Question about Sharp Multi-System Mini Component System Shelf System
CD player won't play or recognize when a cd is inserted
I have a mini-component system, cd-c472, that won't recognize or play cd's. I think I may have confused the player's computer system by trying to play an mp3 disc a few years ago. It made the whole system act strangely, and eventually stopped playing cd's. The carousel rotates through all three locations when I insert a cd, and then the cd player displays "NO DISC" Is there some way to reprogram the cd player? Thank you
Jeffrey
  • misharifi Feb 17, 2009
    same problem
zair
  • 82 Answers
SOURCE: Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Posted on Mar 29, 2008
SOURCE: sharp cd-c472
I did solve the problem; instead of spending time online looking for a user's book, I tore my house apart and found the original one. Thank you for your response.
To set the clock for the Sharp CD-C472:
1. Power switch off
2. Press CLOCK button.
3. Within 3 seconds, press MEMORY/SET button.
4. Press TUNING/TIME to select time mode (12 or 24 hour)
5. Press MEMORY/SET button.
6. Press TUNING/TIME to select hour.
7. Press MEMORY/SET button.
8. Press TUNING/TIME to adjust minutes.
9. Press MEMORY/SET button.
Please note, your "solution is valid for" choice forced the Sharp CD-C401 selection BUT THAT IS NOT ACCURATE THIS SOLUTION IS SPECIFIC TO THE CD-C472.
Posted on Jul 01, 2008
SOURCE: "NO DISC" reading
Try this CD realignment process built into the Sharp XL HP505: Have unit off.
Hol down the square (stop) button and the X-BASS button while pressing the ON button. This starts the CD TEST. press play, the memory, then memory, memory, memory, adjustment lights will come on the screen. FOF, TOF, TBAL, TGAN, FGAN, RFLS. press cd1 - track 4, press cd2 - track 9, press cd3 - track 15. Press square (Stop).
If all the cd trays are full, then will light up . This worked for me.
Posted on Aug 14, 2008
  • 4234 Answers
SOURCE: Sharp BA2100 3 CD mini component system - NO DISC
This is a relatively common problem when the optics get dirty. If you can reach the lens, try cleaning it using a cotton swab and alcohol. Don't bother with the "cleaning discs" available as all they can do is bruch off the dust. These lenses sometimes get a smoke or dirt film on them that the brushes can not celan.
Keep us posted.
Dan
Posted on Sep 17, 2008
SOURCE: cD Player returns NO DISK code
had similar problem, first things first.........clean lens with isopropyl alcohol on a Q-tip. to do this, you will have to remove cover and likely the disc tray. worked for me.
Posted on Sep 21, 2008
CD player rotates but wont play or read disc.
Cd spins but player can not play - ecoustics.com
www.ecoustics.com > Forum > Home Audio Forum > Mini Systems Forum
Oct 30, 2003 - Cd spins once system is on but player can not read discs. ... Traywon't eject. ... I have a Memorex 2Extreme CD player, and I insert the disk, and pushplay, and the CD acts like it's searching for awhile and then the screen ... Dvd player won't read any CDs (but use to ) - eCoustics.com
Sep 22, 2005
Cd makes clicking noise and I get Disc Read Error PLZ HELP ...
Dec 24, 2004
CD Player screen reads no disc - ecoustics.com
May 30, 2004
More results from www.ecoustics.com
How to fix a boombox CD player when it wont play - YouTube
? 5:15
https://www.youtube.com/watch?v=pH33UZveLYI
Jun 24, 2013 - Uploaded by Shyzah
How to fix a boombox CD player when it wont play .... My box reads "no disc", but it is in proper position ...
Dec 22, 2015 | Audio Players & Recorders
How do I get a user manual for sharp cd-c472
do a google search for "manual sharp cd-c472" several show up including the service manual.
Sep 27, 2014 | Sharp CD-C472 Shelf System
When I try to listen to the cd's, it won't play them. It tries to acknowledge them but the player won't play them
CD players commonly will not recognize some types of CD, eg MP3 recordings, or maybe CD-RW recordings.
However if this is happening with CDs that would previously play OK, then it could be
- scratched or dirty CD surface
- contaminated laser lens in the player
- laser lens has become misaligned
The last 2 need a service technician, but it may be cheaper to buy a new player.
Nov 19, 2011 | Audio Players & Recorders
CD player will not recognise or play disc
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it not recognize or play disc.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
Good luck.
Apr 05, 2011 | Sharp Multi-System Mini Component System...
My Sony mini hifi component system is going berserk!! 2 problems: 1- CD system skips tracks and on playing on repeat song, the song skips certain times and jumps ahead of the track. 2- Tape system plays...
Your cd player is fubar and in definite need of replacement.
Tape unit seems to have a mind of its won. Try to reset the electronics to factory defaults. If that has no remedy, since it is a sony< best advise is to trash it. Repair cost is prohibitively expensive.
Sep 19, 2017 | Sony MHC-RG222 CD Shelf System
Magnavox AZ9855 mini system (7 CD changer), trying to play a cd, the system ejects the CD and message Failed CD is shown. No CD will play.
Hi,when a system eject a CD and with a message "failed CD" It caused by the CD mechanisms that allows the CD to play to damaged that's why the CD keeps on rejecting the CD's being inserted into the CD player.
When you replace the CD mechanism that allow CD to play, problem solved.
Take care.
Oct 06, 2010 | Audio Players & Recorders
Where can I find a manual for sharp cd-c472 shelf system?
Hi you can get manuals here auto.manualsonline.com/ex/thread/view/idThread/399708
Aug 11, 2009 | Sharp CD-C472 Shelf System
Sharp cd-c472
1. Power switch off
Jun 30, 2008 | Sharp CD-C401 Shelf System
Sharp Multi-System Mini Component System Shelf System Logo
87 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
