Question about Bose RC-18S Remote Control
Remote control works fine - except will not change channels
I have a Bose 321 system which my husband installed many years ago. The remote control, up to a few days ago, has worked perfectly. TV turns on, Cable turns on, volume works ... however, the remote will not change the channels any more! The Cablevision remote will change the channels but not the volume, so I'm currently using both remotes.
What could have caused this problem to occur? Unfortunately, my husband died so I have no one to ask.
The blue communication light on the media center does light up when I try to program a channel, but nothing happens. I feel so LEGALLY BLONDE because I can't figure it out. HELP!
SOURCE: Bose 321 Remote not working
Pull off the front panel, be carefull there is a ribbon attached. Detach the ribbon. There are 2 ribbons attached to the front panel, one that leads to the IR (remote sensor) and other for the controls on the top of the unit.
Most likely the ribbon that goes to the IR sensor detached itself, this is common if the unit is dropped etc. Insert the ribbons (2) re-attach the front panel and the remote should work fine. You'll notice some tape on the IR ribbon, I suggest using some stronger tape, BOSE tape thats not very good.
This happened to me on my 3-2-1 GS II system and fixed it.
Posted on Jul 04, 2008
  • 4 Answers
SOURCE: Bose Av38 Media center remote contro issue.
problems of conectivi betwen samsun and bose products many people whit same problem,
Posted on Apr 22, 2009
  • 3 Answers
SOURCE: not working on sound, but fine with channel
Try cleaning the side of the pcb where the rubber buttons rest on with a q tip soaked with acetone. You can also use methylated spirit. If this does not work, then there is probably an open circuit in the pcb or a component is not functioning. You need a multimeter and some knowlegde of electronics to test the components.
Posted on Aug 17, 2009
SOURCE: My bose 321 system remote control sometime works and sometime doesn't.
I had a similiar problem with the Bose Remote for Lifestyle 3. The Remote Just didnt work ,other than on/off.I had to stand infront of the system to make it work. Solution:- "Turn Off" all the electronic equipment near your bose system or connected to your bose ( TV, Hifi, Iphone , wifi ,xbox, Wii etc ) and then just "TURN ON" the Bose alone and try the remote...it should work fine. Then start each device one at a time followed by testing the bose remote the same time. I found out that once i "Turned On" the TV the Bose Remote failed to work. The TV was inteferring with the remote as both of them work on around 40Hz...Try it ...it just might solve your problem
cheers Boss
Posted on Sep 01, 2009
SOURCE: I do not have the
instructions for the RCV1T-27 are contained in the manual for the Lifestyle V-class instruction manual (V30,V20,V10) in the link below: http://products.bose.com/pdf/customer_service/owners/og_ls_vclass.pdf
Posted on Oct 18, 2010
I have a bose 321 system and I was wondering if there is a way to turn the bass up and down without the remote. I lost it
321 Home Entertainment System - Bose Product Support
worldwide.bose.com/productsupport/.../321.../page.htm...
Bose CorporationDiscover product support for your 321 home entertainment system. ... Learn how to setup and place your system components. more » ... You can adjust bass and treble levels to suit your listening preferences and your ... Discover how to use buttons on your remote and media center control panel to ... Get Adobe Reader.
[PDF]3•2•1 Home Entertainment System - Bose
worldwide.bose.com/axa/assets/pdf/.../og_321.pdf
Bose CorporationJan 29, 2002 - within the system enclosure that may be of sufficient magnitude to constitute a risk of electric .... Turning off the internal speakers in your TV .
Jan 18, 2016 | Bose 321 Series Iii Dvd Home Entertainment...
Bose 321 dvd and remote
hello.
Clean out the battery connection inside the battery case. Incase this work disassemble your remote and find any fault connection in it. or let the repair man do it.
If the remote work change the setting press PBC mode this will change the color. or refer to the manual for changing view setting.
melnavz
Mar 31, 2008 | Bose 3 2 1 GSX System
I have a Bose 321 GS III Cinema system. What code do I have to program in the Bose remote control to control my Motorola 1960 Cable tuner? The codes in the Bose manual do not work, so I expect that the...
having same problem with my bose 321 GSX. my mom just got shaw digital and likes the shaw remote better than the bose one. I can program the bose remote to do everything but can't seem to do it for the shaw remote. I think i need a code for bose as a reciever? I dunno... any help would be good eh!
Aug 10, 2010 | Bose (321GS) System
My 321 remote does not work
Yes Contact Bose They will Help you. I also have a Bose,but if the receiver is Built by ONKYO and you have had this for more than a year you might have a problem. They(onkyo)require a receipt. The Techs are fine but the lady you will end up talking to is well just say not so nice. Good Luck
Apr 16, 2010 | Audio Players & Recorders
When I first had my Bose home theater system installed professionally, my bose remote controlled my tv, cable box, and dvd player. I have 4 remotes including the bose remote. I thought the bose remote was...
If your remote worked everything for a few weeks and then quit, and you are sure the codes are correct, take the remote back under the 1 year replacement warranty and exchange it. It is defective.
Jul 31, 2009 | Audio Players & Recorders
Mar 25, 2009 | Bose Lifestyle 38 System
Bose 321 remote control not working
You can test a remote control using these methods:-
Method 1 - If you have AM, Medium Wave radio then set the tuning off a channel and press the remote control buttons. If there is a change in sound, higher and/or lower tones the remote is working.
If not check the batteries are charged and fitted correctly.
Method 2 - If you have a digital camera with nightshot, wait until it's dark turn off the lights and turn the camera to nightshot. Aim it at the remote in the dark and focus then press the butoons. Look at the led light is there any change/flashing on the end of the led.
This will confirm it is the remote control and a replacement is required, or batteries need changing
Jan 17, 2009 | Bose RC-18S Remote Control
Jan 26, 2008 | Bose (321GS) System
When we try to use the remote the red light glows which I never saw glowing when it was working properly.What could be the problem?
Jan 03, 2008 | Bose RC-18S Remote Control
Bose RC-18S Remote Control Logo
866 people viewed this question
Top Bose Televison & Video Experts
George Scott
George Scott
Are you a Bose Televison and Video Expert? Answer questions, earn points and help others
