Question about Fujitsu AMILO PC Laptops
AMILO pro v2055 Restarts randomly when in use
Would this be caused by a faulty hard disk drive. Is this the reason why windows shuts the computer down to protect it.
  • mplsiv Feb 17, 2009
    Checked all vents, and cleaned everything. Still having problems though. Thanks for the advice.
  • 17 Answers
This sound very much to me like overheating check all the vents on the laptop make sure they are free and clear. If you have used the laptop on a bed or sofa for a period of time the vents can become clogged with a buildup of dust, if this is the case then you will need to open up the laptop and clean the fan and heatsink. you could also try vacuming the vents.
techbug
Posted on Feb 16, 2009
3 beeps 3beeps 1beep
The beep codes indicate the battery is discharged - and needs to be recharged. A manual can be downloaded at http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/LIFEBOOK/AMILO/AMILO-Pro/Downloads/a26391-k183-z121-en.pdf
Nov 22, 2013 | Fujitsu Siemens Amilo Pro V2055 V2030...
Only ocationaly rebooting the system. most of the time it says operating system not found.what could be the reason.Please help.My system Fujitsu seimens amilo pro 2065
Hey, either a hard disk corruption or some missing/corrupt files - Solution: Format and reinstall your Operating system. If that doesnt work, maybe you need a hard disk replacement.
But before that, are you sure you haven't connected any USB drives or flash drives or an external hard drive when you computer boots up. That could be the reason. Solution: disconnect any such device before you start your computer.
May 21, 2011 | Fujitsu Siemens Amilo Pro V2065 Laptop...
Windows not shutting down, automatically restarts. STOP C000021a(Fatal System Error). The windows logon process system process terminated unexpectedly with a status of 0x00000000 (0x00000000 ...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 21, 2011 | Computers & Internet
Computer randomly shuts downs. i have checked ram/hd/psu and all are fine. It hasn't shut down on me in the bios or loding though or when playing games but it shuts down a lot when just in windows or...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Nov 21, 2010 | Gigabyte GA-M57SLI-S4 (4719331821180)...
Hi when I turn on my fujitsu amilo pro v2055 it says operating software not found. Can anybody help
The operating system software is stored on the hard disk. The computer cannot detect the hard drive and therefore cannot load the operating system. It could be that it only needs reseating to get it operating again, if that does not work it could be a faulty disk drive or a faulty disk controller.
To test if the hard drive is OK, remove it and connect it to an USB hard drive adapter and plug this adapter and drive into a working computer's USB port. If this computer see this as an external hard drive and you can view the contents of this drive, then it is OK. If you cannot see this drive then it is faulty.
You need to replace the hard drive in your computer and install Windows again to get an operating computer again.
May 16, 2009 | Fujitsu AMILO PC Laptops
No wireless settings come up at all
Oh yea I'm sure it had a lot to do with it..when you format a drive you lose everything including drivers. Check the device manager, look for Network Adapter, the click on the "+" to open If you see your wireless deivce then right-click on it and then choose to reinstall drivers..good luck, let me know how it goes and if you have any questions.,
Please rate this solution.
Mar 27, 2009 | Fujitsu AMILO PC Laptops
Amilo Pro V2055 Wont start up
Try reseating the memory and the hard drive if you can remove it easy enough, if this doesn't work you may need to take it to your local computer repair shop.
Good Luck.
Feb 18, 2009 | Fujitsu AMILO PC Laptops
AMILO pro v2055 Shuts down not long after starting up
Sounds like it could be a ram issue. Rule of thumb for blue screenis to check the ram first
Feb 13, 2009 | Fujitsu AMILO PC Laptops
Fujitsu Siemens Amilo Pro V2055 laptop power on problem
Check to see if the ram is securely in place. (that will cause a pc to not boot, usually there is a beep code tho)
Oct 06, 2008 | Computers & Internet
Amilo Pro v2055 Sound very quiet
Go to control panel then sound and audio devices then speaker volume and see what level it is set on.
Nov 01, 2007 | Fujitsu AMILO Pro V1000 Notebook
Fujitsu AMILO PC Laptops Logo
116 people viewed this question
Top Fujitsu Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant  Sharma
Prashant Sharma
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
