Can't get BIOS settings right
I just installed WD 160 HD the start screen is F1 to retry or F2 to set up.... in set up it say primary drive 0 unknown and primary drive 1 off
how should the they be set???
  • Bill Speer
    Bill Speer May 11, 2010
    Is your HD you're trying to install an IDE or SATA? Here's how you tell: IDE will have a larger 4 pin power plug. SATA has a smaller power plug at the end without any holes in it. Rather it will look like a thin **** that goes onto the HD. Now, in BIOS, does it say Primary Drive is SATA? We want to make sure the right kind is being searched for. Also, you do want the Primary Drive to be 0 as that is how a computer starts counting. The next drive you install (slave) would be 1.
    Also, are there any jumper settings on the hard drive that need changed? This would come with the documentation for the HD. Check the back of the HD where the cables go for your the jumper pins.
    Let me know what you come up with so we can take it to the next step.
  • PC fix May 11, 2010
    Do you have some other drives attached?
  • 131 Answers
First check to see if your drive (the 160Gig) is set to master or slave. If you are going to use this drive as your primary drive (boot disk) it must be set as master, and it would be drive 0. If, on the other hand, this is a second drive, it should be set as "slave, and should be drive 1. If there is an auto-detect HDD in your Bios, try that. If not, and this machine still won't detect your HDD, you may need to download and install a Bios update, because if your Motherboard is too old, it may not recognize a 160 Gig HDD.
Posted on Feb 16, 2009
My Laptop is Dell Latitude D600 (A16) Everytime I tried to power up, Splash screen appears with blue bar and when going into next screen this message appears " No bootable devices--strike F1 to retry...
Check your BIOS, by pressing F2 and see if the hard drive is recognized. It should indicate the MFR next to the hard drive listing. If it's not there, then you might have a bad hard drive. If it is there, try re-installing the operating system with the set-up disk. You can also go to the Dell website, enter you service tag number, and get technical support for your particular laptop. It might have a recovery partition in the hard drive to recover to factory settings.
Oct 26, 2010 | Dell Latitude D600 Notebook
Strike F1 key to continue, F2 to run the setup utility
Please let me know what is the make and the model of the pc that you are using.. Also, go to the bios, under boot menu, make sure that you have hard drive as the first boot option.. For further queries please get in touch..
May 28, 2009 | Computers & Internet
No boot device available
Make sure all the connections to the Hard Drive are tight and secure. Then see if it will boot. If not then try loading a windows cd and see if it detects the Hard drive. If it does not the hard drive is no good if it does try running the automated system recovery you may have a corrupt MBR file.
Dec 22, 2008 | Dell Dimension 4400 PC Desktop
Primary Drive 0 is not found when I boot my computer
First things first use teh arrow keys for left and right to select auto for the primary drive. If when you reboot and the drive is not seen then double check if the hard drive is set to master you can see the jumper settings and how they should be set on the top of the drive itself. Then check the power if the drive feels like its vibrating then its ok. After that turn on the computer. If after that the drive is still not detected then you might have to consider that the drive is defective and i would suggest you try another drive and see if it is detected.
Kindly reply back for additional questions.
Nov 19, 2008 | Quantum Fireball Plus AS (QMP30000AS-A) 30...
[Repost] Can't start windows
Ok i had the same problem today:
firstly check to see if the HDD is on its own IDE channel (ie. not sharing with another IDE device such as a CD-Rom or DVD drive)
if yes disconnect the Optical drive or other device on the IDE channel and boot and if it still isn't working change the IDE interface used if this still doesnt fix the problem.
Boot with the Windows Install CD and see if you can do a system repair / chkdsk , if the HDD is still not detected you possibly have a problem with your motherboard / HDD
to determine if its the hard drive if you have another HDD spare which you can try boot off give that ago and if it succeeds your other hard drive is failing time to get a new hard disk.
If you still have no success time to look for a new computer or get it changed under warranty if you still have it ?
Aug 18, 2008 | Dell Latitude CpX Laptop PIII 500 Mhz...
I am using the dell system at XPS710 and i kept getting the bios error:
I tried to hit F1, then i get that message again. I hit F2, then it i didn't see the problem.
PLEASE HELP! 16x16_smiley-mad.gif No ignores!
Apr 27, 2008 | Dell Latitude C640 Notebook
Dimension 3100 Won't Boot
Make sure your HD Cables are all firmly plugged in, and that all drives are starting when you turn on the computer. You can tell with harddrives as they will slightly whine, and have a small, steady vibration to them. If they are all starting, and all cables are fully seated, check in your Setup utility that the drives themselves are Auto-Detect. If none of this fixes your issue, you may have to refer your computer to a computer repair shop.
Hope this helps!
-Backu
Jan 16, 2008 | Dell Dimension 3100 PC Desktop
Computers & Internet Logo
117 people viewed this question
David Payne
David Payne
