Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Amana side by side coil cleaning
How do I clean the coil on my Amana side by side?
    President:
  • Amana Master
  • 2,651 Answers
Removethe lower kickplate , under the doors, then with a refrigeration coil brush(avaailable at te hhradware stores) and a vaccumm you can clean the coils
Posted on Feb 16, 2009
AMANA SIDE BY SIDE refrigerator/freezer . Freezer freezes intermitently, and then stuff thaws. Cleaned the botton coils, didn't help. unplugged and re-booted. didn't help
HI.intermitent faults r allways abit problematic .but run through some basics ok?1-after defrosted freezer works ok?2-how long for.if ok then all u can do is change defrost timer and t/stat one at the time or together.clean condensig unit thoroughly.good luck.ali
Jul 05, 2012 | Amana Refrigerators
Clean coil light comes on - requre detail
Remove the front grille, vaccum the coil or brush with coil brush.
Jul 11, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Clean coil light is on
The coil they are referring to is the condenser coil, which will be located underneath, and can be accessed either by removing the toe plate in front, or by pulling the cabinet from the wall, removing the machine compartment cover by removing the screws. In both cases its best to use an appliance brush or lint brush available at any hardware store, these brushes are about 2' in length, and contain black plastic bristles, and of course, unplug your refrigerator before doing any maintenance. Remove the dust and pet hair from the condenser with the brush, then vacuum the brush clean and repeat.
Jun 28, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Amana drs2660bw refrigerator won't make ice any more
if freexer is not cold enough . this causing low or no ice prod . so ck the fan under neath and clean the coils in back . if this does not correct problem . you may have a bad ice maker .. mm
Apr 18, 2010 | Amana DRS2660B Side by Side Refrigerator
Freezer & refrigerator are not cooling enough.
there is a couple of things you can try. you can try to defrost the whole unit. it is not always a good idea to turn it up to the max setting. if the inner coils get frozen up it causes the problem you are having.
Sep 23, 2009 | Amana ASD2625KE Side by Side Refrigerator
Amana side by side ars2365ac
That fan is most likely on trying to defrost that frozen coil. It sounds like you may need a thermostat, a coil cleaning, and hopefully the system is not low on charge, those are 99% of the causes for a freezer, or refrigerator to freeze, hope all works out.
Feb 15, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Center post on 11 year old side by side amana is hot
check the coils underneath the unit to be sure they are clean if they are clean then check the condenser fan motor behind the cardboard cover on the back of the refrig. the motor could be bad or has an obstructuction. good luck peyton
Jan 19, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana Side by Side Refrigerator not getting cold
amana is having some problems with their compressors locking up. if the compressor is manuactured by tecumseh then tthe compressor is mostlikely locked up and will need replacing. good news is your refrig is most likely less than years old and should be in warranty to amana..
Dec 15, 2007 | Amana ARSE66MB Side by Side Refrigerator
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
756 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
