Question about Hitachi 43UWX10B 43" Rear Projection Television
Hitachi 43fdx11b green wave on top left and center
First the blue wouldn't move, so I changed both ic's and 6 resistors, then the tv worked great for about 10 minutes. Then it got a green wave on top left and center. The green convergence crosses seem to have ''dropped'' on those two locations about 3 inches, and now it has a green wave that I can't fix. I rechecked all my soldering and it looks fine. What could this be?
    Novelist:
  • 184 Answers
Its likely that you did not find all the resistors that were damaged when the original failure occurred. Now you must re-replace the ICs and locate the other damaged resistors. Check all, including those you just replaced. Use a good ohm meter and be certain that all the resistors are gold band tolerant(5%) and of the exact resistance value and wattage.
michtech
Posted on Feb 15, 2009
2 Suggested Answers
Ecollier2012
  • 3459 Answers
SOURCE: hitachi 43fdx11b green wave on top left/center of screen
Check your soldering.
Check the resistors - make sure none are shorted.
Make sure you did not buy fake STK chips...
www.TvRepairKits.com
Posted on Feb 28, 2009
Hitachi UltraScan HD Projection Screen 43FDX01B
The convergence board is on the fritz! See TVRepairKits.com and see if they have a kit just right for you!
Jan 12, 2010 | Hitachi 43FDX01B TV
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Green wave on left top and center top in my 43FDX11B TV
replaced both convergence ics in the tv.also check for open resistors near the convergence stk ics.
Jul 17, 2009 | Hitachi 43UWX10B 43" Rear Projection...
3 resistors and IC's replaced, still have convergence problem
Well you've done everything pretty well so far. However it sounds like to me you missed one of the resistors necessary to wrap this up. Down by the STK's are three connectors going to each of the yokes, red, green and blue. Locate the one for blue and follow the traces from the connector to the large wattage resistors like the ones you've already changed. One of them affecting blue vertical is probably open. If you have an ohm meter check those resistors after you disconnect the plug going to the yoke. that because those resistors are in parallel with the yoke windings and thus mess with the measurement of the resistors.
May 01, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 43fdx11b green wave on top left/center of screen
Feb 15, 2009 | Sony KP-51HW40 51" Rear Projection...
BLUE BULB CONVERGENCE
Replace the convergence ICs and feed resistors. You can get replacement ICs and resistors at the following link with installation instructions. If you leave them a email with your model number they will tell you the correct ICs and resistors for your model set. Heres the link.
http://servicemanuals.vstore.ca/
Nov 26, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Top left corner double picture red and green
you have a failed IC resistor usually you can physically see the bad one because it burns out leaving you to guess what the value was. Hitachi offers a convergence fix kit which has 2 IC's and all approiate resistors.
Sep 01, 2008 | Hitachi 43FDX01B TV
Hitachi projection tv
I would change both ICs STK392-110 and also the 3.3ohm 1 watt resistors and the 1.8 ohm 1 watt you would need 2 of each resistor. Then your convergence would be new again. You can get replacement ICs and resistors at the following link with free shipping and free instalation instructions with pictures.
Jul 01, 2008 | Televison & Video
Double Vision ...w/waves on top/bottom too much green.
1024x768 Normal 0 Convergence
When A REAR PROJECTION TV has coloured outlines or a 3D image the Convergence Circuits most likely need attention.
Replacing the output amplifiers (located within the Convergence IC's) allows the pictures to line up correctly, and no more color outlines.
This is the most common fault in all makes of rear projection TVs.
Some models of TV require major disassembly and considerable shop/manufacturer's support to repair because of their design that causes other power supply or vertical deflection problems. The poorly designed products require a "bench" repair that can typically cost from $350 t0 $700.
Some TVs are designed for on-site repair and have more reliable circuit design that does not usually cause damage to other parts of the TV when convergence chips fail. The ones that usually allow reliable on-site repair are JVC, Samsung and Hitachi.
It is normal to have some resistors in the circuit burn up or increase in value from the heat (from 2.2 ohms to 5 or 10 ohms). These resistors must be replaced with the right value or the chip may fail again.
This is not a simple repair like changing batteries or a fuse. Reading through the other posts shows many that try and end up with bigger problems.
Your JVC uses STK 392-110 IC's. Misinformed people replace the IC's with other "new and improved" IC's, like STK 392-150. These are devices with different characteristics and require different value resistors in the circuit. Replacing with the STK 392-150 will cause overheating of the resistors and a damaged IC.
If you are in Calgary, I can help. If not, get someone that has experience working on your JVC. My website is below with some costs and explanation.
calgaryconvergencerepair.weebly.com/convergence-explanation.html
Good Luck,
Easyab
Jun 05, 2008 | JVC AV-56WP74 56" Rear Projection...
Hitachi 43FDX11B television Ghosting
I had the same problem on my Hitachi rear projection TV 53FDX20B made in Mexico. The blue convergence problem. Blue focus had shifted and appeared like a blue ghost image. I followed the step by step intructions from the fixya site. First Replaced the two STK 392-110 ICs and turned on the tv. No change. Then I went looking for the bad resistor. There was one resistor RK50 (2.7 ohm, 1Watt capacity) which is attached not right close to the printed circuit board surface but was well raised up from the board. The bands on the resistor were a little discolored. I replaced that one and turned on the tv. The convergence problem was solved. Thanks for the step by step instrucitons on your site.
Dec 20, 2007 | Hitachi 53FDX01B 53" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
176 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
