Question about Kenmore 22422 Top Load Washer
Kenmore top load no spin -.coupling destroyed w/ isolation dsk?
8 YR old machien, will no longer spin although motor makes noise as if working. Took top off, on floor we seer busted plastic pcs which we assume is the motor coupler (diagram in generic repair book show this peice between motor and transmission). Destroyed plastic peices laying on ground with isolation disc. 3 questions:
1) DOES THIS SOUND LIKE AN EASY FIX (FOR EXAMPLE - WILL REPLACING THE PLASTIC COUPLING RESTORE SPIN?)
2) WHAT ARE POSSIBLE CAUSES OF COUPLER BUSTING?
3)HOW CAN WE TELL IF OTHER PART FAILURES CAUSE THIS (IE: TRANSMISSION, MOTOR...?)
    Problem Solver:
  • 6 Answers
Hello I believe you have pinpointed the problem accurately yourself.
1. It is an easy fix, if you said you got the top off then thats the hardest part. That will restore spin because it is the linkage between the motor and transmission which spins the inner tub.
2. The causes of the coupler busting are just wear and tear. Happens all the time. Main reason for it busting is because its plastic.
3. Thats probably all it is most of the time the transmission will just slip when it goes out and not lock up. Like I say this is common so it is not likely that it is anything other.
To fix it just pull cabinet off. Pop the pump off, then the motor. Then you can access the coupling. When you buy the coupling it will come in 3 pieces. Two plastic coupling gears and the isolator. Now to put the coupling on the motor and transmission use something like a socket with a hammer to knock the coupling flush up onto the shafts of each. Put it all back together and you should be working again.. Hope this Helps
Posted on Feb 18, 2009
WAsher BROKE!
lift the lid up and down,if you don't hear any clicking the lid switch broke,if that's not it check the motor coupling,take the two clips off that hold the pump in place,remove the two screws and the two clips that hold the motor in place and the coupling is on the back of the motor,if the washer is dead it's the lid switch,if it makes a grinding noise but doesn't move then it could be the coupling,let me know how you make out
Jul 17, 2010 | Kenmore 22422 Top Load Washer
The spin cycle doesn't work and ushing the top
You need to replace the motor coupling, take front off and it's behind the motor
Feb 26, 2010 | Kenmore 24902 Top Load Washer
My kenmore washer is no longer agitating or spinning.
if it is just your motor coupling broke i would replace it ,only 15 bucks
Feb 17, 2010 | Kenmore 22422 Top Load Washer
The drum is not spinning. I hear a noise like when you stick something in your bike spokes.
Assuming that this is a Kenmore / Whirlpool top loader with a direct drive system, the first thing to check is the motor coupling.
The transmission and motor have plastic parts that connect through a rubber coupling.
pd_0026_110_285753a?$pddetailsth$ #13 on diagram Coupling, motor and isolation Number:661560Substitution:285753A $18.50 If the coupler rubber piece wears out, the pins on the motor and transmission sides will rub together making the sound.
If the coupler looks good the problem is likely in the transmission.
Sep 10, 2009 | Kenmore 22422 Top Load Washer
Kemore 110.26912690 will agitate won't spin, makes noise
You need to replace the coupling that goes between the motor and transmission
Jul 14, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer will not spin or agitate, it makes noise
IN BETWEEN THE MOTOR AND TRANSMISSION THERE IS A MOTOR COUPLING PART # 285753A REPLACE THAT WILL FIX YOUR PROBLEM
Apr 28, 2009 | Kenmore 23822 Top Load Washer
Noise from spin dial...won't spin
Remove the cabinet.
Remove the motor.
Replace the direct drive coupling.
Check the pump for any blockage.
Mar 10, 2009 | Kenmore 22422 Top Load Washer
Kenmore Washer Grinding Sound - No spin or agitation
sounds as if oyou have a bad motor coupling, you can search you tube for keywords, whirlpool motor coupling, far easier to watch someone perform the repain that try to explain it, easy to do!!! part number 285753
Feb 23, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machiene not spin dying
Most likely the coupling near the motor. go to fixitnow and search your washer problem. Tells how to fix it, I'm doing mine now.
Kenmore washer top load no spin
that is only 2 screws holding the motor, and 2 clips at the pump a 2 at the motor.
1st took the pump and than the motor and you gonna see the coupling
May 09, 2008 | Washing Machines
Kenmore 22422 Top Load Washer Logo
97 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
