Question about Whirlpool RF378LXKS Electric Kitchen Range
How to reset a RF378LXK electric range
The burners keep getting as hot as they can even when it is on a low setting ,we moved and at the other house it worked fine but now it keeps doing this problem...
Krazytech
  • 725 Answers
SOURCE: repair GE electric range
Door motor safety circuit you may have a faulty Electronic Range Control (ERC).. let us know what you find out.. krazytech
Posted on Sep 08, 2007
the dr
  • 447 Answers
SOURCE: problem with electric range
Most likely the switch has welded closed
Posted on Sep 28, 2007
fridgetech
  • 473 Answers
SOURCE: magic chef electric range model 38HK-6TXW
MAGIC CHEF
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad F6 means no ac signal and will need to replace the oven control.
Posted on Oct 18, 2007
SOURCE: gas range top burners too hot
Get the installation manual for your range, and find the part on adjusting the low heat for the burners. On my Whirlpool, I found there is an adjustment screw inside the control knob shaft of each burner. The manual says turn the burner on low, remove the knob, then turn this screw until the flames are 1/4" high. Super-easy, it took me 5 minutes to do. I am sure all ranges have similar adjustments, might be in different locations - check the manual.
Posted on Feb 19, 2008
MATRIX_MMX
  • 209 Answers
SOURCE: Front right burner won't go on high, keeps continuous low flame only
Dear lejeunelm
Righteo then, this is a problem that will probably require you to send the appliance back to where you got it from as there is either a fault with a valve, the gas regulator, or a problem with the supply. Even if this fault is caused by an electronic regulator (controls the amount of gas that is pushed through the burning chamber, and to the temperature it heats (if your gas cooker has this), then it is SERIOUSLY ADVISABLE to get yourself a corgi approved gas engineer to look at this fault and fit the part. Obiously becuase gas is not only explosive, but also pretty poisonous either before or after combustion has occured.
Now id did mention that the fault could be associated with either the supply, regulator, valve or anything that controls the flow of gas, but the fault could also be caused by something as simple as the twist knobs on the front of the cooker unit. If the knob either becomes stuck, or is not in the correct position then obviously the gas settings will be wrong. Now behind this knob, there probably will be a flow valve, which will control the amount of gas being delivered to burn. Probably a good point of fact to get the valve checked too. Even more reason if you get a funny smell of gas that is being emitted, as this would indicate a leak either with the valve or elsewhere in the system (which causes pressure to drop and hence low amounts of gas being delivered to the combustion area).
I would suggest calling out an engineer to check your gas supply, and definitely take the coioker back to where you got it from. Although this may seem like drastic measures, it is not as drastic as the potentail risks to you and those around you if the problem is serious. (explosions, fires and poisonings are common with gas problems if they are serious enough). It is probably wise to also do this if you have an insurance premium on your house/ flat or place of residence.
Now there could be chance that you your good self are an engineer to some degree, or have experiance with gas fixtures and fittings, now if this is the case, then i would start by suggesting a trip online to http://www.google.com and then typing the manufacturer/ vendor model of your cooker into google with the words "service sheets" or "repair manual" or "repair instructions". Now this will give you a list of websites that will offer you the chance to get hold of the information that you require, however some of these sit6es may charge you for the technical data, and some even so expensive, that the cost of the sheets is outweighed by the cost of taking the unit/ getting a professional in to do the job for you.
Now lets say that you did do the job yourself, then you may need parts, and i reckon http://www.google.com yet again will be the best place for you to start searching for the parts. NOTE:::IF YOU DO ORDER ONLINE, CHECK THAT THE PARTS ARE NOT FROM THIRD PARTY VENDORS. ONLY PURCHASE APPROVED PARTS FOR FUITTING TO YOUR MAKE AND MODEL OF COOKER/ GAS UNIT)
Finally, if you do get your appliance worked on, always get a second opinion and always demand that you have your old part back (if any need to be fitted) as so you can have this checked over to find exactly the fault cause, and obviously to send the part back to the manufacturer/ vendor to make them aware of the issue.
I hope that this fixya is the fixya you require and also that you get this matter resolved in the fastest and most appropriate way. In the meantime, if I can be of anymore assistance, please feel free to contact me as soon as you feel the need to, and i will endeavour to advise you on virtually any technical issue that i have experiance within (mostly home/ business electricals and appliances).
In the mean time, i hope you take care, and hope to ghear your response soon.
yours sincerely
oz
Posted on Apr 13, 2008
Why do burners not get hot? After rehooking to electrical power, due to a remodel, the burners don't seem to heat up as hot as they used to. Cant boil water on any of the 4 burners.
Could be not enough voltage on your 220.lines ( one wire lose or a bad breaker. or the wires are hooked up wrung causing it to try to operate on 110 instead of 220
Aug 17, 2014 | Kenmore Electric Smooth Top Stove
I have a Beaumark Electric range about 8 years old, The right front burner comes on high as soon as it is turned on, even if I turn it to low it remains on very, very high and burns everything. Why
The burner is not controlled and so it is possible that there is no control on the heating coils.The thermostat settings must be checked as this can be an area where the coils are not controlled for the heat set but goes to the highest level.You will need to remove the unit to check the control action of the controller, check the thermostat and sensor.
Nov 22, 2011 | Kitchen Ranges
Need help...my range JS968 cooktop seems to not cool down when turned down, even boils food when turned down to low, what can be done...I'm almost ready to purchase nother range. Thanks
It is normal for food to continue to boil for a short period of time after turning the burner to a low setting. Is your burner staying hot long after it is turned off?
Jun 05, 2011 | GE Profile JS968 Electric Kitchen Range
My electric stove will turn on but the it won't get hot. Oven or burners.
either the power cord is shorted out or the voltage coming out of the receptacle is too low...reset the circuit breaker,it may be half tripped-the lights can operate at 120 volts,but the unit needs 240v to operate the burners
Mar 06, 2010 | GE Spectra JBP78 Electric Kitchen Range
Electric gemini range has a low hum to it.
could be your low voltage transformer that powers your control board
Nov 03, 2009 | Maytag MER6772 Gemini Electric Kitchen...
My oven on my GE stove gets too hot even on low and top of stove is very hot. Whats my problem
it sounds like your sensor is out a calibration
it may need a new one to keep the range in desired setting
Oct 09, 2009 | GE JBP30 Electric Kitchen Range
Coil gets extremely hot
You need a new controler for that burner.
Jul 15, 2009 | Kitchen Ranges
Problem with Jenn Air Gas Range???
are you talking about the burners or the oven reply with model num and dont rate me till we are finished
Jan 02, 2008 | Jenn-Air JGS8750 Gas Kitchen Range
Whirlpool RF378LXKS Electric Kitchen Range Logo
130 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
