Question about Maytag Neptune MDE5500AY Electric Dryer
FIn inside neptune md55 dryer came loose need to remove side pane
The fin on the Neptune Dryer has come loose and I need to remove the side panel on the dryer to replace the two screws that hold one of the three fins in place. It would be simple if I knew exactly how to remove the panel.
  • 7 more comments
  • shortoldlady Mar 21, 2009
    one of the three fins is coming progressively looser - need help how to access and tighten.
  • mp548225 Mar 27, 2009
    The past two weeks my dryer has this god awful rattle clinking noise in the lower left side while running.
  • Anonymous Apr 02, 2009
    does anyone know how long the screw is that I would need to replace I need to get the parts today before I go home or the wife might not let me come home.
    Thank you solution #2. You are awesome and explained things perfectly!
  • Anonymous Apr 08, 2009
    Same problem with loose fin, The directions provided here were excellent! Saved me a $125 service call.
  • Anonymous May 06, 2009
    My problem was a rhythmic scraping noise while the dryer was on. Using solution #2 (worked like a charm), I found that one of these screws holding the fin had unscrewed most of the way out and was hitting the sides of the dryer as it went around. I'm sure glad it didn't snag any of the wires, etc in there. Using my 8mm socket I was able to tighten the screw back in (and while I was in there, make sure all the other screws were tight also!), put the front back on, and start up the dryer. Voila, no more noise! Thanks so much for the solution to my problem.
  • Mrs. Fixit Jul 14, 2012
    Solution #2 worked like a charm!!
  • Anonymous Mar 31, 2014
    Need to remove fins from dryer barrel
  • Anonymous Apr 01, 2014
    Remo
    ving fins from mitor and is this why the dryer tyrns on and off
  • 10 Answers
I had the same problem but it's the FRONT Panel you need to remove. Before you start, unplug the thing first. BTW I did the whole proceedure in 10 minutes using an electric screwdiver / philips bit and a socket set with an 8mm socket with my leg in a cast. You can do better, I'm confident!
Two 8mm hex head bolts hold each fin on the drum. They can be tightened. You need to open the dryer front since they bolt from the outside of the drum. To open the dryer front you first take the door off by removing the two philips head screws, then slightly lift the door and pull toward you (the door hinges have little hooks on the end that inserts into the slots (this little design keeps the door from falling off during removal and install-nice). Then remove the two philips screws on the other side of the door opening (opposite the door hinges). These screws hold two plastic brackets (be sure to see how they are aligned before you remove them so you know how they go back on.
Now the front frame panel looks like an "H" . Grab the top two arms of the 'H" and give a quick ****. The top arms of the 'H" will come loose. The bottom part is held by a couple of clips, just pull up and the front panel comes off.
You will be able to spin the drum until the hex bolts for the fin(s) in question are visable / reachable from the right side (just above the heater unit-hope you unplugged the dryer earlier). I tightened it using an 8 mm socket.
Now reverse your steps: put the front panel back on the bottom clips and snap the top "H" arms back in place. Reinstall the plastic clips / screws and then put the door back on.
Posted on Mar 28, 2009
  • 2 more comments
  • nornicotine May 10, 2011
    Yes Indeedy...a ten minute fix as described by psuallen (#2)...THANKS!
    Also, Kudo's to Maytag for designing a product that can be disassembled and reassemble without trouble!
  • Helpmedothis Dec 16, 2011
    Dear psuallen,
    Thank you, thank you! I was able to follow your well-outlined instructions exactly, and problem resolved! I love the Internet. People like you make life better. I owe you $85 (the price my appliance repair guy would've charged me...minimum.
    This solution is perfection!! All worked as described!
    Mrs. Fixit
    absolutely worked like a charm, thank you!!!
    Mrs. Fixit
Yeah for my DH! You take off the door and then remove the lower front panel. You now can access the fin screws - tighten all while they are there!!
Posted on Mar 21, 2009
    Side note - tighten them ASAP - our's has been clanking for awhile and DH said the holes were starting to elongate.
Fin that tumbles clothing inside dryer coming loose, how can I tighten it?
These fins are usually screwed on from the outside of the drum. If you're up to it this is a simple but time consuming fix. Take the cabinet off the front of the dryer, the top will come off as well. be careful of the wires from the control console, they will stay attached to the dryer. Tighten the tumbler fins on the drum and then re-assemble the cabinet. Typically the screws you need to access are the same used for the door latch and hinges. They go back together easy ........
Feb 14, 2011 | Maytag Neptune MDE7500AY Electric Dryer
Fin inside dryer drum is loose
unplug unit open front panel. reach in to tightned. if screws missing look on flooring of unit. they always there
Feb 06, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I HAVE A MAYTAG NEPTUNE DRYER. THE RIB ON THE
remove the toe kick front panel screws near the floor in front then lift up like a car hood to release clips at the top,then remove screws that hold top on,then you can get to the baffle screws to re attach
Jan 28, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Neptune dryer MD5500 - the fin in the dryer is loose. How do you take the top off in order to access the outside of the drum?
First remove door. Remove the screws holding the front panel on (inside door recess), pull panle from top down and remove and set aside. Remove the 2 5/16 screws hold top down located at left and right sides. Lift top up for easy access.
Jan 27, 2010 | Dryers
Neptune Dryer Blades
Yes - right where the front panel meets the top panel of the dryer on both sides there are two clips. Insert a screwdriver into the clips and push up on top panel. You'll see the screws that hold the fins on the dryer. Tighten these screws or replace. Good luck...
Nov 16, 2009 | Maytag Neptune MDE5500AY Electric Dryer
One of the "fins" inside the drum has become loose. It hasn't come off, it's just loose...how can I fix it? Thank you!!
hoping it is a neptune.........
remove the screws on the door hing to cabinet
and the two opposite
lift and remove the door
once the door is off
you can pull the front panel off
grab the thin sides and twist in and pull
onvce tat panal is off you will see two 5/16 screws on each side
remove those
you should be able to lift the top
once you do you should be able to see the top of the tumbler
turn till the loose fin is on top and just tighten the screws back out and your good to go
Oct 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My neptune dryer has an interior 'fin' that is loose (mde5500ayw)
There are screws holding the fins on the outside of the drum. To get to them:
  • remove door
  • remove screws on the opposite side of the door screws (which would hold the door if it would open to the opposite side)
  • pull the top of the front panel, which was held by those screws outwards
  • remove the front panel. You'll see brackets holding the top of the dryer in place. Remove screws holding those brackets.
  • lift the top.
Good luck
Oct 20, 2009 | Maytag Neptune MDE5500AY Electric Dryer
The fin on the Neptune Dryer has come loose and I need to remove the side panel on the dryer to replace the two screws that hold one of the three fins in place. It would be simple if I knew exactly how to...
Remove the 2 screws holding the door and the 2 screws on the other side of the door opening . Pull the front panel foreward and lift off . If still not enough room to reach under to tighten , remove the 2 screws (1 on each side , holding the top down , then lift top . DISCONNECT POWER BEFORE DOING ANY WORK .
Aug 18, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
2,066 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
