Question about Braun Tassimo Espresso Machine/Coffee Maker
Water leak from underneath whilst dispensing - Braun Tassimo Espresso Machine/Coffee Maker
  • vern336 Mar 21, 2009
    water comes from the condensation hole (while making drinks) in the bottom of the drip tray holder, nearly as quick as it comes from the drink dispenser hole, making it look like its leaking from the bottom, its been descaled but water is still coming out as quick as ever
  • Braun Master
  • 1,711 Answers
From experience in your model and also other espresso machines there are many possible points that you may have the leak. The pump, boiler, volumetric dozer, water/steam valve are connected together with Teflon pipes and supports at the ends with the clips and one "o" ring. In one of this point the clip can slip out so the Teflon hose to be loose and so the leak. There are also some cases if the machine is more that 2-3 years one of the above parts to leak itself due to tearing out and it might need to be replaced.
So you need to remove first the top panel and then the side panel and work the machine with extra safety since we have power wires and with visual check to find the point of leak.
If it is just the Teflon pipe and clip slip out the secure it back again, if it one of the part you can try to tight up and if the leak insist then you need to replace it.
Posted on Dec 01, 2010
Kenmore front load washing machine leaking water from under the the detergent dispenser
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub. Pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer and remove it. Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening. Reach down into this opening to see if an item is inside the hose. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again. If the dispenser still leaks, then I recommend calling a service technician to diagnose and fix this problem.
May 01, 2012 | Kenmore Washing Machines
Machine not taking powder
From your comment the water feed into the wash powder section of the dispenser tray is not working properly. Follow these instructions for first removing the dispenser and thoroughly cleaning and then clean all of the jets where the water is supposed to enter. Afterwards replace the dispenser;-0)
Try the following- in the second and third cases whilst looking from underneath!
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit).You may have to push the bottom of the dispenser upwards.
  • lift upwards on the tray as it is coming out to clear the lip underneath. Again you may have to push the bottom of the dispenser upwards.
Pull out the dispenser drawer far enough to be able to just see the trays, select each part of the cycle in turn (briefly to save time) and check that water is entering the trays. If it isn't there is a fault with the water distribution and an engineer call is required ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 17, 2011 | AEG Lavamat 72640 Front Load Washer
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
Water leaking underneath when we use the water dispenser in the door.
I repaired that same problem yesterday. It is probably a break in the plastic water line. They get hot under there and get brittle enough to break. But this advice is only if you are certain it only leaks when you use the water dispenser.
Sep 11, 2009 | Kenmore 57029 Side by Side Refrigerator
My Whirlpool calypso top loading washer poured water from underneath, water everywhere, what do I do and how do I do it?? No codes showed up. Thanks for any info. Rose
Sounds like the seals & gaskets have failed. If you removed the wash plate trying to unjam the washer and did not also replace the gasket kit, you may have violated the integrity of the water tight seals. However, sometimes also the fabric softener dispenser especially, gets clogged and may overflow and leak if the tubes are clogged with coagulated fabric softener. As I am writing this, my washer's fabric softener dispenser is clogged and the method I use to clear it has not worked this time - a cup of boiling water to melt the congealed fabric softener. One has to open the top lid (method varies by Calypso model - Whirlpool or Kenmore) to get to the dispenser tubing and reservoir underneath to get things flowing again, and in fact I have a small water leak on the floor where the dispenser overflowed a bit. That you have a leak, if it happens to come from such a clog, at least gives you a sign that your dispenser solenoids are not malfunctioning, requiring replacement of one of the circuit boards.
Apr 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My washer is leaking water from underneath. How can I fix this problem
Are you sure its from underneath as a lot of washers seem to be leaking underneath but its actually a blockage in the soap dispenser. Or the water pressure is too high and splashing out of the dispenser in this case make sure the m/c is level front to back.
Mar 07, 2009 | Roper RAS8244KQ Top Load Washer
MAY8700AWW LEAKING WATER UNDER DOOR AND S/B/F DISPENSER
Service came out to check out my washer. He sent it thru the wash cycle and it started leaking. He removed the top and checked the hose that leads from dispenser to tub. What he found was the round piece of paper from the clorox top which had dropped into the dispenser apparently when I poured clorox into the dispenser. Which was causing the dispenser to backwash underneath and flow down like it was coming from underneath the door. Thank God I have an extended warranty. I advise everyone who has the newer digital models to purchase an extended warranty. It is worth it....the repair can be costly from what I understand.
Jan 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Slow leak from the water dispenser
water or switch i beleave is the water valve
Dec 18, 2008 | Kenmore 53082 / 53084 Side by Side...
Water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Jun 14, 2008 | Maytag MSD2758G Side by Side Refrigerator
Braun Tassimo Espresso Machine/Coffee Maker Logo
930 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
