Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Water dispenser tubing in fridge has calcium deposits how to clea
In my side by side fridge the water dispenser tubing has calcium deposits. How do I get the tubing cleaned out so I can get clear water?
  • matrix2725 Apr 10, 2009
    where our ice comes out its all white so calcuium build up. so how do we clear that up?
  • Anonymous Mar 24, 2014
    how to remove hard water buildup on pots and pan
Replace the tubing.
Posted on Mar 19, 2009
Refrigeratgor will not dispense water or ice
The lines may be clogged before or after the filter. If the hoses can be removed and flushed do so. If not you may require a service call to remove internal gunk due to hard water, calcium deposits, algae and more.
Aug 30, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser side by side is slow
Check the dispenser tube to be sure it is not partially plugged by taking a piece of grass whip cord and pushing it up the out spout a few times. Then try the water output in a glass so you can inspect the water for calcium deposits... If this doesn't help, check the connections at the filter to be sure that there is no obstruction at the connection between the incoming water line and the filter...
Jul 19, 2014 | General Electric Refrigerators
Whirlpool side by side, water-ice through the door. Icemaker and ice dispenser works fine, water dispenser does not. What could be wrong?
I think the solenoid that operates the water on and off is bad. After awhile calcium deposit builds up around the plunger causing it to stick. That's what happened with my refrigerator. Hope This Helps.
Oct 02, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a GE Profile side by side with water and ice in the freezer door, it is about 3 1/2 years old. The water was barely coming out of the dispenser, I changed the water filter and it is not any better -...
We had this problem on our own fridge at home. it turned out the plastic lines which feed these appliances liable to fill up with lime and calcium which will restrict water flow. take a look at getting a new line.
something else to look at. is the tube getting kinked when you push the fridge into postion?
let me know if this helps. davcol47@hotmail.com
May 08, 2010 | GE PSC23NSWSS Profile Counter-depth 23.2...
Ge profile arctica side by side- ice maker and water dispenser not working..have already replaced the water filter
The water dispenser and the icemaker both operate on different soleniods on the water valve so the chances of a bad valve are slim. I would assume you issue is in your water supply. The easiest thing you could try first would be to check your saddle valve that taps into your main water line to supply the ref. They are known for calcium deposits which obstruct the flow of water. This issue is IDed by very slow water pressure through th door. If its gunked your icemaker fill tube may also be frozen.
Jan 11, 2010 | GE Profile Arctica Stainless Steel Top...
Moldy taste from water/ice for GE profile
What kind of external filter did you use ? If you used an $11.00 cut the line and attach on each end of the tube filter , this will not work . Go to home depot and invest in the $50.00 filter which mounts to the wall , where you replace the inner certridge by untwisting with your hand . This filter has replaceable charcoal , calcium , lime ,etc cartridges . You may have to try different cartridges to find the one your happy with .
Aug 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker works but not water dispenser
Here are the steps I took to fix thi:. First, if you tapped into a copper line near your sink, turn off the off the tap completely and turn it back on again. Why? Occasionally, calcium deposits will build there and cut down your water pressure. You may have enough pressure to run your ice maker, but not enough to push the ice out of the line (I'll talk about this later). Turning the tap on and off breaks up the calcium. This will also fix an ice maker that's slow to make ice or makes hollow cubes.
Next, I just kept running my water pump (about sixty seconds or more at a time) until the water finally started to come through. When it did, a few inch-long pieces of of ice came through -- telling me that the problem was a frozen water line. If running the water pump several times doesn't work (I think it took me six tries), consider turning off your fridge for a while (be sure to remove food and pack in dry ice).
May 05, 2009 | Kenmore Refrigerators
Water flow decrease on refrigerator dispenser
You might have calcium deposits in the supply line.You can unscrew the line from the fridge and turn on the water to see if you have good flow. Have a bucket or pan handy. Let it run for a minute. If it checks out ok then the problem might be in the line attached to the fridge. Those usually come off fairly easy. If so take that off and see if its clogged. You can also check the valve where the feed is connected to the main water.
Apr 18, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kitchen Aid Superba Dishwasher
check the holes in the spray arms to see if they are plugged also brand and model number will help
Mar 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool refridgerator ice maker
Check your water valve. Most likely it is leaking by the seal on the icemaker side of the valve so that it is getting a slight trickle of water all the time to the fill tube. This will freeze in the tube much like an icecicle is formed. This is the most common cause. Low water pressure and mineral deposits inside the tube can cause it also, but it usually will take longer than a few days for the problem to reappear.
The dispenser housing and parts on your fridge are replacable and show to still be available.
You can go to sears.com, click on parts, enter your model number, and see parts diagrams and lists for your fridge.
This link should go directly to the parts site.
http://www3.sears.com/
Post back and let me know about the water valve.
Thanks/Mike
Jan 06, 2008 | Refrigerators
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
761 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
