IRobot Mirra 530 Tips & Tricks
Tips from iRobot Resources:
Run Mirra only when in the water.
Mirra has a very strong motor system that needs to stay cool for optimal performance and life. Your pool water around the motor helps keep it cool during operation. Therefore Mirra should not be run outside of the pool due to the risk of overheating the motor.
Choose the correct filter canister.
Use the Large Debris Filter Canisters when the pool contains a significant amount of large debris (leaves, insects, etc.) and when the pool is opened for the season or cleaning during the Fall. The Fine Filter Canisters are ideal for filtering small debris such as algae, sand, silt and bacteria and for regular pool cleaning maintenance during the peak of your pool season.
Keep Mirra working at peak performance.
Mirra uses the powerful force of water pumped through its filter to clean and circulate pool water and to propel itself around your pool. It pumps and filters more than a gallon of water every second! Clean the filter canisters regularly by removing them from Mirra, emptying its contents and hosing it out. Keeping the filter canisters clean will ensure optimal cleaning results and strong pump suction.
Allow the motor to cool before removing the robot from the pool.
Mirra's power supply has an automatic timer that shuts Mirra off after each cleaning cycle. Wait 20 minutes before removing Mirra from the pool to allow the pump motor to cool. Turn the power supply off and unplug it from the electrical outlet before removing Mirra from the pool.
