Question about Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Pump
How do I prime the STA-RITE DS3HF-01? - Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Pump
I have a sta-rite mkse-6 pump and it has lost its prime..... how do I prime it???
Posted on Aug 15, 2009
  • 3 Answers
Make sure it is full of water, and there are no leaks and just let it run. It is a self priming pump and will pick up the prime after a few minutes.
Tim @ International Sprinkler Supply - www.internationalsprinkler.com
Posted on May 21, 2009
  • 1 more comment
  • Spicerak Apr 04, 2012
    They have a problem latley.. I heard they have a company making there heads.. I took me 32 mins verse my flotec that took 8mins.. Sta rite has screwed up... Trust me
    I have used the pumps for 20 years... Used to be the fastest primer ever... Not now... Deeper pull forget it.. I have a plastic flotec 10 years old blowns them away now... New plastic flotec same as the starite... Im going to goulds... Sta rite bettter figure this out... Im very pissed at them
Where to add water to prime pump ds3hf-01 sta rite
water is filled in the body of the pump to prime it
fill the filter housing if that is part of the pump
make sure that there is no open pipes /hoses or air leaks on the suction side of the pump and that includes any vacuum machine hoses floating on the water surface
Jun 26, 2016 | Sta Rite Pool & Spa
Have deep well vetical sta rite pump both pipes in ground staying full of water will not pump press does not looose prime but wont build press
shut off pump breaker at the lowest faucet drain completely. Turn it back on. If this doesn't work, you have to change out the pressure valve on the side of the tank. it's not hard.
Oct 08, 2012 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Rrigaton pump won't hold prime?
Check out the foot valve... it either went bad or it has dirt stuck in it...
heatman101
Aug 11, 2010 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Do I need gasket sealer on gasket between motor and pump housing on sta-rite water pump?
You will know if the housing has a gasket groove cut in it for a o-ring. if not no gasket needed.
The Pool Tech
Jul 10, 2010 | Sta Rite Ds3hf 1.50 Hp Self Priming...
I had to take the motor out and put it back together now its not getting water what do I have to do. The motor works fine
If this is a self priming pump you will just have to fill the pot with water. If not you will have to open a valve and force some water through the system to prime the pump. This being done, if you still have no water you may have a suction leak keeping the pump from priming and may need a repairman at that point. Good luck.
Apr 25, 2010 | Sta Rite Ds3hf 1.50 Hp Self Priming...
How to prime a sta rite mse 7 deep well pump, when I've filled the 1 inch pipe plug with water and it won't fill.
have to fill the housing complete with fluid. make sure there is no more air in it. also make sure that is not poss. to **** air. also the sucktion side must be full of fluid. watch rotation direction. pump is not able to **** from under 7 meters.
Feb 08, 2010 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Pump will run continuously, not disengaging, creating high pressure in tank.
have a look at the presher censor it could be a duff one may need to be replaced
Oct 26, 2009 | Sta Rite Ds3hf 1.50 Hp Self Priming...
REPLACING A NEW GASKET ON AN AO SMITH 1HP PUMP
NOOOOO!!!!! NEVER put any kind of cement on a gasket! It will RUIN IT!!!!
Mar 26, 2009 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Open Questions:
See all Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Questions
Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Pump Logo
1,696 people viewed this question
Top Sta Rite Garden Experts
appman67
appman67
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Are you a Sta Rite Garden Expert? Answer questions, earn points and help others
