Question about Sharper Image Ionic Breeze GP SI720 Air Purifier
Power The power on my unit will not turn on at all. I have cleaned it and made sure everything is put together correctly, however it will not turn on in any setting. Any suggestions? My Ionic Breeze from Sharper Image -- worked one day and not the next. Red light blinks -- I have cleaned it and done everything possible but to no avail. What about a class action suit against Sharper Image? Or are they broke?
  • 129 Answers
Hi
Welcine to Fixya !
The manual doesnt say of aIf its any blinking red light. If its new peice, Then Sharper generally offer a 5 year warranty.You would probably get it reparired/Replaced by them instead of going for a complex suit against them
Posted on Feb 15, 2009
  • 19,396 Answers
That is probably because of a losen contact inside.
Call the service number phone listed on the user manual and follow instructions to get the unit repaired.
    Brigadier General:
  • 8,619 Answers
Hi
Kindly open the unit and put the collection grid correctly.Also clean the contacts at the bottom which are connected to the chasis.
  • Rylee Smith
    Rylee Smith Feb 15, 2009
    If the collection grids are fine ,then issue is with the micro switch that detects whether the collector plates are inserted or not. There is a about a one-inch cylindrical piece of plastic on the front of the collector plate handle. This cylinder goes through a hole and pushes on the micro switch (actually a plastic cover over the micro switch.
    Please revert for further clarifications.
    Thanks
    Rylee
Ionic Breeze Midi Prof. Plus has red light on and won't work
When you cleaned everything did you also turn the whole unit upside down and gently shake to remove trapped dirt in the bottom of the unit. As for taking this unit apart to clean throughly there is no need. Just use some q-tips with 91% Isopropal alcohol not Rubbing alcohol to get to the small areas. Pay close attention to the small arrow shaped metal contact near the bottom of the unit. Make sure it is wiped clean and everything is completely dry. Plug unit back into power and the red button should turn green.
Mar 22, 2010 | Sharper Image Professional Plus Ionic...
I cleaned my air cleaner and now it will not turn back on
When you cleaned your cleaner, you must be gentle with it. Wipe down with a lightly moist cloth or paper towel. make sure you dont shove any grime between the metal cleaning grid and the plastic holding it all together. that can cause lots of problems. Your air purifier probably wont start because of an auto shut off safety feature. Be sure that everything is in its proper place.... make sure hte front grill is fastened on correctly as well as the back grill. if those are not secured properly the unit will not start. also, check that your collection grid is placed all the way inside the unit and wait for the click noise that indicates that its locked in place. at that point the unit should turn on and you can once again enjoy fresh, pure air!
Dec 09, 2008 | Sharper Image Hybrid GP (SI724) Air...
Won't turn on
Just wanted to make sure you inserted the carbon filter on the back before turning it on. It will not turn on without the filter in place. Also, you have to make sure the on/off switch on the back is turned on. Hope that might help.
Aug 28, 2008 | Ecoquest Breeze AT Living Air Purifier
Brookstone Pure-ion Advanced
make sure the filter is seated in the unit correctly there is a right and wrong way and unless the connection is made it won't start
Aug 23, 2008 | Brookstone Pure-Ion UV Air Purifier
One hissing one shut down
I have two Quadras not sure about the GPS. The only way to clean them properly is to complete the folowing steps. This will eliminate the hissing noises and intermittent shutdowns. Clean the blade unit as normal and leave it out of the unit. Unplug the unit, remove the four phillip screws on the top of the unit where the collector grid slides down. Next remove the four screws holding on to the base of the unit. After this you will see two additional screws also by the base that need to be removed. Look carefully between the grills of the unit and you will see about 12 to fifteen tiny screws that hold the grill together. After these are removed take off the UL label and seprate the grill. You may have to gently pull up on the top where the power switch is located. I have found if you use a lightly dampened scotch brite pad to carefully clean the two wires works best. Clean the wires and pins at the bottom and make sure all is well. Use a microfiber or lint free cloth to gently wipe everthing down and make sure the unit is dry. Put it back together and put the UL sticker back on.
Feb 12, 2008 | Air Purifiers
Kenmore air purifier- model 85500
Power Off the unit then Press and HOLD the Off-Timer and Function buttons at the same time WHILE Powering the unit back On. The Replace Filter light will blink for 5 seconds than go out. Now you can release the the buttons.
Just to make sure everything is working fine power off and on the unit.
On a side note if you are a tight wad like me you may want to just smak the filter layers against the ground a few times to clean them and re-use them / make them last longer. When the replace fileter light comes on too often then it is time to replace the filter.
No worries ;o)
CDA
Dec 18, 2007 | Air Purifiers
Ecoquest Breeze AT
When you clean this unit, the plate should be soaked in a 50% amonia to water solution for about 8 minutes. Take a toothbrush and scrub each side of plate and let copletely dry. Take a qtip and dip in rubbing alcohol and swab each of the metal electrodes that touch the plate....This should have that freash air smell back again.!!
Nov 08, 2007 | Ecoquest Breeze AT Living Air Purifier
Power
Can someone start a Class Action lawsuit against The Sharper Image ?
The two I bought are the SI871 GRY for $693.82. Both have flashing blue lights. Margie B.
Aug 17, 2007 | Sharper Image Ionic Breeze GP SI720 Air...
Sharper Image Ionic Breeze GP SI720 Air Purifier Logo
78 people viewed this question
Top Sharper Image Air Purifiers Experts
martinmarty
Ken Thomas
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
