Buying an
iron with variable heat settings is really important as it gives you control.
If you have
hair that is fragile, fine or color treated, you should set the heat below 200
degrees otherwise you are risking burning or damaging your hair.
If you have
curly, coarser type hair, you can set the heat higher - around 200-300 degrees.
But never go
above 400 degrees no matter what you hair type is like.
