Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
Motor guilde lll trolling motor
Can someone tell me what year this motor is ? And how many pounds of thrust it has ? Ser.#17476 model # 2600
  • mac12571 Mar 28, 2009
    I also have a motorguide III model 2600 I would think that it is 26 lb but I do not know the year and would like to know
    New Friend:
I have a motorguide trolling motor model 2600 #s/n 19409 can't find out what thrust it is
Posted on May 01, 2013
3 Suggested Answers
  • 323 Answers
SOURCE: Motorguide Trolling motor has low thrust in all five speeds
I have a 4 speed with 48 lbs of thrust. On mine, 1 through 3 will move me out pretty well, however, 4th is similar to an overdrive gear in a car or truck and is meant more for maintaining a speed with less draw on the amps.
I certainly wouldn't want to take off with it. I suspect it is the same with your 5 speed. The boat needs to be up to speed and then those two gears will maintain it, with 5th being optimal as far as low draw in amperage.
Posted on May 23, 2009
  • 5 Answers
SOURCE: i have a 37 lb thrust motor guide stealth 5forward
trolling motor parts.com
Posted on Apr 30, 2010
I have a Kenmore sewing machine model 158-923. Ser num 003339, can u tell me what year made?
Sears may be able to provide that information. If it is a metal case, probably 1970's. If plastic case, possibly 1980's. Just a guess...
Oct 01, 2016 | Kenmore Sewing Machines
I have a Maytag washer model MAV298DAWW. My clothes are still wet after it spins, and it makes a clunk/screech noise at the end of the spin cycle
It could be the clutch if you change it out be very careful. When you remove the cover screws that brake spring hold 500 pound of tension and it will knock your block off.
Jan 12, 2016 | Maytag Legacy MAV208DAWW Top Load Washer
I have a 65 pound thrust all terrain MinnKota trolling motorThat stopped working on me the other day when I was fishin.Iwas fishing and was trolled 2 another spot when I got there I stop the trolling...
Hello John,
Most Of The Time I Find The Problem Is With The Cables And Connections To The Battery?
Remove Battery Lugs And Cables Clean All Contact Areas .
Re Connect And Test Again
Hope This Helps
Gordy
Dec 01, 2017 | Boating
99 honda accord was running fine, then out of nowhere, it started idling rough at a stop,
I think your being had over here ,if i had my head under the bonnet i could tell you but from afar ,3000bucks sounds a lot for a 99 motor thats worth 500 to 1000 pounds tops even if it is a honda ,i can buy a monster jag here under a 1000 pounds and at 10 dollars us a gallon you know why?
Dec 09, 2012 | Cars & Trucks
May 22, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
How does the minn kota 65 all terrain run on 24
You should only run the motor with a 24v battery or two 12v batters 'jumped' out. To jump the two batteries, connect the positive on one batter to the negative on the other battery and hook the trolling motor battery cables up to positive and negative terminals that are NOT jumped out as you would normally. Don't run this with 12v as you will have serious problems if you do. They do not make a 65lb thrust in 12v - too much pound thrust to run off of 12v.
Feb 22, 2009 | Minn Kota Endura 30 Freshwater Transom...
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
1,641 people viewed this question
Top MotorGuide Electrical Supplies Experts
jdthefixer
Mike
Mike Marcotte
Mike Marcotte
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
