Question about KitchenAid Ovens
Wiring in oven
I have a kitchenaid wall oven/convection that I need to re-install. It has 6 wires in the wiring harness, the standard 4 wires are straight forward but where do the extra 2 wires (black with white stripe and brown wire) get connected to?
  • 979 Answers
If you are saying you are re installing this oven, then what did the 2 other wires go to before?
Posted on Feb 15, 2009
I need to replace my 1987 approx. Chef wall oven Balmain fan forced and grill. Does anyone know the cut out dimensions. I want to buy anew oven that will fit the existing opening. Thanks
when you buy the ovens replacement
instructions are given in the paper work how to adjust the cavity to suit
there will have to be an air gap on back and sides of the new oven
you should call an electrician to wire in the new oven
to check , even replace the 1987 wiring and connections
if needed to meet the 2016 house wiring standards
you will need
tape measure
pencils
a square
straight edge
reversible hand drill and bits
two levels .... for inside the cavity to level oven
approx a 15 inch .one 6 inch
a hand saw or circular saw
, i found a jigsaw helpful
self tapping screws different lengths
as per the oven fitting requirements
you can use any paint to finish the job
white board or MDF board is ok
some extras strips of timber to level the new oven
maybe required
if imperial was used for the cavity of the old oven
metric might be for the new oven
some DIY about wall oven installs are found on youtube
Oct 14, 2016 | Ovens
F2E5 showed on the display and the oven turned off
The F2 E5 error indicates that there is a fault between the key pad and the control unit. (The wiring is giving an "open" fault.)
Press Cancel and wait 60 seconds. If the error recurs, you need to get behind the keypad and check that the wiring is securely connected to the keypad and the central control unit. Inspect the wires for any breaks. Check each conductor for continuity on each side of the wiring harness, if possible. Reconnect the wiring and press Cancel again. If the error recurs after 60 seconds, you'll need to replace the keypad or the keypad and control unit. (KitchenAid provides the keypad and control unit as a single assembly for some models.)
If your oven is still under warranty, contact KitchenAid for service.
I hope this helps. Please add a comment with the model number of your oven for details on the appropriate replacement parts.
Feb 17, 2015 | KitchenAid Ovens
Oven keypad is completely black but inside oven lights work. does keypad have a separate fuse?
Yes. Many of these have a display thermal fuse that is part of the wiring harness that connects to the board... it should have continuity. WP4451042. Almost all models have what is called the "oven shut-down thermal fuse" which is on the back of the machine ( you have to pull it out of the wall and remove the back panel) and looks like this KitchenAid Range Stove Oven Thermal Fuse WP9759242
Dec 06, 2014 | KitchenAid KEBC208 Electric Double Oven
Vulcan convection oven model SG4d-1 will not ignite burners
Gas does not ignite. No spark. No Ignition light is not ON.
1. Shorted electrode on igniter/flame sense.
2. Igniter cable (high voltage) OPEN.
3. Heat relay malfunction.
4. Centrifugal switch in blower motor inoperative.
5. Transformer inoperative.
6. High limit thermostat open.
7. Interconnecting wiring malfunction.
8. Ignition module malfunction.
Sparks but gas does not ignite.
1. Gas solenoid valve off or inoperative.
2. Manual gas valve closed.
3. Gas supply OFF or insufficient gas pressure.
4. Inerconnecting wiring malfunction.
5. Igniton module malfunction.
Feb 23, 2010 | Vulcan Convection Oven - VC44EC-208-1
Shows F2 E1 no buttons work?
Sounds like a shorted keypad error(F2-E0). I do not see a F2-E1 error listed. You will need to pull the top front panel off and verify that the keypad wiring harness is fully seated. You might want to try removing the harness then re-plugging it back in. Inspect the wiring for shorts(exposed wires). And make sure the appliance is unplugged from the electrical outlet before attempting any repairs.
Jan 16, 2010 | KitchenAid KEBC107 Electric Single Oven
I HAVE A W136C Jenn-Air wall oven and would like a wiring connection diagram. Icant figure where to connect the orange wire
Look for schmatic behind control panel, open oven door and remove 4 screws that hold upper face panel down, panel should slide up 1/2' or so and lift off.
Sep 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
F9 error code while using the convection baking function
This is a lock switch error code. Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. If the switch cannot be re adjusted, it must be replaced.
Jul 30, 2009 | GE Ovens
Replacing frigidaire wall oven door light/fan switch
Ask the Frigidaire Agent to go talk to a technician and get the answer to your problem. Technicians are available to the Agents. 1 (800) 374-4432
May 14, 2009 | Electrolux 30" Built-In Single Electric...
Electrical intallation
check the wattage from the rating plate and that will tell you
Sep 14, 2008 | AEG B5741-4 Electric Single Oven
Kitchenaid Convection oven
F5
E0
E1
DOOR AND LATCH SWITCH DO NOT AGREE
DOOR LATCH NOT OPERATING.
PROCEDURE: Before proceeding, press OFF, OFF, START to enter
the Diagnostic mode and verify the error codes.
TO VERIFY DOOR SWITCH:
A. While in diagnostics, open the oven door. The second digit on the clock display
should toggle between “1” and “0” as the door opens and closes. When door is
closed display should show “1”, when the door is open display should show “0”.
If the second digit on the clock display did not toggle, go to step B.
If the digit did not toggle after replacing the door switch, go to step D.
If the digit did not toggle after replacing the door switch harness, go to step F.
B. Unplug oven or disconnect power.
C. Replace door switch. (If door switch is integral to the door latch motor
assembly, replace the entire door/latch motor assembly). Go to step H.
D. Unplug oven or disconnect power.
E. Check the integrity of the harness wires and connections between the
appliance manager and the door/latch assembly. Ensure there are no shorted
or pinched wires.
If the wiring harness is pinched or damaged, replace the door switch harness.
Go to step H.
If wiring harness is good, go to step H.
F. Unplug oven or disconnect power.
G. Replace appliance manager. Go to step H.
H. Replace all parts and panels before operating.
I. Plug in oven or reconnect power.
J. Press OFF, OFF, START to reenter the Diagnostic mode and complete checks.
Repeat step A.try this lighting may have knocked either the door switch or latch motor out
Mar 30, 2008 | KitchenAid KEWD105HSS Oven
Ovens Logo
137 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
