Question about Sharp LC-45GD5U 45 in. LCD Television
I own a Sharp Aquos LC45GD5U, purchased January 2006 yesterday morning, the picture did not appear when I turned on the TV. Sound, backlighting working fine. Cable Box and DVD player also fine. No picture. Found in the manual a reference to a way to turn off the picture and get audio only, but it requires the original remote, which I have lost. (I use the remote provided by cable company, exclusively). I doubt that I have accidentally turned off the picture. However, I would note that the TV has been slow to turn on for the past couple of months. Has something burned out?
  • rexfordh Feb 16, 2009
    Did that first. thanks.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
The easiest would be to 'borrow' an original remote to verify that it is not the video muting enabled. If even with the original remote, the situation remains the same then, two ways to address your problem:
  • if you are comfortable/familiar with electronic components & circuitry, then a DIY (do-it-yourself);
  • seek the service of a qualified professional and get a repair quote.
Based on the above, options then are:
  • access a Service Manual or at the very least a schematic diagram for reference when performing voltage checks at key test points;
  • follow the checklist/repair procedure to determine faulty boards;
  • check/replace as necessary; or
  • depending on the repair quote, you may want to re-evaluate your options and consider replacing the TV. This is based on the age, cost of repair, downtime and efforts to effect a repair. It may turn out not to be economically reasonable.
Good luck and thank you for using FixYa.
Posted on Feb 15, 2009
    Master:
  • 848 Answers
Most likely your set is experiencing a panel backlighting problem or powersupply problem.
    Brigadier General:
  • 3,614 Answers
kindly check the connections first, could be a loose connections at the back of your tv.
  • Sharp Master
  • 19,396 Answers
Try first unplugging power cord for five miunutes, I can find a replacement remote.
  • Ginko
    Ginko Feb 15, 2009
    Try first unplugging the TV from main for ten minutes, th8is will drain power completely and restore default settings.
    After connecting test teh TV with no device connected, only with an antenna.
    If you still get no picture then this is an internal fault.
    If you get picture with antenna, then the TV is fine, and you have either a bad video cable or a faulty receiver/DVD.
    If the TV is defective call the number listed on the owner manual to get it repaired.
My sharp aquos lcd tv 32 inch usually gets hard time in turning on coz once a brownout occurs and when i turn it on only the green light appears without pictures so i have to unplug it on and off as...
Sounds like you have bad capacitors somewhere in the TV. If none of them are bad, you could also have loose grounding screws on the inverter shield. It is common for this TV and simply retightning them will keep the backlight on again.
Mar 23, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
No picture no sound opc light and power light
This is very common in sharp tvs.U turn it on.U get power on light stable right?U hear a click,one or twice,sometime tv is good right?Sometime POWER light and OPC light flashes?Push the power button on/off couples times will work, picture will come on.If keep trying off/on couples time after POWER and OPC flashes,don't ever stop and never get backlight and picture.Ur Video backlight board is dead must replaced.
Dec 28, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Tv picture turns off by itself. sound still
the problem of your LCD TV is maybe there is something loosing up when heated on the backlight board of your LCD TV......all you have to do is resolder it or reheat it with a hot air...........if you dont bring it to the sharp service center
Oct 30, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
No Picture with sound
sounds like you have a bad panel. This ussually happens when a backlight lamp has gone bad and the inverter board senses this and sends a signal to turn the backlight off.
Mar 06, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
No Picture
If your TV is a SHARP LC-45GD5U,
Try using the reset buttons on the back of the TV. It should be below your digital audio output port.
If that doesn't work, ( this is only a guess) the power supply for the LCD screen may have burned out.
Feb 15, 2009 | Sharp LC-45GD5U 45 in. LCD Television
No Picture
I doubt that your component has burned out. You may be looking at a repair issue here even though your unit is only 3 years old IF: you have tried connecting using different inputs, OR if you cannot bring up your sharp menu, or you list of inputs. If you cannot do those following things, you have a SERVICE issue on your hands and unless you purchased and extended warranty with sharp, its useless calling them. They will just tell you tough luck, and refer you to one of their authorized service centers. good luck
Feb 15, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos lc45gd5u
perhaps the power inlet cord or the scart cord needs replacing or perhaps you have a faulty pixel generator. try and replace them if that is the problem. find out first! good luck!
Sep 11, 2007 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Sharp LC-45GD5U 45 in. LCD Television Logo
51 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
