Question about Noritz 6.3 Gallon Residential Tankless Water Heater - N-063S
Water Heater Won't Fire up
I have a Noritz Tankless Water Heater... it won't turn on.  no blinking light. I have power to the unit but still no spark... think maybe there might be debris clogging the unit? need help!
    Habit-Forming:
    New Friend:
I had the same problem with my Noritz 751M, I called the plumber and after he talked with Noritz and ran a bunch of tests (for $150) he told me I needed a new unit ($4,000 installed). They implied it was my fault cause I never flushed it over 8 years. They were unable to tell me the flow rate though (which should be very low if scale was my main issue). I decided to take over as I am very handy and an engineer. Here is what I found:
1. The unit is 8 years old and was never descaled (orig installer did not install the bypass valves nor tell me to flush annually). So, I installed the valves ($70) and bought a pump/hoses/bucket/Zep CLR ($150) and did the flush. There was tons of flow thru the exchanger (I did not measure how much).
2. I called Noritz myself (they were very helpful) and cleaned up the igniter rod with sandpaper (it was very discolored due to 8 years of sparking). This did the trick and my unit fired up but it was very sporadic (sometimes yes & no). The difficult part is that while the igniter is installed you CANNOT actually see (nor definitively hear) the sparking. It seems like sometimes the spark happens (unit fires right up) and sometimes it doesn't (unit cycles and ends in a Code 11 after a couple of minutes).
3. INFO: Per the field manual (Search google for: docslide.us_noritz-field-manual-2009) you can read the flow rate data from Data #14 on the remote control. It needs to be >0.5 GPM for the sparking to happen which then triggers the gas flow. You can live monitor Data #14 by following the instructions in the field manual on pp.46-47. The startup logic is: Flow > 0.5 GPM then Sparking Happens then the Gas Flows then Flames start in the combustion chamber
4. I got mine to successfully start by loosening the ignitor rod PN 101 and jiggling it while still inserted into the combustion chamber (holding it with insulated pliers while still against the case) - somewhat dangerous and startling when after sparking the gas flows and flaming starts but not too bad.
5. BOTTOMLINE: I got it working but it would not "always" light (even though my flow was always >0.5 GPM). Noritz told me that it is probably because I have the older black ignitor (PN 126 = EHEJ003). They have a new and improved gray ignitor (PN 126 = EMUJ004). I ordered it with a couple of other ignitor parts for a total of $35. I just installed them and they work great - ignition all the time from every faucet.
6. ENDGAME: Order the new ignitor parts, verify your flow rates using the field manual. See the pics below for some insight. I spent 20 hrs troubleshooting and wanted o share. If you want more info just email me at: tmorganjets@gmail.com
You can monitor the flow rate and flame by doing a skype (PC at faucet to Phone place in front of Noritz) - you will be able to see the Noritz turning on (with flow rate displayed) each time you turn on a faucet - it is very helpful for troubleshooting and verification
Water Heater Won't Fire up - water-heater-fire-up-2vdytplxgocwcfcu3oen5i2x-1-0.jpg
Posted on Feb 05, 2016
    Scholar:
  • 73 Answers
There are a few things you'll want to check:
1) make sure you have 120VAC at the outlet
2) measure voltage across the blue/white and black/white wires connected to the gfi (black box inside the unit on the bottom left or right hand side). You should read roughly 100 VAC on both sides. If you don't read voltage on the black/white wire pair, then you gfi is tripped. Look for moisture that might be shorting the gfi.
3) If the GFI checks out ok, you probably have debris clogging your flow sensor
Posted on Aug 15, 2009
  • 547 Answers
Could be thermocupple
Posted on Feb 17, 2009
Noritz NR98-DVC tankless water heater won't give hot water thru a single valve fixture. Gives us all the hot water we want on a double handled fixture. Any suggestions on what to do?
Replace single-handled faucet cartridge, and see if hot flows to that faucet again.
http://waterheatertimer.org/Crossover.html
Exposing tankless to hard water causes reduced efficiency within a few months, and can cause Total failure of parts within two years.
Do not expose tankless to more than 11 grains hard water.
Here is research pdf conducted by water softener industry comparing tankless andf tank-type:
http://waterheatertimer.org/pdf/Battelle_Final_Report.pdf
To solve problem long-long term, install tank-type gas water heater from local box store for $350.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Oct 12, 2012 | Noritz NR98-DVC-NG 100W Freeze Tankless...
Code 73 on a noritz tankless propane water heater
73 code is a circuit board error. It typically occurs if you connect or disconnect anything in the heater with power on. Try disconnecting electricity for 20 seconds to reset the unit. If the problem continues, you may need to replace your circuit board.
Apr 08, 2011 | Noritz 7.1 Gpm Propane Lp Gas Tankless Hot...
I have a Nortitz natural gas water heater, model #N-063s-1. Acouple of days ago it stopped heating the water. what can I do myself to fix this matter. Thanks, lynnatheana@hotmail.com
There are many reasons a tankless heater will stop heating water. The first thing I would look for is a flashing red light on the burner indicator. The flash break down goes as follows
continuous blinking - typically means ignition failure or the unit is overheating; look for visible water inside the unit, have your gas pressure checked, or check the flame rod/igniter for buildup of debris
three blinks - typically indicates 16 error code; typically resolved by performing a descale
4 or 5 blinks - exotic error codes; for these you should definitely contact Noritz tech support
If there is no flashing light, first check your filter for debris. If the filter is clean, your flow sensor is probably stuck. Again I'd recommend contacting Noritz tech support to help you clean the flow sensor.
Jul 31, 2010 | Noritz 6.3 Gallon Residential Tankless...
My Noritz N-084M-NG residential/commercial indoor/outdoor Hot Water Heater does not heat the water when I get up in the morning. I have to go and switch it on and off again to get it to heat the...
That unit has two flow sensors. It needs to register flow through both sensors in order for it to fire. If one of the flow sensors is stuck or if there is scale blocking flow through the heat exchanger, it will not fire. I'd recommend contacting a servicer to clean the unit.
May 21, 2010 | Noritz 8.4 Gallon Residential Tankless...
Noritz f 76 error blinking f 76 and on off light blinking at the same time. Everything works fine turned on and off hot h20 it goes to burner on 120 and then goes back to blinking f 76 after burner...
F76 is a communication error between two quick connected heaters. To clear the code, disconnect power from both heaters, wait 20 seconds, then reconnect power.
Apr 23, 2010 | Noritz 6.9 Gallon Residential Tankless...
After water to house was shut off, my Noritz tankless water heater is on but won't produce hot water. On the unit, the light indicating that the burner is on stays off now.
you probably had debris get into the filter or flow sensor when the water was turned back on. I'd recommend checking the filter first and if that doesn't work, call Noritz Tech support to help you with the flow sensor.
the filter is a black plug located on the cold water line (labeled cold on the bottom of the unit). It points torwards the left.
Apr 14, 2010 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
I have a noritz water tankless heater and hot water stopped. Red light blinking three times. Need help.
Three flashes typically indicates the unit is overheating due to scale. I'd try a descale initially and see if that remedies the problem.
Dec 27, 2009 | Noritz 6.3 Gallon Residential Tankless...
does the fan come on? this has to happen before it will even try to start if it doesn't your problem goes farther into the unit,, normal pracess if the fan then the ignitor then the flame, It could be in the circuit board most people that have gone with the tankless don't clearly ask the question but that is normal, but if you could clearify the procedure of what it is doing to this point i could be more helpful to you---- e-mail me what is happeing diffrent then what it use to do gary1121@aol.com
Jun 01, 2009 | Noritz 6.3 Gallon Residential Tankless...
Noritz tankless water heater not producing hot water
I called Noritz error code 16 is a overheat problem. Noritz say's to flush your coil with vinegar or CLR.
Use a small pump to recirculate the CLR or vinegar through the system for 45 minutes and flush with fresh water. This worked for me.
Jan 04, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Noritz 6.3 Gallon Residential Tankless Water Heater - N-063S Logo
2,508 people viewed this question
Top Noritz Water Heaters Experts
gizmonix
Level 1 Expert
jasbo
jasbo
Mack Baxter
Are you a Noritz Water Heater Expert? Answer questions, earn points and help others
