Question about HP LaserJet 4L Printer
HP4L Printer-While printing,paper cycles1/2the way, printer stops
HP 4L printer takes the print command, paper follows the print path, paper cycles to the top tray but only comes out approx. half the way and the printer thinks it has completed the task. Paper can be pulled out manually but has only made one half of the copy. It appears to be ourt of sync. How can it be remedied?
    Problem Solver:
  • 6 Answers
Check the paper size setting in the software and print driver. Sounds like a non-standard paper size setting.
Posted on Aug 23, 2009
When print to the printer then printer take the paper and print the paper but when paper out the printer then paper is blank
If the printer accepts the commands from the pc and acts like it is printing, but no ink appears on the page, it probably means that the ink has run out and the cartridges are not supported by the printer, ie, refilled cartridges. If the cartridges are relatively new and are HP cartridges, the problem might be with alignment of the printer, but that is not likely. The most likely is that the cartridges are bad and new ones are needed. In either event it is probably too expensive relative to the cost of a new printer to try to fix this one because if the cartridges are not bad, you risk wasting the money buying new ones when the printer repair is not cost effective. One thing you might check is that the paper path is clear so that when the paper is fed through it does not get held away from the print head. Also check that the paper is following the correct path as it is printing. In any event, these printers are not expensive enough to spend much time trying to repair them.
Apr 19, 2011 | HP DeskJet 810c InkJet Printer
HP 4L stopped printing. Red light flashes
May be some ilegal process, May be paper not in tray, find it
Dec 10, 2009 | HP LaserJet 4L Printer
HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Aug 31, 2009 | HP LaserJet 4L Printer
HP Laserjet 2015n printer
Sir, the Hp LaserJet 2015n printer CANNOT automatically do duplex printing since the printer does not include mechanism and paper storage areas to cycle the paper through the printer a second time and print on the reverse side. Manual duplex printing can be done as follows: Choose duplex printing and remove all sheets after the printing is complete. Turn the sheets over while preserving the orientation and insert them in the paper feed path. I have an HP 1020 laserjet printer which is similar to the 2015.
Aug 22, 2009 | HP LaserJet P2015n Printer
Grinding Sound - Orange Paper Jam Light
You have a broken gear main motor. I had the same problem, bought $5 part and after the replacement of the gear,it runs like new
Dec 04, 2008 | HP LaserJet 4L Printer
Paper jam
Remove the toner, and try to gently pull out the paper jam.. If the page gets torn, or ripped, make sure you have all the pieces of the paper removed. Then re-start the printer. Print a test page to make sure the paper path is clear..
Nov 21, 2008 | HP LaserJet 4L Printer
Print jobs hang - LED out of paper
you need to change the ppeper pickup roller. cleaning some time helps, but always. When the same problem happen again and again. it is time to replace the part.
roller is about $8 each.
you can get it at http://www.feedroller.com/Store/index.php?cPath=1_17_86_25
Oct 14, 2008 | HP LaserJet 4L Printer
HP4L
Good. Usually that error is cause by a bad data signal comming in from the printer cable. It should be replaced to get rid of the problem.
Jun 14, 2008 | HP LaserJet 4L Printer
HP4L prints all balck page
Try reseating the print cartridge if this does not work try a new print cartridge the problem seams like your primary charge failure.
If you require more help please get back to me
Thank You
Mar 11, 2008 | HP LaserJet 4L Printer
HP LaserJet 4L Printer Logo
91 people viewed this question
Ben Johnson
