Question about Xantrex Technology XPower Powerstation Inverter
Auto xs power station
I have purchased an auto xs power station and there was no user manual with it. I can only find that u have 2 charge this but there is only 1 green light on and im not sure if it is working or not. Can anyone help?
  • 2 more comments
  • madda65 Apr 22, 2009
    when i plug the mains in the red charging light illuminates then after a few seconds it goes out and i am left with 1 green light. I have left it like this for a couple of hours and when i remove the power led and turn on the power i get a red light indicating it requires charging. argh
  • j_mcm717 May 25, 2009
    auto-xs plugged in ,green light is on to say battery condition. is good yet nothing works.no power, it is not charging.
  • A1Z1
    A1Z1 Apr 07, 2014
    You can get the manual at this link: https://www.google.com/url?q=http://erni...
  • A1Z1
    A1Z1 Apr 07, 2014
    Download manual at:https://www.google.com/url?q=http://erni...
Hi, i had the same problem and emailed the manufacturer. They suggested that i try to charge it up using a regular car battery charger, simply connect the crocodile clips to the charger and trickle charge for 3 to 4 hours. this worked for me. hope you have same success.
they did say that if this did not fix the problem then i needed to replace the battery, a used motorcycle battery will do the trick.
Posted on Apr 27, 2009
The solution for it replace the capacitor 470uF in the charger. It should provide 15V at 500mA or get a new adapter. Usually if capacitor dead it could draw ~25V. Have fun.
Posted on Jul 06, 2010
  • 4,889 Answers
In most inverters the green light signifies that it is charging. When the power goes out, the red light comes on and the inverter provides backup power. The simplest way to check is to turn off you mains for a second and see if the inverter fires up.. If not then the inverter switch is not turned on. Just flip it to the other side and it will power up.
Posted on Feb 15, 2009
  • eagle338
    eagle338 Apr 25, 2009
    Bad rating= No further help!
Auto xs jump starter
I was also looking for the manual. So came across this site. I have just connected a 12V 1A DC charger to the 12V DC input socket. Seems to be working fine. Both green lights are on - I seem to remember that when only the right-hand green light is on, the unit is fully charged. If I find my manual, will correct if needed.
Nov 25, 2013 | Air Tools & Compressors
Mains adapter for auto-xs power station not working
It could be that the internal battery is too discharged for the AC charger (as supplied with the Power Station) to work.
You could try charging the Power Station using a Vehicle (Car/Motorbike) 12 Volt battery charger, connecting the Crocodile clips on each unit.
I''ve just done that, although once 'I'd got the Power Station battery's voltage above 2 Volts, I used a 'special' charger (Optimate 5) that automatically applies several modes including 'Desulfation' for recovery.
Oct 05, 2012 | Cameras
How come i cant find the radio for my Phillips go gear vibe?
From the main menu, select the icon that looks like a little radio
To search for the next stronger signal, press and hold the up or down arrow
To fine tune the frequency, briefly press the up or down arrow
From the main menu, select to enter
radio mode.
• The earphones cable acts as FM
antenna.
Manually tune a radio station
While in mode, you can manually tune to a
radio station:
1 To search for the next stronger signal,
press and hold / .
2 To fine tune the frequency, briefly press
Auto-tune preset radio
station
The auto-tune feature of GoGear Vibe helps
you find radio stations and save them under the
preset numbers.
1 While in mode, select [Auto tune] >
[Yes].
»» The radio automatically tunes radio
stations and saves the frequencies to
presets.
»» There are 20 presets available.
»» To stop auto tuning, press .
»» To exit radio, press and hold for 2
seconds.
EN
Jan 09, 2011 | Philips GoGear ViBE Digital Media Player
Today my rebel xs was overexposing outside pics in auto mod. To get some kind of shot I have to go to manual with shutter at 1/4000, aperture 36, iso400 and still am getting heavy overexposure. Why?
The Rebel XS has an exposure compensation of + or - 2 EV in 1/3 or 1/2 stop increments. I suspect that this setting has been altered resulting in over exposures. It will not matter where you set your camera in manual operation it will still yield an overexposure.
Dec 07, 2010 | Canon EOS Rebel XS 35mm SLR Camera
How do I preset radio stations?
PRESET RADIO STATIONS
1 press RADIO BAND. AUTO PRESET to select the band.
2 Hold down RADIO BAND > AUTO PRESET for 2 seconds until "AUTO"flashes in the display
3 Press DSPL/ENT/MEM. The stations are stored in the memory from the lower frequencies to the higher ones.
if a station can not be preset automatically.
you need to preset a station manually.
2 tune int he station you want.
3 hold down DSPL/ENT/MEM. for 2 seconds until the preset number flashes in the display.
4 press PRESET + or - until the preset number you watn for the station flashes in the display.
5 press DSPL/ENT/MEM. The new station replaces any old one.
TIP the preset radio stations remain in memory even when all power is disconnected.
manual available at sony
http://www.docs.sony.com/release/CFDF10.pdf
Jan 01, 2010 | Sony CFD-F10 Radio/Cassette/CD Boombox
RX-397 FM Station presets, both in Auto or Manual, DIFFICULT to control.
I took a deep breath and realized that I had to push memory twice. Once to engage and once to set.
Apr 27, 2008 | Yamaha RX-397 Receiver
Turner mode
To the right of the number 6 station preset is an auto/name button. In the display it likely shows something like auto 1 or 2. each press will cycle it through Auto 1 > Auto 2 > Manual. You want the manual setting. See if that works for you.
Mar 22, 2008 | Kenwood KDC-X717 CD Player
Xantrex Technology XPower Powerstation Inverter Logo
7,214 people viewed this question
Top Xantrex Technology Electronics - Others Experts
Craig Butler
Craig Butler
Jimmer_9
Level 1 Expert
richie46
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
