Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Disposal wont work
Knocked out plug now disposal wont work!!
  • Thomas F. Schneider May 11, 2010
    Have you pushed the reset button on the disposal?
    President:
  • 2,976 Answers
The reset button might be around the back, depending on which side the outlet is located on. It takes quite a good push to reset it.
Posted on Feb 17, 2009
2 Suggested Answers
clyde2j2
  • 137 Answers
SOURCE: garbage disposal wont work
I'm going to ask a dumb question first. You didn't by any chance leave the plug in the disposer did you? I didn't think so but I had to ask.
Next I would check the "red" reset button on the side ot bottom of the disposer, reset it by pushing hard it should "click".
If this doesn't work look under the disposer and see if the is a allen wrench opening in the middle of the disposer, if there is get the proper size wrench (sometimes they are included with the disposer) insert it an turn the disposer counter clock wise, if this turns freely, the next step wold be to call the man.
Posted on Feb 15, 2009
Dishwasher not emptying out water
If you recently replaced your garbage disposal make sure the "knock out" plug was punched out to allow drain water into the disposal. The guy who replaced my disposal forgot to do it and my dishwasher would not empty. It's an easy fix. Just remove the drain hose from the dishwasher that attachs to your garbage disposal. Look inside with a flashlight and you will see if it is still there.
If it is, take a hammer and screw driver or punch and knock it out. TURN OFF POWER to your disposal and you can retrieve the "knock out" plug (piece of plastic about the size of a dime). Replace your drain hose to the disposal and try your dishwasher again. Worked for me! Good luck.
Oct 05, 2014 | Dishwashers
After I installed my Badger 5 my dishwasher would not drain. Is there a plug in the dishwasher port on the side of the disposal and how do I remove it?
There is often a plug in the ISE as many people use them without have a dishwasher connected to them. Quite often it is just a thin plastic membrane that can be knocked out with a screwdriver. There should also be a note to this effect in your installation instructions for the ISE.
Sep 14, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My dishwasher is brand new but it wont drain? help
Hi and welcome to Fixya, When installing the unit was the dtain hose by chance connected to a disposer/garberator ? If yes, then I'd start by checking the drain spout of the disposer where you connected the drain hose from the dishwasher and make sure you knocked out the plug in the spout. **Turn off the power or unplug the disposer/garberator before performing any service** If the plug is not punched out, with the aid of a long screw driver and a hammer, or a firm smack with the palm of your hand you should be able to knock out the plug. Now reach in the disposer and remove the plug you`ve just knocked out, reconnect the drain hose for your dishwasher and you should be good to go. Let me know what you find and how it goes. Thank you for visiting FixYa. Please take a moment to rate the solution provided here for you. Hope that help`s. Good luck. macmarkus :)
Jul 30, 2010 | Maytag 24 in. MDB4100 Built-in Dishwasher
Not draining
I'd suggest you are correct in your suspicsion of the disposer being a likely problem.
Start by checking the drain spout of the disposer where you connected the drain hose from the dishwasher and make sure you knocked out the plug in the spout.
Good luck.
macmarkus :)
Jul 11, 2010 | Whirlpool Dishwashers
Water wont drain, just recently replaced garbage disposal. Tried the "drain" button but no luck
most likly you didn't knock out the knock out stop where your drain hose connects to the disposal, disconnect hose from disposal, it will probaly be block by a peice of plastic inside, take a straight slot screw driver and a hammer and knock out the plastic blockage, hook up hose and enjoy a glass of your favorite bevarage!
Mar 16, 2010 | Dishwashers
Water will dot drain, washer overflows and leaks. new drain hose and new garbage disposal was installed.
Did you knock out the plug where the dishwasher drain hose connects to the disposal. If you did not that is the problem. Plumbers will even forget the plug every once in a while. In side the spot that the hose connects to the disposal there is a plug. Knock it out and make sure you do not leave it inside the disposal or it will jam it. Hope this helps. Rick
Mar 07, 2010 | Dishwashers
I replaced a disposal and now when I run the washer cycle the used water shoots out the drain that is on top of the sink. It didn't shoot out that drain while the old disposal was working and the dishes...
The new disposer has a plug inside the dishwasher nipple that you must knock out. The dishwasher hose nipple is plugged so water won't leak out if you don't have a dishwasher connected. You must take a flathead screwdrivers and knock out the plug inside the nipple with a hammer or something. Make sure you don't leave the plug inside! The air gap is designed to prevent water from siphoning back into the dishwasher. With the disposal's drain connection blocked, the water exits through the air gap!
Feb 15, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Wont drain water out, have replaced filter. machine beeps and wont empty out old water. Whirlpool dishwasher, model adg7440
New garbage disposal? It's happened many times in my career- customer installs a new disposal then the dishwasher won't drain so they buy a new dishwasher to find the disposal didn't have the knock out knocked out. Check the easy stuff first.
Ken
Jan 08, 2010 | Whirlpool 24 in. ADG7540 Built-in...
Garbage disposal wont work
Feb 15, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
How to knock out garbage disposal plug
Turn off the power source to the garbage disposal. Take the drain hose from the dishwasher off the connector going to the disposal (if connected). Insert a flat blade screwdriver in the drain hose fitting and tap a few times with a hammer. The plastic plug will pop off inside the garbage disposal. Reach inside from the top of the disposal to retrieve the plastic plug. Sometimes you have to use a little force to tap the plug out. Hope this helps you.
Apr 07, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
140 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
