Question about Epson Stylus C62 InkJet Printer
Epson c62 printer say's parts need replacing, service required
Needs a service, can i reset the printer, or service it myself, printer is 6yrs old.
  • fredt_333 Feb 15, 2009
    Same/similar problem: "Parts are beyond service life". However, if you turn your computer COMPLETELY off, then turn the printer on, then turn the computer on, the printer (at least mine) WILL print 1 job. It then goes right back into error mode.
  • keith437 Apr 12, 2009
    just got the sme message out of the blue with no warning, seems to have in built redundancy!! very naughty. Epson webs site troubleshooter says machine is 'malfunctioning' and may be cheaper to replace it!!
  • 353 Answers
These symptoms usually mean the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C62), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. Check the current count value - if it is greater than the limit shown it will confirm this is your problem. Then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
If this solution helps you, please rate it; if it doesn't, please provide further information by posting a new comment.
Posted on Apr 14, 2009
ALTERNATING GREEN RED LIGHT EPSON C62
Try first disconnecting power cable for tem minutes and see if it reset
May 25, 2008 | Epson Stylus C62 InkJet Printer
Plastic part that holds down black inkjet Epson Stylus C62
yes it is possible however cheaper to replace the whole printer
Oct 30, 2009 | Epson Stylus C62 InkJet Printer
Epson c62 Parts inside your printer are at the end of their service life. Contact your dealer for replacement.
Use this link, covers what software and tricks
http://tricks-collections.com/reset-epson-stylus-color-printers/
goodluck
Oct 09, 2009 | Epson Stylus C62 InkJet Printer
Refuses to print with red light constantly flashing.
well sir this kind of indication TENDS to pertain on the ink pad that needs to be replaced. for you to extensively use the product, download an ink pad reset utility on the epson website. it should give you all of the information you need. www.epson.com/ipr is the site.
Sep 23, 2009 | Epson Stylus C62 InkJet Printer
Epson c62 color ink cartridge says it is empty when i just refill
I use cheap replacement cartridges about 20$ for 3 color/5 black....the printer usually doesnt recognize the cartridges ink level but it still prints......do you use actual epson replacements? If you use cheaper replacements you might have gotten some with dud chips...prob the cartridges fault, not your printer
Jan 01, 2009 | Epson Stylus C62 InkJet Printer
Epson Stylus C62 Error Red light wont go off
Hi victorarcas
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced (see later). You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C62 Service Manual". You will often find them for sale very cheaply on E-Bay.
Please rate this solution if it has helped you
Dec 22, 2008 | Epson Stylus C62 InkJet Printer
Epson C62
This is probably that the waste ink pads need replacing. If you still have this problem and need help with it, please post a new comment to this effect.
Apr 08, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson Sylus Photo RX600
press the on, stop, color & b&w buttons at same time and hold them down for awhile......seams to reset everything....good luck
Oct 23, 2007 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson Stylus C62 InkJet Printer Logo
518 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
