Question about Whirlpool LSB6200PQ Top Load Washer
Howdo i get the washer cover off a thintwin whirlpool washer tha
Have a whirlpool washer and need to get the cover off the top thanks
    Problem Solver:
  • 9 Answers
The timer box or the whole washing cabinet cover?
the timer box is removed via 2 screws in the rear of the plastic end caps and carefully wiggling it foward very gently then it should tip back...
if you want the cabinet removed under the timer box is 2 metal snaps that can be removed to take off the outter cabinet.. good luck
Posted on Apr 30, 2009
My thintwin is not spinning, seems like motor is working but the central part is not rotating and its stuck
this sounds like a broken motor coupler between the motor and transmission. this is common in whirlpool washers.
Apr 25, 2010 | Washing Machines
Washer stopped in the middle of a load
sounds as if yhou have a lild switch problem , lift and close the machine lid and listen closely for a "clicking " if hte machine doesnt think the lid is down it wonk spin/ drain for saftey reasons. common issue broken lid switch
Nov 13, 2008 | Washing Machines
Whirlpool thintwin stackable unit
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 25, 2008 | Whirlpool LTE6234D Top Load Stacked...
ThinTwin cabinet access
a little awkward atfirst but shlould be a problem. remove the angular panel along the rear of hte washer top youll see two brass clips an inch in on both sides, with a screwdrier "pop" these clips off, and if i remember correctly there are (2) 5/16 screws directly behind them (sorta on the frame of unit just below the rear lip of the top) the main top then will slide toawrd you and rigth off. a screw secures the front panel on both sides adn it too lifts up and off. acess to pump is right there. reverse order nad your good to go.hte brass clips will SNAP right back in place when lined up correctly
Mar 07, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool ThinTwin LTG6234DQ1
CHECK YOUR LID SWITCH IT HAS PROBABLY CAME LOOSE OR IS OUT. YOU CAN USE A OHM METER TO CHECK IT OR UOY CAN JUMP THE WIRES WITH A TEST LEAD
Feb 27, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool ThinTwin
have you checked the carbon brushes in the motor 1 on either side of the motor with a wire going to each brush carbon should be at least 1in in length and can go down to about 8ml b4 they need changing m8
LTE6234 Whirlpool Twin Thin Timer Broken?
Check for voltage at the water inlet valve with the timer dial pushed in or in an off position. If no voltage replace the water valve. If you do have voltage you'll have to trace the circuits back from the water valve to the line. One point of demarcation is the water level switch. Pull the violet colored wire and see if it still fills while off. If it does it's likely the timer's bad.
Jan 31, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LSB6200PQ Top Load Washer Logo
147 people viewed this question
Dan Webster
Dan Webster
Sal De
