracked or glazed, you may need to call your print technician or replace the roller.
THANK YOU FOR VISITING FIXYA
Mar 03, 2011 | Ricoh Aficio CL7000DTL Laser Printer
When we hit the print button to print a page the paper will not feed into the body of the printer and the sign flashes for us to remove jammed paper and hit start button, when we do this it just keeps...
Paper jams
85% of paper jams are caused by worn rollers Chances are, when your tech arrives, he'll tell you that the jams were caused by worn feed rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
MP150 reset:
Feb 11, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Paper keeps jaming in paper tray
Try to give several print outs by placing paper one by one (Not a bunch of paper ) in Paper Tray. if it prints perfectly prints then your should use higher quality papers with no scrach on paper. and after that still issue of paper jam then
Your printer need to to be serviced by technician. It looks like Paper Pressure Roller of Printer is damaged.
Mar 22, 2010 | Kyocera Mita LaserPrinter FS-1018MFP...
Hp2200D Won't print - "jam" light comes on - but no jam
Have you cleaned the feed roller? If it's dirty it'll spin but won't pick up any paper. Look at the paper after a "jam." Can you see any black roller marks on it? That's a sure sign of a dirty roller. If you suspect a dirty roller, clean it with a little alcohol on a cloth.
Mar 10, 2009 | HP LaserJet 2200D Printer
Paper jam
This video explains how to resolve a recurring paper jam on your product. It sounds like the rollers on the rear access door may not be working properly and are making jamming the paper as it starts to feed up into the printer? Check the rollers on your rear access door and see if they have some give in them and roll freely.
Sep 27, 2008 | HP Photosmart C7180 All-In-One InkJet...
Printer won't accept paper
What jam code are you getting. I suspect a registration clutch issue. But there should be a code associated with the jam.
I would like to look that up and narrow it down for you.
Mar 13, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Paper jam in tray 2
the most common problem for a paper jam in tray 2 is that either the pick up rollers and separation pads are worn or that there is something stuck to the rollers that transfer the paper up through to trat 1.(most commonly from if people have been printing on stickers/labels) just eyeball it to see if anything looks to be stook and try wiping it off. DO NOT SCRATCH IT OFF as this will only make things worse!!!
Sep 05, 2007 | Office Equipment & Supplies
Canon PIXMA MP830 All-In-One InkJet Printer Logo
41 people viewed this question
old marine
old marine
Corne Viljoen
