Question about Sewing Machines
Problems with prolectrix sewin machine
My granddaughters prolectrix sewing machine will not pick up the bobbin thread can you help
  • 1 more comment
  • jpbville May 17, 2009
    The problem is there doesn't seem to be an easy way to get the thread into the compartment under the foot to enable the needle thread to pick up the cotton from the bobbin.  the printed instruction spend more detail on threading the needle! I'm sure it must be easy but it's totally confused me at the moment.
  • Maggie
    Maggie Nov 07, 2013
    my bobbin black casing catches in the bottom and refuses to pick up the thread - how must the black part fit into the pink part please someone - thanks
  • Anonymous Mar 19, 2014
    The adaptor is in, the plug works. it doesn't go at all. The light won't even come on.
    Is there an on off switch I've missed?
You have to make sure the bobbin thread is positioned right in the middle. When the needle comes down (into the bobbin compartment), you can peer into the bobbin compartment and see a loop of thread (coming out of the needle). You want to catch that bobbin (thread) in the loop of thread (that runs from the needle).
Posted on Feb 27, 2009
    President:
  • 1,734 Answers
I found the full Prolectrix 8 Stitch manual with google+ here.
Find it listed in the result pages.
Hope that helps!
Posted on Mar 15, 2013
I have a Brother CS6000i sewin machine and I'm
Mmmm Are you using the right stitch? Like zig zag or straight stitch only with a medium stitch length? Check that and test again.
Sep 06, 2012 | Sewing Machines
Thread on sewing machine won't pick up bobbin thread
the bobbin case does not move, just the bobbin.. if the machine is still under warrenty, I would take it back & get another sewing machine,, and probably not from them
Feb 26, 2012 | Sewing Machines
Prolectrix 8 stitch sewing machine top thread keeps getting caught round bobbin housing and jamming everytime i try to use it
Sounds like the take-up lever is not threaded.
Remove the thread from the machine, turn the handwheel until the take-up lever is at its highest position, raise the presser foot and rethread the machine. Set the upper tension dial to 5 and retry.
Aug 18, 2009 | Sewing Machines
Bobbin unravelling on prolectrix 8 stitch sewing machine
did you put the bobbin thread in the tensioner? that would be the cut in the side of the bobbin case to pull the thread under the tensioner. if not it will cause problems. but if the top thread is looking good then the top thread is the problem, thread the machine with the presser foot up to let the thread into the tensioner, if it looks good on the top and not the bottom it is the upper thread if it looks good on the bottom and not the top it is the lower thread
Jul 29, 2009 | Sewing Machines
Won't pick up bobbin thread
Does she have the right needle in? If the needle is to short it won't pick up the thread. If that is not the issue than it could be timing
Jul 28, 2009 | Sewing Machines
Needle not picking up bobbin thread on Prolectrix 8 stitch
my machine is not picking the thread from down bobbin thread ,i am fallowing the all instruction for threading.
Jul 21, 2009 | Sewing Machines
Bobbin thread not feeding into the upper needle thread
completely unthread the machine....ensure the needle piston shaft is in the correct position and retread the upper. reinstall the bobbin and turn the machine by hand to engage the bobbin thread. Draw the bobbin thread through the stitch plate and with the needle thread, allow to trail off the back. attempt to sew a piece of scap material.
please let me know what happens at this point.
clarkco
Feb 08, 2009 | White Sewing Fashionaire Sewing 2380...
My needle won't pick up the bobbin thread
My sewing machine is a Brother LS1217, well actually it is my son's, and he uses it very seldom. I went over to put in a new needle and I cleaned it top and bottom, put in a new bobbin, and a new needle and the needle won't pick up the bottom thread. What am I doing wrong? Please help me!! It has to be something simple, as this is such a simple machine! roseandjimmy@yahoo.com
Jan 11, 2008 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
1,332 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
