Question about Mag Innovision LT776s 17" LCD Monitor
My apple mini mac (no intel) hook up mag monitor 780
Problem is that the mag has only dvi  9 pins w/one flat one................the mini mac has 9 pins one flat one  PLUS 4 MORE pins (2 on each side of the flat one ? )  Is there an adapter   for this ?...........Will the picture still be digitally inhanced   OR  would  one notice a differece if I put a vga  adapter on both ends ?  PLEASE HELP !!
    Problem Solver:
  • 17 Answers
The Mac Mini has an adapter plug, DVI to VGA.
If you use the adapter and a VGA cable to the monitor there is not a noticeable difference.
Just be sure to know the resolution maximums of the MAG monitor before you think its the Mac.
Posted on Feb 15, 2009
Hi i am looking for vga cable 9 Pin Female to 15 Pin Female thanks
The 9-pin port on your PC tower is NOT a video port, it is a serial data port. All VGA connectors are 15-pin. Hooking up to the 9-pin port will not get you a picture. There should be a VGA port on the PC, or else a DVI an/or HDMI port. You can get DVI-to-VGA adapters that work, but only if the DVI port is an analog DVI, not if it is a digital DVI (DVI-D or DVI-DD).
Feb 02, 2016 | LG Computers & Internet
What type of adapter will I need to connect my pl 1700 monitor into my mac mini?
you'll need one of these
http://store.apple.com/uk/product/M9320G/A
mac mini dvi to vga adapter
Apr 05, 2011 | Planar PL1700 17" Flat Panel LCD Monitor
I want to connect an LG 32LD550 television monitor to an Intel based 24" I mac computer---what cable is needed?
The LG 32LD550 television has HDMI and VGA.
Your iMac has a mini-DVI output port with support for DVI, VGA, S-video, and composite video connections via adapter.
So all you need is either:
1) mini-DVI to VGA adapter.
2) mini-DVI to HDMI adapter.
HDMI is better quality, and so I'd recommend something like this: http://www.amazon.com/PTC-Mini-DVI-Adapter-6ft-Macintosh/dp/B001H0REVK (You may want a longer cable though).
Dec 22, 2010 | Apple 24 iMac - Intel Core 2 Duo 2.8GHz,...
I want to know what kind of connection cabel i need for a monitor
It depends on what sort of monitor you mean, if it's an external monitor for your Mac it would need a mini dvi cable but if the monitor you want to add on is a vga or dvi monitor you will need a mini dvi to vga cable which can be found here : http://store.apple.com/uk/product/M9320G/A . Or a mini dvi to dvi cable found here : http://store.apple.com/uk/product/M9321G/B . If it is a Mac Pro which does not come with a built in screen and it's a primary monitor you want to connect it would probably have a cable with the monitor. Hope this helps.
Oct 22, 2010 | Computers & Internet
How do I connect my macbook pro to a Pioneer Elite HDTV?
Newegg.com carries a mini-dvi to hdmi cable that
Item#:N82E16812200375 it's listed as "StarTech MDVIHDMIMF Mini DVI to HDMI Video Cable Adapter for Macbooks and iMacs"This should hook directly into one of your HDMI connectors on your HDTV.
Hope that helps
Oct 31, 2009 | Apple MacBook Pro Laptop Computer with...
What kind of adapter do I need?
Your mac mini more than likely has a DVI plug on it for a monitor. You just need a DVI to VGA adapter. You can get them at any computer store for around $7. You can get them at best buy also, but for some reason their cables and adapters are way overpriced.
If you don't have a mac mini, then your connection will be different. If that is the case then I would need to know that model of your computer. Here is a link to a random picture of a DVI port:
http://akamaipix.crutchfield.com/graphics/infolib/homelib/dvi_output_jack600.jpg
Not to be confused with a proprietary port mac came out with, that is similar to DVI, but has a few extra pins for USB support. You can tell its not a standard DVI by the fact that it is oval shaped.
Sep 15, 2009 | Apple Computers & Internet
Can I use an Apple M7649 Studio Display with a MacBook Pro
Do you have the black unibody Macbook Pro that was just released, or the silver model?
Since the display is DVI, it will directly hook up to the silver model. If you have the new model, you need a mini DVI to DVI adapter.
Nov 22, 2008 | Computers & Internet
MAG monitor
The first things that comes to mind is a cable problem. Check to see if there is a bent pin on the graphics cable. Is this a new problem? Did it work before?
Sep 19, 2008 | Computers & Internet
Flat Panel Insignia 19
Lets see the cableing..
So you have a mac with a mini-dvi slot, you have a mini-dvi to dvi adapter, and then Dvi to vga adapter which connects to the tv?
The mini-dvi to dvi adapter doesn't have the analog VGA signal your tv needs. If I understood right.
Apple's mini-DVI to DVI-D cable does not carry the analog signal coming from the mini-DVI port on the Apple computer. This means that instead of buying a single mini-DVI cable from Apple and using a cheap DVI-to-VGA adaptor when you need VGA output, you must purchase another mini-DVI cable from Apple.
May 20, 2008 | Insignia IS-LCDTV32 32 in. Television
Sound for a Mag Model 780 Flat screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Dec 16, 2007 | Mag Innovision LT776s 17" LCD Monitor
Mag Innovision LT776s 17" LCD Monitor Logo
373 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
