Check these codes. 003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171 If you wish to get four digit or five digit codes, check this link.
I need the four digit code for the tv. this page was for a different television.
There are four digit and 5 digit code list to different brands of televisions. Check it. Pull up older posts there. Check these links too. http://fixyab.blogspot.com/ http://electrohelponline.blogspot.com/
SOURCE: Programming the Acquos Remote
Input code 0093 into your Comcast remote. Here's a link for the how to: http://www.comcast.com/MediaLibrary/1/2/CM/VanityURL/documents/comcast_dvr_remote_manual.pdf
SOURCE: Two red vertical lines down 32" Sharp Aquos LC-32P50E LCD TV
There are solutions for stuck "and not dead pixels" Here are a couple idea's to try and please do not rate me bad if don't work!! That would not be nice as i do not get compensated showing your solutions I get them by your "good ratings" Hence do not use "Thanks for Trying" rather helpful or fixya will do now here are the websites:
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
http://www.jscreenfix.com/basic.php
If you TV can hook up to a computer witch it can through servral means then you can use this information. But However do not rate me Thanks for trying if the darn thing just dont unstick the pixels... Thank You for using Fixya.com
"were we can save you hundreds of dollars on repairs" It has been my pleasure assisting you today. Rulds2008- Expert Top 10 Fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
I’m happy to assist further over the phone at https://www.6ya.com/expert/kevin_c38b47f462e94458
SOURCE: sharp aquos no sound through hdmi
Reset all audio factory setting.Tries unplug,replug it well work,if ur backlight video board it still good.
Testimonial: "worked like a charm thank you so much, i was about to throw in the towel and get a new tv, now i don't have to thanks again"
