Question about Genius Twin Wheel F1
I have genius twin wheel f1 Calibration problem
When i step fully on the gas it doesnt give me full acceleration . and when calibration the small point doesnt go to the Top ..it stays before the top when i step full on the gas pedal .. help me plz am bored :S:S
Incline position stuck fully raised.
lube the rack and pinion, and adjust the small POT. see the diagram attached.However RUN the software calibration for easy troubleshooting and fix it. God bless you
The Steps for Newer Style Console Calibration
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
3955270e-0ffb-4d9b-b5ae-29087a8d6aec.gif3955270e-0ffb-4d9b-b5ae-29087a8d6aec.gif3955270e-0ffb-4d9b-b5ae-29087a8d6aec.gif3955270e-0ffb-4d9b-b5ae-29087a8d6aec.gif3955270e-0ffb-4d9b-b5ae-29087a8d6aec.gif3955270e-0ffb-4d9b-b5ae-29087a8d6aec.gif3955270e-0ffb-4d9b-b5ae-29087a8d6aec.gif3955270e-0ffb-4d9b-b5ae-29087a8d6aec.gif
Apr 04, 2013 | Exercise & Fitness
Tip
How to calibrate the MSA Altair 4
Want to calibrate the MSA Altair 4 Gas Detector or MSA Altair 4X? Here's how:
1. Turn the MSA Altair 4 and MSA Altair 4X on in normal reading mode. Do this by pressing and holding the center button.
2. Once the MSA Altair 4 and MSA Altair 4X is in normal reading mode, you need to send it into calibration mode. Do this by pressing and holding right beeps at you and the screen asks you to zero the monitor (sensor refresh on the MSA Altair 4X).
3. Now that the screen is asking for confirmation, press the center button once to confirm. This will send the monitor into zeroing mode. Now is a good time to set the monitor down, and grab your calibration gas, regulator, and calibration adapter.
4. Open the valve on your regulator. This is a very important step so you do not ruin your calibration gas cylinder. Now screw it in to your calibration gas cylinder. Close the regulator once you hear gas spewing out of it. This is the signal to know your regulator is good to close. Continue screwing in the regulator until it stops. Do not overturn it.
5. Attach the tubing to the hose barb on your regulator. Make sure the tubing is also connected to your calibration adapter.
6. Wait for the screen to come up asking for you to apply calibration gas. Once this screen comes up, press the center button again to confirm. Screw the calibration adapter in to your gas detector. Once it is screwed on, turn on your gas.
7. Make sure your calibration gas values on the screen match what is on your calibration gas cylinder!
8. Once the calibration procedure is completed, turn your gas off and remove the calibration adapter from the MSA Altair 4 or MSA Altair 4X. The screen will go back to normal reading mode within a few seconds.
9. Congratulations! You have officially calibrated your MSA Altair 4 or MSA Altair 4X gas monitor. Make sure to record these readings in your calibration log!
If you come up with an error, the most likely bet is a bad oxygen sensor, but it could be a number of other issues. Feel free to email me.
on Sep 29, 2014 | MSA Altair 4 Multigas Detectors - 10085989
P1589 trouble code
The ECM memory should have been rest due to which the calibration of the accelerator pedal has been erased.
Use a scanning tool and calibrate deceleration sensor.
You can do the calibration by clicking Engine and ECT > > special function > > and then click "decleration 0 point calibration" while you do that make sure that your car IGN switch is "ON" and your gear shift is on "P"
Jul 24, 2012 | 2007 Toyota Camry
Kettler atlantis 51L error!!!! what is the solutions?
I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1 Stand on the side rails of the treadmill for safety purposes. Remove the safety key. Step 2 Press and hold the two incline buttons. The incline buttons are blue and on the left side of the display. Hold the up and down button simultaneously. Release the buttons when the display reads "Calibration."
Step 3 Press the green start button located either above or below the large, red stop button (depending on your model). Stay on the side rails as the treadmill belt begins to move. Both the speed and incline should go through their full range from lowest to highest, and then back down again.
Step 4 Repeat the process if the display does not read "Calibration Successful." Contact the business where you purchased your treadmill if repeating the calibration process does not result in a successful calibration.
Aug 17, 2011 | Exercise & Fitness
My touchscreen doesnt work on my Ikasu 8gb media player for some reason anyone know how I can fix this?
If the touch screen does not work, it may be because it is out of calibration.
You can go into settings and navigate using the buttons to recalibrate the touchscreen.
Slide the on/off slider briefly. It should give you a menu.
Use the - button to scroll down to calibrate.
Push the M button
This gives the calibration screen.
Press the small square that appears in each corner, and finally in the center.
This should give you the touch screen, hopefully working.
There is a manual and other information here.
www.fascin8.co.uk/f8/ikasu/mp4-players/8gb-touch-71939#tutorial
Jan 31, 2011 | Audio Players & Recorders
CANNOT FIGURE OUT HOW TO CALIBRATE THE OVEN. OVEN TEMPERATURE IS OFF 50 DEGREES. INSTALLED A NEW THERMACOUPLE. THIS DID NOT HELP THE PEOBLEM. OVEN WAS PURCHASED IN 1992. THANK YOU FOR YOUR HELP.
Without the Model Number I can only give you Basic instruction.
If your machine is Digital the best way to calibrate if find the manuel of your machine useing your Model number.
Some of the digital models : select bake and press and hold the up or down Temp button for 5 Sec to enter the calibration mode.
Some models require you do get the temp to over 400 deg befor you can enter the Calibration mode.
If your machine has a turn knob ... Take the knob off and see if there is a small screw in the center... This is the calibration screw.
Oct 05, 2010 | Magic Chef 9122 Gas Single Oven
Ok well i bought the wheel and i have this game called dirtfactor and i was trying to drive a latemodel and it doesnt turn at all it turns a little but barly......also when i do sprint cars it turns but...
I wouldn't say it's a lack of the wheel being cheap I'd be more inclined to say it's "because" the wheel is cheap. Seriously, Have you tried to calibrate the wheel using the windows calibration routine found in your control panel under Game Controllers.
Obviously the wheel is operating but barly sorry, barely. That means it is working and giving input to your computer so if that input isn't enough you either need to calibrate in windows or maybe there's even a calibration routine in the game you're playing, maybe under options. Calibration by the way is found under properties on the Game Controller section. Try it.
The test section of the windows section will tell you just how far your wheel is turning or directing your cars by means of a box with a cross in it. The more you turn the wheel the further that cross will move. Test it first, then do the calibration and then test it again. I'm sure you'll see a big difference.
Apr 21, 2010 | Genius Twin Wheel F1
04 sportsman 700 twin seems to come to a stop if not accelerating. almost like the brake is sticking. It's not a sudden stop but it just seems like i'm braking if i'm not giving it gas. Also is there...
this is called engine braking. If you roll it while its not running it should roll just fine. If it doesnt then u probably have brake dragging on front or rear
Dec 15, 2009 | Polaris ATV
I need to factory reset.. or re calibrate
Just take the battery out simple as that. Just need a small Phillips screwdriver or a very small flat one.
May 26, 2008 | Nintendo DS Console
Genius Twin Wheel F1 Logo
653 people viewed this question
Top Genius Video Game Consoles & Games Experts
James Wishart
Are you a Genius Video Game Console and Game Expert? Answer questions, earn points and help others
