Question about Packard Bell iMedia SL 9553 (P660401806) PC Desktop
Cant use old packard bell speakers
I want to use my old speakers from my very old packard bell machine. These speakers plug into the monitor that they came with,which looks like a power cable from an adaptor.
I tried just connecting them to my newpc but they wont work. Is there any way I can use them so I dont have to shell out for another set?
  • ortiz_82 Feb 18, 2009
    thanks for the help
  • ANTGOM71 Mar 11, 2009
    SAME...ISSUE IS IM MISSING THE ACDC CABLE...BIG PROBLEM IS THAT I TOOK OUT THE SPEAKERS TO SEE SPECS FOR CABLE...NO SPECS ABOUT VOLTS AND AMPS...ONLY READS PHSP70219926, WHAT A PITTY 'CAUSE SPEAKERS ARE GOOD, BBE & SRS.
    TONIO G
    President:
  • 2,692 Answers
No . The reason that you cannot is that they are amplified type speakers and the amplifier section appears, based upon what you stated, to be in the old monitor.                      Sorry.
Posted on Feb 15, 2009
Newer monitor won't work with packard Bell R450
Wow, it's about time to dump the Packard Bell. Maybe the Video Card has gone bad in the Packard Bell and if you fix it your old monitor might work.
Apr 24, 2012 | Packard Bell Computers & Internet
My packard bell is about seven years old and was fine until i had it fixed recently and was told that i would need to buy new speakers that could plug into the back of the computer as I needed a new...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Apr 25, 2011 | Packard Bell (030069) Sound Card
How do I connect the speakers to a packard bell computer
You need a Packard Bell motherboard for this. look on the side of the monitor in the slot, and you should see 2 dark patches (holes). poke the hooks of the speakers inside these holes then pull down. if they are correctly placed, they will not come out if you pull the speakers away from the monitor. Hope this helps! Max
Feb 10, 2011 | Packard Bell Computers & Internet
Can I fit packard bell speakers to an ibm computer?
sure the speakers are plug ad play, so just plug it to the green jack in the IBM computer
Aug 13, 2010 | Packard Bell Speaker Computer Speakers
Speakers not working - PS2 plug has come out
Honestly, if they are packard bell speakers they are 1. old, 2. may have a propritery connection that is no longer found. A new set of speakers will only cost $20 at walmart, might be easier to just invest in a new set!
Oct 04, 2009 | Packard Bell Speaker Computer Speakers
Unable to connect speakers to desktop
The monitor has integrated speakers. This means that there should be a headphone jack at the front or side of the monitor. You can plug your (amplified!) speakers into this jack, and it will bypass your monitor speakers.
Mar 26, 2009 | Packard Bell iMedia 6826 (P481000502) PC...
Packard bell fps100 flat panel speakers
I am in the same situation as Simon and would appreciate help. They are Packard Bell speakers, called FPS-100
Dec 03, 2008 | Packard Bell (030069) Sound Card
Packard Bell speakers screeching sound
Are they plugged in to correct sound socket on back of computer
even if they are on monitor
Jul 05, 2008 | Packard Bell Speaker Computer Speakers
Drivers for Diamond 1200
The Packard Bell Diamond 1200 Plus is in fact manufactured by Mustek and is the Mustek Bearpaw 1200 CU Plus.
Packard Bell no longer support or list this device on the website but drivers can be found at Mustek's European site
http://www.mustek.de/11/index.php/en/ser...
They provide drivers for Windows so make sure you download the corret one for your version
Feb 22, 2008 | Packard Bell Packard-Bell Full Page...
Packard Bell iMedia SL 9553 (P660401806) PC Desktop Logo
290 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
