Question about i-mate JAM Pocket PC
How to reinstall opraring system from where to get oprating system 5 and how to prpair booting card memory
  • dr masood Mar 08, 2009
    it is imate JAMA
  • 146 Answers
U cannot install windows mobile 5 on imate jam...
Posted on Mar 07, 2009
Wipro laptop PC not starting Only widows starting automatically option is repeating
go to boot menu and check your setting about firstboot devise.sure first boot devise is hdd than restart and show if problem not remove than return into boot menu and change first boot devise into dvd rom and reinstall your oprating system whith your oprating system cd..
Mar 02, 2014 | Computers & Internet
My dell optiplex gx620 does not start and it shows no. 3 and 4 lights illuminated on its front . what could be the problem.?
One of your memory chips is bad.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Diagnostic Lights caution.gif CAUTION: Before you begin any of the procedures in this section, follow the safety instructions located in the Product Information Guide. To help you troubleshoot a problem, your computer has four lights labeled "1," "2," "3," and "4"on the front or back panel. The lights can be off or green. When the computer starts normally, the patterns or codes on the lights change as the boot process completes. When the computer starts normally, the patterns or codes on the lights change as the boot process completes. If the POST portion of system boot completes successfully, all four lights display solid green. If the computer malfunctions during the POST process, the pattern displayed on the LEDs may help identify where in the process the computer halted.
note.gif NOTE: The orientation of the diagnostic lights may vary depending on the system type. The diagnostic lights can appear either vertical or horizontal.
Light Pattern
Problem Description
Suggested Resolution
The computer is in a normal "off" condition, or a possible pre-BIOS failure has occurred.
The diagnostic lights are not lit after the computer successfully boots to the operating system.
Plug the computer into a working electrical outlet and press the power button.
A possible BIOS failure has occurred; the computer is in the recovery mode.
Run the BIOS Recovery utility, wait for recovery completion, and then restart the computer.
A possible processor failure has occurred.
Reinstall the processor and restart the computer.
Memory modules are detected, but a memory failure has occurred.
  • If you have one memory module installed, reinstall it and restart the computer. (see "Memory" for instructions on how to remove and install memory modules.)
  • If you have two or more memory modules installed, remove the modules, reinstall one module, and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error.
  • If available, install properly working memory of the same type into your computer.
  • If the problem persists, contact Dell.
A possible graphics card failure has occurred.
  • If the computer has a graphics card, remove the card, reinstall it, and then restart the computer.
  • If the problem still exists, install a graphics card that you know works and restart the computer.
  • If the problem persists or the computer has integrated graphics, contact Dell.
A possible floppy or hard drive failure has occurred.
Reseat all power and data cables and restart the computer.
A possible USB failure has occurred.
Reinstall all USB devices, check cable connections, and then restart the computer.
No memory modules are detected.
Memory modules are detected, but a memory configuration or compatibility error exists.
An other failure has occurred.
This pattern also displays during System Setup and may not indicate a problem.
  • Ensure that the cables are properly connected to the system board from the hard drive, CD drive, and DVD drive.
  • Check the computer message that appears on your monitor screen.
After POST is complete, all four diagnostic lights turn green briefly before turning off to indicate normal operating condition.
None.
Jun 06, 2012 | Dell OptiPlex GX620 PC Desktop
Whenever I am trying to boot my desktop....it is going to hibernation...I have checked the monitor, which is working good
press F11 on start and see if it wants to boot in safe mode.. ..if you manage to boot it ..it means that it is just a setting from the video card made wrong ..and I suggest to reinstall the video card ..
If it do not boot atall ..and just beeps a sec and shuts down ..open it and see if the CPU cooler is spinning ...and also check the Ram memory ...If you have more than one units for ram ...remove them one by one ..and try to boot the computer with one at he time and see if any of them is damaged..
In case the ram memory is damaged..the computer will actually not boot at all ..and will not show the device check on start ...but just spins the hdd and clicks in a loop ..
If the computer shows the devices..but goes off when windows is trying to start it needs eiter the video driver to be reinstalled to correct any odd settings ..or the operation system is unable to start and this is cause by the hdd not being detected or a malfunction of the operation system ...In this case..check the HDD to work well ..or reinstall the OS..
Dec 24, 2010 | HP Compaq Presario SR1265CL-B...
T5048 windows xp very slow, 5 to 8 min. when first turn on. bought 512mb memory that dose not fit in real tight. Can you help me, thank you. Ed Monnin
The fact that it is slow may or may not be the memory. Did you purchase the correct memory for the computer? I suspect that you did since it is booting. When it does finally boot, go into your control panel, into system. Then look and see if it is reading all of the memory (this is at the bottom of the General tab). This screen should tell you how much memory you have minus whatever your video card is using.
If it is reading all of the memory then you're ok there. If it isn't take out the new memory and try again, that is if you still have the old memory and it is good.
Now once you have booted up your system backup all your data to a flash drive, an external harddrive, a cd, or whatever media you have available. Next, reinstall your operating system (I'm assuming it's Windows). Make sure that you reformat your hard drive in the process. Alot of times it could be a virus that has infected your hard drive and causing it to slow down. Then restore your backups and you should be good.
If that doesn't work then there's something else wrong with your system. If your hard drive crashes and you can't reformat or reinstall windows then you needed another drive to begin with. If that's the case then at least you've made a backup of all your data.
Good luck, have fun, and let me know.
Nov 05, 2010 | E-Machines Computers & Internet
MY CELL PHONE CANT DISPLAY MISSED,RECEIVED AND DIALLED CALLS?
Remove your battery memory card ,replace battery after 30 minutes, restore your phone to factory settings using code 12345.Now if the system boots up clearly,have the memory card scanned and reinstalled.If there are still errors the phone must be re installed.Contact Nokia care.
Sep 30, 2010 | Nokia E63 Cell Phone
G31TM-P21 normally boots with series of beeps. Now will not boot properly from CD start sequence (for reinstalling op system) and gives a short beep about every 5 seconds. No information found on MSI...
According to the sequence of beeps your getting from your computer, ther is a possibility that there is a problem with the memory module or RAM on your computer. Try reseating the memory then try to boot up again.
Cheers!!
Sep 02, 2010 | MSI G31TMP21 (890552671946) Motherboard
When booting the number 2 light is not on...the others light but the computer wont boot up...if you turn it of and on 20 time it will finally work.when it does work the display flickers sometimes.sometimes...
  • If the power light is steady amber, a device might be malfunctioning or incorrectly installed.
    • Remove and then reinstall the memory modules (see Memory).
    • Remove and then reinstall any cards (see Cards).
    • Remove and then reinstall the graphics card, if applicable (see Cards).
    • Ensure that all power cables are securely connected to the system board (see System Board Components).
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/adtshoot.htm#wp1054148
Sounds like a motherboard failure
Jan 10, 2010 | Dell Dimension E521 (D10E16) PC Desktop
I CANT USE MY SECONDARY IDE
Format system and reinstall oprating system
if problem still continue so update bios
download from www.asus.com
Mar 08, 2008 | ASUS A7S333 Motherboard
i-mate JAM Pocket PC Logo
137 people viewed this question
Top i-mate Computers & Internet Experts
Bilal Ahmed Qureshi
castletech
castletech
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
