I have bvrp fax that came with my computer I used to be able to scan a document and fax it. All the screen for the fax says is "Dialing" but I don't hear it dialing. I have bvrp fax that came with my computer I used to be able to scan a document and fax it. All the screen for the fax says is "Dialing" but I don't hear it dialing.
don't know how this happened but I checked the ports that the modem is using. Bvrp says com3 but the modem in the control panel says com1. I have no idea of how these ports got changed.
Is there a way to put the modem on com3?don't know how this happened but I checked the ports that the modem is using. Bvrp says com3 but the modem in the control panel says com1. I have no idea of how these ports got changed.
AnonymousFeb 23, 2009
Computer crashed. Resinstalled Windows XP. Dell Printer A920 prints, but does not fax. Uninstalled printer, and reinstalled all drivers. Now the printer will scan, but the BVRP fax does not come up. Instead, after scanning, the printer prints the document rather than faxes it. How do I fix this?Computer crashed. Resinstalled Windows XP. Dell Printer A920 prints, but does not fax. Uninstalled printer, and reinstalled all drivers. Now the printer will scan, but the BVRP fax does not come up. Instead, after scanning, the printer prints the document rather than faxes it. How do I fix this?
Your fax machine can work independently from your operating system. Print the document and try to manually fax from the fax machine. See if there is an error message on the fax when you try. Then if it doesn't work , post the new error from the fax machine.
Fax machines usually only work over regular phone lines, not through digital cable or DSL systems. If your phone is a VOIP phone, it is a digital system and your fax will not work. It needs to be plugged into the Plain Old Telephone System (POTS) which is an analog system.
The FaxTools software is on the A920 Series InstallationCD. During installation of the printer driver, you will be askedwhether you want to install it. If you choose to cancel this optionduring the installation process, you can install the softwareseparately as follows:
Insert the A920 Installation CD into the CD-ROM drive.
When the Install Software screen appears, click Cancel.
Right click on the Start button and select Explore.
Click on the plus sign (+) beside My Computer .
Click on the plus sign (+) beside the A920 CD.
Double-click on the FAX folder.
Double-click on the relevant language folder on the right-hand side.
Double-click on the Setup executable. (Note: The correct setup icon is the one with two white arrows on a grey foreground.)
Follow the on-screen instructions to complete the installation.
If you dont have the cd this is where you can purchase the software from http://wareseeker.com/free-bvrp-software/
Use the above link, go to 'download & options' (grey on top of box), download the driver to your desk, or someplace easy to find then double click that file & it will install the driver & you'll be all set. Good luck. If this helps you plz rate this 'fixya', if you need more help leave a comment & I'll be happy to help you further. Thank you kindly.
How to Install BVRP FaxTools Software on the Lexmark X6130/X6150/X6160/X6170/X6190 Pro
The FaxTools software is on the Lexmark X6100 Series Installation
Insert the Lexmark X6100 Installation CD into the CD-ROM drive.
Click on the plus sign (+) beside the Lex X6100 CD.
just check the phone line is connected to the fax if your ans is yes then pls connect one ordinary handset and chek you are geeting the dial tone and you are able to make call chek the socekt connecton also whtether it is conncetd to the proper line socket not in ext.
bye
Yep, I have a dial tone
Say What?
