Question about iLO IWT3206 TV
CANT USE DIGITAL TV OR HDMI MODE - SCREEN NOT SIZED
I have a 32" ILO, When i put the TV in HDMI mode- the picture is not sized to the tv, its to big. but you cant adjust the picture to fit the screen. also it wont work on digital mode -it says " signal not supported". it will work on analog mode but the volume is low and sometimes the picture is fuzzy .....can anyone help ??? thanks
    Sniper:
  • 51 Answers
Give FUNAI a call they can walk you through the problem. There info is...
FUNAI CORPORATION Customer Service
Tel :1-800-605-8453
http://www.funai-corp.com
Posted on Sep 03, 2009
How to get tv back on. was trying to adjust picture size and accidentally clicked something to do with the HDMI and now tv won't come on
Hi U might have put youre TV into sleep mode ... unplug power cord for a few minutes if it is the problem it should lose its memory.,.good luck
Sep 02, 2016 | Televison & Video
Denon AVR - 2807 flickers in TV mode with picture & sound.
Change the hdmi cable and try. If not then you have an hdmi fault module.
Dec 15, 2013 | Denon AVR-2807 Receiver
I am not using cable or dish...what type of antenna should i use to get the most out of the digital conversion...and is the built in converter adequate or do i need converter box?
The specs for this TV shows it has ASTC and NTSC so you do not need a converter box.
Almost all the Digital channels are broadcasted in the UHF band.
When you scan in the channels the VHF numbers will still show but the actually signal will be in the UHF band.
Go to
WWW.TVFOOL.COM and enter your ZIPCODE to get the stations in your area.
MPN: IWT3206 Key Features Digital TV Standard: SDTV Diagonal Screen Size: 32 inch Display Capabilities Built-in Tuner: ATSC · NTSC Image Quality Comb Filter: 3DYC / 3D Digital Audio Features Audio Type: Stereo SAP / MTS Stereo: SAP / MTS Stereo Technical Features Sleep Timer: With Sleep Timer Connectors Rear Input Connectors: Composite x 1 · Audio (RCA) x 1 Front Input Connectors: Composite x 1 · Audio (RCA) x 1 Screen Text OSD Languages: English · French · Spanish Miscellaneous Product ID: 37594421 More Information Details: Big picture, small price. Enjoy watching your favorite, sports, programs and movies on this generously-sized 32" TV from ilo. The side stereo speakers help create a richer sound experience. Even more conveniently, the built-in digital (ATSC) tuner accesses digital content without the need for a separate set top box that takes up space. And since the screen delivers standard definition (SD) resolution.
Apr 05, 2009 | iLO IWT3206 TV
Ilo 32" flat screen lcd tv
We have the same problem. Any advise out there?
Jan 19, 2009 | iLO 3200 32 in. LCD Television
Ilo tv
You need to change the aspect ratio of the screen. The cable box remote has an aspect ratio button and the tv remote also has an aspect ratio button or picture size button. You are probably on a zoom aspect since its too big.
Nov 13, 2008 | iLO 3200 32 in. LCD Television
PS3
bad cable or bad port on tv. Test it. Get another set of HDMI and test it to see if it works. If it doesn't then the port on your tv is bad.
Oct 24, 2008 | iLO 3200 32 in. LCD Television
Ilo 27
If you have the original remote, try the "picture size" button.
Oct 22, 2008 | Televison & Video
Picture size
Hello! You need to put your tv into service mode and adjust the horizontal and vertical size. You can find info on how to enter the service mode for some brands at epanorama.net. Good luck.
barneyluc
Oct 10, 2008 | Televison & Video
I have a T5054 TV and the picture has zoomed in and is way too big, however in the picture settings menu the zoom option is not highlighted in Component mode.
There could be a problem, but verify the settings as listed in the owner's manual as follows:
1 Press the MENU button to display the menu.
Press the ▲ or ▼ button to select Picture, then press the ENTER button.
2 Press the ▲ or ▼ button to select Size, then press the ENTER button.
3 Press the ▲ or ▼ button to select the screen format you want.
Press the ENTER button.
Press the EXIT button to exit.
16:9 : Sets the picture to 16:9 wide mode.
Zoom1 : Magnifies the size of the picture on the screen.
Zoom2 : Expands the Zoom1 format picture.
Wide Fit : Enlarges the aspect ratio of the picture to fit the entire screen.
4:3 : Sets the picture to 4:3 normal mode.
Just Scan : Use this function to see the full image without any cutoff when DTV
or HDMI 720p/1080i signals are input.
Press the P.SIZE button on the remote control to change the picture size.
And realize the restrictions as listed:
• In TV, VIDEO, S-VIDEO, and COMPONENT(480i, 480p) modes, all screen
modes can be selected. (16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
• In COMPONENT(720p, 1080i) or HDMI(720p, 1080i) mode, 16:9, 4:3 and
Wide Fit can be selected.
• In Zoom1, Zoom2 and Wide Fit modes, you can move the picture on the
screen by pressing the ▲ or ▼ button.
•You can not change the picture size when PIP is set to Double.
•When Double ( , ) mode has been set in PIP, the Picture Size cannot
be set.
•Wide Fit can be used when watching a Digital HD (High Definition) signal.
Wide Fit sets the optimum picture format by expanding it both horizontally and
vertically. For example, you can reset the picture in 4:3 format to 16:9. Wide Fit
does not support all external devices (DVD, VCR etc.).
Keep us posted.
Dan
May 29, 2008 | Samsung Televison & Video
Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Mar 05, 2008 | Sony KDL-32M3000 32 in. LCD Television
iLO IWT3206 TV Logo
482 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
