Question about Kenmore 23822 Top Load Washer
Won't pump out water at the end of wash or rinse cycle.
Timer is moving. When the normal 90 second pump-out cycle is reached, the washer is dead, no noise at all. Then when it moves to spin cycle, the washer spins and pumps out water, but the tub is still full, and most of the spin cylcle is spent pumping out the water that wasn't pumped out before the spin cycle was reached. Clothes are still wet when using the high water settings. Spin and lid switch work normally. Sounds like a timer issue to me, since the washer is dead quiet when pump out cycle is reached? can you confirm? Pump works fine when spin cycle is reached. How can I troubleshoot the pump-out failure? The only thing running durring pump-out is the timer.
  • James Sandberg Feb 16, 2009
    It pumps right away when the tub is full and not spinning fast enough to push water out, indicating the water is being pumped and not driven out be CF. I did think of this, but I really dont think its the problem. Will double check. Also, there is absolutely noise when in the pump out cycle. The motor is not running at all when the timer is in this cycle.
    Novelist:
  • 175 Answers
I don't know this model at all, but hada similar set of syptoms on an electrolux .....
Just a thought, but have you checked the pump chanber is not impeded by a stray hairgrip, or bit of wire?
The fact it doesn't pump when it should, but allows water to pass when the centrifugal force of a spin cycle builds up, would indicate that maybe its the pump that either has a jammed impeller, or a blown motor (or fuse).
Posted on Feb 15, 2009
    Problem Solver:
  • 5 Answers
Sounds a like the timer is unable to give the right commands to the pump
Bosch classix 1200 exprss washing machine will not move on from the wash cycle. it will keep on washing and never moves to the rinse cycle. pump and motor works ok.
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Mar 25, 2015 | Bosch Washing Machines
Hi my washing machine works perfectly fine but the water don't pump out srew out bottom filter is clean and I clean it on a regular basis. Defy 1300 laundromaid. Thanks please help
You probably have a rock or some object stuck in the pump blades. Take out the pump and turn the blades get out the obstruction
Nov 26, 2014 | Washing Machines
KenmorenLaunry center not draining or advancing cycles
Hi David if the timer is not cycling the tub will not drain ,the washer will not complete cycles, second check the lock switch on the door. this can stop the timer and the tub from draining. when not cycling the timer is at fault , this could be two problems, 1st when everything stops check the door safety switch , 2nd listen for the timer, if it stops running. good luck ,geodaws
Dec 09, 2013 | Kenmore Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 90 Series Washer - No Agitator Movement
You need a timer the motor contacts are probably burnt.
Aug 21, 2009 | Kenmore 15864/15862 Top Load Washer
Amana washer only works on delicate cycle
Open the control panel. Unplug the timer and then plug it back in good and firm.
If it does not work correctly after that,
Replace your timer.
Mar 12, 2009 | Amana Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Skipping throygh cycles
Timer ? Are you referring to the main control board ? How much extra water is being added on the first cycle ?
Jan 14, 2008 | Maytag MAH6500 Neptune Front Loading...
Kenmore 23822 Top Load Washer Logo
192 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
