Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door slider that connects to the pulley will not stick
  • Kaz Masri
    Kaz Masri May 11, 2010
    Can you provide more details? It sounds like the plastic lastch that attaches the two may be damaged.
  • 504 Answers
IF YOU ARE REFERING TO THE TROLLEY THAT RUNS ON THE OPENER RAIL. IT MAY JUST NEED THE RELEASE RESET. PULL THE ROPE BACK TOWARD THE POWER UNIT AND IT SHOULD CLICK - SOME UNITS NEED TO BE PULLED STRAIGHT DOWN.
IF IT IS A SCREW DRIVE OPENER THE TROLLEY COULD BE STRIPPED.
IF YOU HAVE A SCREW DRIVE IT COULD BE THE DRIVE
Posted on May 28, 2010
Trouble garage door
Disconnect the door so the belt and pulleys will run without a large weight to move. If they move ok, reattach the door and try again but help the door move with your hand. If it moves ok then, the door levers and joints may be too stiff and need lubicating and wiggling until they move freely.
Nov 16, 2013 | Ultra Max Home
I installed the belt of the lift master garage door opener, but it looks like it has a lock and it does not open and close correctly. How can I re-set it?
The position of the belt and the limit assembly must be synchronized to operate properly. You need to loosen the belt enough to lift it from the pulley on top of the motor and then run the motor until it runs in the clockwise direction and stops. Now with the belt connected to the door and the door closed put the belt back on the pulley and tighten. Should do it.
Apr 28, 2011 | Sears Craftsman LiftMaster Chamberlain...
GARAGE DOOR WANT CLOSE, USING CLOSER WILL MOVE A LITTLE BUT LIGHT FLASHES, SENSORS SEEM TO BE WORKING
I recommend this to everyone with garage door opener problems:
Use the pull cord and disconnect the opener from the door.
Operate the opener and let the carrier slide back away from the door. Is the carrier moving smoothly when disconnected?
Next, lift the door by hand from the bottom to the top. Is it moving smoothly?
If not, lubricate the hubs of all the rollers on both sides of the door. Check the cable pulleys at the top sides of the door channel, lubricate them as well.
Are all cables in all the pulleys, there are 4.
Dec 07, 2010 | liftmaster Chamberlain Garage Door Opener...
Garage door wont close - acts like there is an object in the way. If is detach the door from the sliding unit, the door closes easily. If I try running the slider down without the door attached, it stops...
It sounds like the sun may be shining on and causing problems with the door sensors. Try using the cardboard tube from a roll of toilet tissue on the receiving sensor.
Sep 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Two pulleys have come off my liftmaster 9851 garage door. how do i fix it?
Hi. The pulleys are held in place with a bolt and a nut. Go to any hardware or home depot that has garage door parts. Take another pulley off and take the missing pieces with u. J.
Aug 01, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster Chamberlain Garage Door Opener Transmitter 300MC: Hi, The belt that connects the motor to the pul...
IF IT IS ONE OF THE NEWER BELT DRIVE OPERATORS THE BELT ATTACHMENT IS ADJUSTABLE.
IF IT IS ONE OF THE VERY OLD OPERATORS AND YOU IN FACT HAVE THE CORRECT BELT YOU CAN NORMALLY SET THE BELT ON THE SMALL PULLY AND LAY IT AGAINST THE LARGE PULLY BY TURNING THE LARGE PULLY YOIU CAN ROLL IT ON.
May 16, 2010 | liftmaster Chamberlain Garage Door Opener...
Chamberlain Whisper Belt Drive
door does not close without holding wall button in
Oct 15, 2007 | Chamberlain Powerdrive PD422D 1/2 HP...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
109 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
